#1 |
Mentally in Cancun.
iTrader: (11) Bronco Info: 1996 Ford Blazer. Lifted, locked, and loaded. Where's the Zombies?
1996 Emission Issues – P0420
I installed the Bassani headers, y-pipe, and Auto Zone tailpipe several years ago. Everything has worked great however, every winter I pop off a P0420 emissions code (Bank 1).
Does anyone know why this happens only in the winter time or how to fix this? I have to smog my truck in the next couple of weeks and want to fix the issue more than dumb luck. Here is some information pulled from the Freeze Frame: P0420 Bank 1 Fuel Sys 1 – CL Fuel Sys 2 – CL-Fault Calc Load (%) – 65.10 ECT (ºF) – 185 STFT B1 (%) – -3.13 LTFT B1 (%) – -2.34 STFT B2 (%) – -3.91 LTFT B2 (%) – -2.34 Engine – 1883 Vehicle Speed (MPH) – 53
![]() ![]() California Bay Area off road UC4x4.com
| Sponsored Links | |||
Advertisement | |||
#2 |
Have you checked for leaks? I had lots of leaks by collector and gasket was popping code on bank 1 as well. Snugged up bolts have not seen it for 250 miles.
#3 |
Mentally in Cancun.
Simple enough. I can try that as a starting point. I will let you know what happens in the next few days.
#4 |
I used to know this stuff
yo Stan;
This is by Ford in a 96 P0420 - Catalyst System Efficiency Below Threshold (Bank 1) Indicates Bank 1 catalyst system efficiency is below the acceptable threshold Use of leaded fuel Damaged HO2S Malfunctioning ECT High fuel pressure Damaged exhaust manifold Damaged catalytic converter Oil contamination Cylinder misfiring Downstream HO2S wires improperly connected Damaged exhaust system pipe Damaged muffler/tailpipe assembly Retarded spark timing Compare HO2S upstream & downstream switch rate. Under normal closed loop fuel conditions, high efficiency catalysts have oxygen storage which makes the switching frequency of the downstream HO2S quite slow compared to the upstream HO2S. As catalyst efficiency deteriorates, its ability to store oxygen declines and the downstream HO2S signal begins to switch more rapidly approaching the switching rate of the upstream HO2S. Once beyond an acceptable limit the DTC is set.
96 XL 5.0 E4OD, Man Xfer/Hubs USN (Ret) & MIL/DoD Contingency Planner (ret) THANKS to ALL WHO SERVE! my broncolinks.com was "disturbed"; but some sections are archived @ http://web.archive.org/web/201209211....com/index.php |
#5 |
Chillin on the Gulf Coast
![]() Join Date: Apr 2009
iTrader: (4) Bronco Info: Blue 89' 5.0, E4OD, OBDII, Mass Air, Saginaw/hydroboost, 3G alt
How far from the manifolds are your O2 sensors? If they are too far away you may not be keeping them warm enough when its cold outside. If so wrapping the exhaust or moving the sensor closer to the manifold will help.
μολὼν λαβέ Build the best you can with what you have to work with. Quality parts and quality installation is where it all starts. "It is idle to say that combinations of old elements cannot be inventions; substantially every invention is for such a 'combination': that is to say, it consists of former elements in a new assemblage." Supermotors |
#7 |
Unless you find a leak in the exhaust you need a new catlyst. I have seen this many times on all different vehicles and it almost always comes down to the cat.
#8 |
Looking back at your freeze frame data, your truck was popping the code at 1883 RPM and 53 MPH, unless that was right after you hat taken off moving your O2 sensor should have been warm. Most of the time when the sensors don't stay warm enough it is when you are sitting still idling for some time. You make no mention of if you installed new cats or not. If they are original they could be failing.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
