1978 Bronco what size tires? - FSB Forums
Thread Tools Display Modes
Old 02-17-2013, 10:10 PM   #1
78Bronkadonk
Here in a few months im going to buy a body lift. (i don't have cash for suspension and i just wanna lift the truck) I would like to put 35's on it. If I get a 3 inch body lift, will 35's work well? what about a 2 inch body lift? its got 31x10.5x15 on there right now, i bet i could fit 33's stock... but idk, what do you guys think?
78Bronkadonk is offline   Reply With Quote
Old 02-17-2013, 11:43 PM   #2
79BOSSHOGG
79BOSSHOGG's Avatar
Bronco Info: 1979 Ford Bronco Custom, 351m, c6 auto, np205 transfer case, 4" suspension lift, 35" tires
With a 3" body 35s will be pushing it. They will rub and you won't have much clearance. I have a 4" suspension on a 79 bronco and 35s look nice and have enough clearance. If all you can do is 3" body the max I'd do is 34s
[><]BOSS HOGG[><] NOT A CONCRETE QUEEN!!! GOTTA PAY TO PLAY!
79BOSSHOGG is offline   Reply With Quote
Old 02-17-2013, 11:52 PM   #3
LarryP
Thanks 351w500
LarryP's Avatar
Location: Northcentral,CA.Twain Harte, up here in the mountains
Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
Wrong info there bud.
Nobody makes a 34 inch tire
35's fit with no rubbing on 78/79 broncos that's common knowledge here for the most part. with a 4 inch lift I was clearing 38's with no rubbing and I have flexy suspension. When my 78 was stock I wheeled the piss out of it weekly with 35's and never had a rubbing problem ever.
I take Prayer Requests. God Bless
LarryP is offline   Reply With Quote
Old 02-18-2013, 06:39 AM   #4
OX1
OX1's Avatar
With stock suspension travel, 35's will fit no problem with 3" body lift. I have 35 BFG AT's, 2 inch front springs and it does not hit on the street even with a plow on the front.
Now if you go with a 35 X 14.5 bogger, it probably will hit, so you need to decide what tire you are talking about before anyone can truly answer the question.
79 XLT, 400/C6/mog 404's/42 IROKS, 8.5" lift.
79 XLT, 400/C6/D60-D44 8 lug, 2" lift, 35 BFG AT
74 Bronc build, 408/C6/Black Box/205/406 mogs/43 SX stickies
OX1 is offline   Reply With Quote
Old 02-18-2013, 07:43 AM   #5
Raped Ape
Raped Ape's Avatar
Bronco Info: 1991 Ford Bronco EB 5.0
When i had my 79 i had 37's stock. There wasnt much room at all in the wheel wells and it did rub at full turn. When i put the 3" BL it def made a diff in rubbing the fenders when wheeling. again it did rub the radius arms at full turn..
If you go to my thread there are pics to give you a better idea for room.
VOTE FOR ME FOTM! http://www.fullsizebronco.com/forum/...d.php?t=219679
1991 Ford bronco E.B. 5.0 V8 3" Suspension lift & 3" BL 1979 ford bronco 3" BL on 37x12.50x17 (sold)
Raped Ape is offline   Reply With Quote
Old 02-18-2013, 10:40 AM   #6
78Bronkadonk
ok so ill probably go 2 inch body with 35's. the only problem is that i cant find 35x12.5x15 ANYWHERE.. think i found one tire but it was 250 a piece. is that normal? i payed 70 a piece for my 31x10.50x15's...
Old 02-18-2013, 11:50 AM   #7
mrhp
Swampers come in 34 inch.
mrhp is offline   Reply With Quote
Old 02-18-2013, 11:57 AM   #8
f150inline
f150inline's Avatar
Bronco Info: 96 F150 (soon to be sold) 94 bronco, stock for now
save up for the suspension lift it will be worth it in the end.
96 f150 straight 6, d44 SAS, 4.56s, Aussie lockers, 35 inch mtrs. My build thread http://www.fullsizebronco.com/forum/...d.php?t=213623
f150inline is offline   Reply With Quote
Old 02-18-2013, 12:14 PM   #9
broncomine
Bronco Info: looking to trade for chv or dodge NOT
craigslist always seeing cheap suspension lifts for solid axles
broncomine is offline   Reply With Quote
Old 02-18-2013, 12:48 PM   #10
78Bronkadonk
true but i dont wanna worry about u joints and stuff as well.
Old 02-18-2013, 02:03 PM   #11
LarryP
Thanks 351w500
LarryP's Avatar
why would you have to worry about U-joints?? If you do a lift right it all works.
Old 02-18-2013, 03:15 PM   #12
bluebolt
Bronco Info: 1974 Bronco with 351w, 1978 F150 4x4 with 1966 F100 cab
34's
It's not a common size but Interco has Super Swamper TrXux in a 34/12.50/15 but not cheap at over $300 each. They have a few others in a 34 but narrower.
bluebolt is offline   Reply With Quote
Old 02-18-2013, 04:14 PM   #13
78Bronkadonk
I wanna get 35x12.50x15 but they are like 250 a piece. is that normal? or is that pretty high...
Old 02-18-2013, 04:37 PM   #14
LarryP
Thanks 351w500
LarryP's Avatar
That's about the norm for new tires. Look on your local craigslist You can probably find a whole good set for $400 to $600
Old 02-19-2013, 01:05 AM   #15
78Bronkadonk
ill take a look
Old 02-19-2013, 01:26 AM   #16
78-79FordMan
Ford Hoarder
78-79FordMan's Avatar
Bronco Info: 7 of them 1978-79's and 1 of the 1991's and 1 of them 1986's
Yap 35 no lift works ..
Sent from my iPhone 5 using Tapatalk 2
Ford It Man
78-79FordMan is offline   Reply With Quote
Old 02-19-2013, 01:38 AM   #17
78Bronkadonk
alrighty then, cool. NOONE around me on craigslist has 35 inch tires for 15 inch rims, and tbh i dont wanna get bigger rims.. thanks for all the help everyone.
Old 02-19-2013, 01:46 AM   #18
DNBELOWBRONCO
DNBELOWBRONCO's Avatar
Bronco Info: '96, 5.8, 4.56, 4", 35's, Thorleys, Warn 8274, 5100's, 160 3G, Sag, 10.25, E-fan, Projectors, 8-Lug
Yeah, I see 35's on Craigslist here all day long for $500 with like 85-90% tread on them. There is a guy right now selling 37x12.50x17's Pro Comp A/t's with decent tread for $250 and another guy selling almost new 37x12.50x17 TSL's for $700....bad crab is miserable I had that once sucked bad! -Kevin-
http://sacramento.craigslist.org/pts/3627025480.html
http://sacramento.craigslist.org/pts/3621792181.html
DON'T GIVE UP PUSH THE PEDAL ON THE RIGHT JUST A LITTLE BIT HARDER DNBELOWBRONCO www.supermotors.net/17883
"Be who you are and say what you feel because those who mind don't matter and those who matter don't mind" -Dr. Seuss-
DNBELOWBRONCO is offline   Reply With Quote
Old 02-19-2013, 01:47 AM   #19
DNBELOWBRONCO
Where are you?
Old 02-19-2013, 09:34 AM   #20
78Bronkadonk
Originally Posted by DNBELOWBRONCO View Post
Where are you?
in the fayetteville Arkansas area.. looking for 35x12.50x15, gotta be 15 inch rim
You may not post replies
Forum Jump
