newbie with intermittent starting problem - FSB Forums
Thread Tools Display Modes
Old 02-17-2013, 05:59 PM   #1
franco
Bronco Info: 92 XLT 351
Hey guys...new to forum obviously but bought my first bronco today! 92 XLT with 5.8 l motor 110380 miles and i am having some issues.
on way home (about 5 miles into trip)the bronco started spluttering and coughing and then died.yes it does have fuel
Towed it home and immediately got some codes....
11 - system test pass
61 - map/bp sensor out of self test range
22 - ect sensor is less than self test minimum of 0.2 volts
i thought no problem went to store and got new map sensor and ect. got home installed the map and no difference still won't start.
Noticed that the coolant was way low and topped it up with about 1.5 gallons antifreeze. still no start.
installed new ect sensor and still nothing.
any ideas to point me in the right path?
franco is offline   Reply With Quote
Old 02-17-2013, 06:01 PM   #2
sackman9975
sackman9975's Avatar
Bronco Info: 1995 Eddie Bauer 357w, E303 cam on S/D, Warn premium hubs, 3 inch exhaust with flowmaster 40
Franco, welcome to the site.
You say it's got fuel, but have you tested the pressure?
~ Scott ~
~My Exhaust clip on YouTube ~ 204k on the odometer and no longer a daily driver. ~
~ Bronco owner/Driver/Mechanic/Enthusiast for 21 years ~
sackman9975 is offline   Reply With Quote
Old 02-17-2013, 06:09 PM   #3
franco
no i don't have a fuel pressure guage
Old 02-17-2013, 06:13 PM   #4
sackman9975
Get one. You can not rely on pressing the shrader valve to see if it has pressure. You need actual numbers.
~ Scott ~
Old 02-17-2013, 06:27 PM   #5
franco
yeah i know...wil go pick one up tomorrow. why will it run for a while and then not start again though? if i was having a pump issue wouldnt it be all the time?
Old 02-17-2013, 06:32 PM   #6
sackman9975
Not necessarily .......
I had an 86 Bronco that would run great for miles and miles, then started to run like crap......then run fine again for miles and miles, then back to crap. It ended up being the fuel filter. Once the filter was replaced, the problem went away.
Fuel pressure is funny. But you have to have positive numbers for it to even want to run correctly.
~ Scott ~
Old 02-18-2013, 06:30 PM   #7
franco
update....
was still getting the code for ECT so went back to auto store and had them test my new ect sensor...was bad new out of box. replaced with another "new" one and she starts up no problem and runs full time now!
however i got a failed TAD sensor now and am waiting on replacement part for that as they are hard to come by.
Old 02-18-2013, 06:45 PM   #8
Yeti_Rescue
Yeti_Rescue's Avatar
Bronco Info: 95 302 auto man hubs in "oj" white
Originally Posted by franco View Post
update....
Awesome !!! Glad to see you follow through on this . Bad parts get sold everyday and for some reason people just acccpt the fact that if there new there good.Nice job and follow through . Good luck on the TAD , if you can't find one let me know.
Only dead fish go with the flow
Yeti_Rescue is offline   Reply With Quote
Old 02-19-2013, 09:37 PM   #9
'95 XLT
'95 XLT's Avatar
I have a newbie question, I can find what TAD and ECT stand for.. I was searching threads because I am having some starting issues of my own, and I was doing some research and found this thread..
'95 XLT is offline   Reply With Quote
Old 02-19-2013, 10:20 PM   #10
Seattle FSB
Seattle FSB's Avatar
Bronco Info: 1990 EB FSB, MAF, 6.7L, E4OD, 4" Rancho, 4.56, 33" on 15x10 Alcoa's
TAD - Thermactor Air Diverter [Solenoid or Valve]
ECT - Engine Coolant Temperature [Sensor]
See this link: EFI Abbreviations
And browse these pages: Ford Fuel Injection
1990 Bronco, MAF, 408 Stroker, Level 10 E4OD, Currie F9+, Electric Boost Brakes, lots more...
Seattle FSB is offline   Reply With Quote
You may not post replies
Forum Jump
