Unusual ground strap on passenger side.. - FSB Forums
Thread Tools Display Modes
Old 02-14-2013, 12:06 PM   #1
epsgunner
epsgunner's Avatar
Bronco Info: 1993 Bronco XLT..351W
Question Unusual ground strap on passenger side..
While checking my 1993 Bronco I just bought I found this ground looking strap dangling.. I tried searching on here and found nothing showing this particular one..
Its on the passenger side from the body to?? guessing the frame?? maybe the radius arm bracket (that is rotting away and needs replacing)??
Anyone know what its for and where it goes??
epsgunner is offline   Reply With Quote
Old 02-14-2013, 12:09 PM   #2
TheUnforgiven
Salt blows goats for fun
TheUnforgiven's Avatar
Bronco Info: 2006 Kia Spectra
can attach it to body mount is where i *think* it should go.
2006 Kia Spectra 4 banger/5 speed.
I enjoy Alabama Hot-Pockets.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 02-14-2013, 12:14 PM   #3
jowens1126
jowens1126's Avatar
Nice Rust....
1994 EB Bronco, 302 MAF, E4OD, BW1356, box stock
jowens1126 is offline   Reply With Quote
Old 02-14-2013, 12:29 PM   #4
slhanks4
slhanks4's Avatar
Bronco Info: 1991 Eddie Bauer Edition w/140k miles, 351W, AOD
I was under my Bronco the other day and saw the same ground strap. It goes from the radiator support (where it's clipped to now) to the frame.
Scott
slhanks4 is offline   Reply With Quote
Old 02-14-2013, 12:29 PM   #5
jermil01
Charlie doesn't surf!!
jermil01's Avatar
Bronco Info: 1992 xlt, 351EFI, .040, E40D, D44 SAS w/Trutrac, Detroit locked 8.8, MAF conv, Tweecer tuned..
those are chassis to frame grounds and aren't as critical as the others.
You could always make a new ground strap or buy one, some of the marine stores have a heavier grade of strap, I believe NAPA carries them as well . Are you experiencing any strange electrical issues?
Vote 4 Top 4x4 Site!!!
jermil01 is offline   Reply With Quote
Old 02-14-2013, 01:22 PM   #6
epsgunner
epsgunner's Avatar
This one is near the radius arm bracket and my Catalytic converter though..
Old 02-14-2013, 01:27 PM   #7
jermil01
jermil01's Avatar
There are about 3 or 4 of these types of grounds on our rigs, not sure if I ever had one in that location or not..I know I don't now. In any case, the absence of this particular ground shouldn't have any ill effect on your rig.
Old 02-14-2013, 02:09 PM   #8
4DI2D
4DI2D's Avatar
Bronco Info: '93 Custom, '90 Lincoln 302, E4OD sixlitre tune and a lot of overdue service
And just where is the point where the chassis and frame separate
4DI2D is offline   Reply With Quote
Old 02-14-2013, 02:11 PM   #9
jermil01
jermil01's Avatar
excuse me....frame to body..happy now?
Old 02-14-2013, 03:12 PM   #10
DNBELOWBRONCO
DNBELOWBRONCO's Avatar
Bronco Info: '96, 5.8, 4.56, Rancho 4", 35's, Thorleys, Warn 8274, 5100's, 160 3G, Sag, 10.25, E-fan, Projectors
I have one from the lower right radiator support to the sway-bar mount bracket but I don't see anything by the radius arm or the cat so maybe the previous owner added or moved one there. You can see the other end of the clip right there on your body bushing mount. They are just grounds that Ford used to connect everything like the firewall to the upper plenum chamber and the negative battery cable to the frame rail and then to the side of the engine block. More won't hurt but less would be bad so find a non rusted spot if you can, and hook it up. Welcome aboard and nice way to pad/increase your post count... -Kevin-
DON'T GIVE UP PUSH THE PEDAL ON THE RIGHT JUST A LITTLE BIT HARDER DNBELOWBRONCO www.supermotors.net/17883 "Be who you are and say what you feel because those who mind don't matter and those who matter don't mind" -Dr. Seuss-
DNBELOWBRONCO is offline   Reply With Quote
Old 02-14-2013, 06:35 PM   #11
rustycharms
The ground straps are useful for reducing likelihood of static buildup and for minimizing RFI interference. There are several on the bronco.
Hope this helps.
rustycharms is offline   Reply With Quote
Old 02-15-2013, 03:46 AM   #12
Steve83
Steve83's Avatar
Steve83 is online now   Reply With Quote
Old 02-15-2013, 08:54 AM   #13
epsgunner
epsgunner's Avatar
Thanks Steve83 for the diagram... this may make sense as a radio ground strap..
My factory radio has the clock on and turns onto a tuned channel.. but I get no noise from the speakers for like 2-3 minutes.. maybe this ground is to help ground the speakers???
I'll try to re-attach and see what happens.. can't hurt..
Old 02-15-2013, 08:59 AM   #14
TheUnforgiven
doubt it. throw the ford radio in the trash and put in a decent aftermarket unit.
Old 02-15-2013, 11:08 AM   #15
Steve83
Steve83's Avatar
No. Just no...
You may not post replies
Forum Jump
