#1 |
transmission question
I recently purchased an 88 bronco xlt w/ 5 spd manual trans . At the time I test drove it it had a pretty load exhaust leak at the right donut . I had the leak fixed yesterday so now that I can hear clearly I notice that the transmission is quiet on 1-2 shift but when I get to 3rd gear and above I hear a grinding noise thats stays constant while accelerating .Strangly sometimes , maybe 50% of the time ,it makes the noise while in second also. When I take it out of gear and coast its quiet . The person I purchased it from had the trans rebuilt and clutch replaced a couple of thousand miles ago . It dosent grind while shifting so I know its not the clutch .
So to put it simply . !st gear sounds perfect,no grinding at all .2nd gear is a sometimes . 3 4 and 5 are everytime . Am in for trouble? What could it be ? Thanks for any help |
| Sponsored Links | |||
Advertisement | |||
#2 |
Check fluid, I have a similar wine in mine when at 1st-2nd. I notice that it does this when cold and when my fluid was low du to a leak on input shaft leak. I'd like a zf5 but the mazda dog has worked fine for almost 4 years for what I use it for. I've towed wheeled and hunt not to mention daily drive it to work. My pilot bearing was also shot by the way last time I pulled motor last month.
#3 | |
#4 |
gone fish'n
![]() ![]() Join Date: Feb 2003
iTrader: (4) Bronco Info: pile of parts
is the noise follow engine rpm's or constantly get louder as your going faster?
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun! ![]() Let's Go Fishing. |
#5 |
It doesnt follow rpm or get louder . As soon as its in gear it starts and stays constant as long as Im accelerating if I let off the gas it goes away about 90% If i take it out of gear and coast it stops completely .
#7 |
AKA: Butthead
iTrader: (0) Bronco Info: '91 RoadQueen 351w-2wd-ZF camtiming+4* 265/75-16E's dual Ranchos F&R, SuperCab bench seat EEC=F250
Are you sure about that 4th gear business? ;)
4th gear bypasses the cluster gear, see? Cluster gear bearing noise is common is why I ask. My ZF has that and has "torque rattle" from its loose bearings too. My '75 F150's T18's got twice as many miles as the ZF and hasn't got any of those noises! The ZF ain't all it''s hyped up to be, IMO. How many miles the Bronco got on it? Alvin in AZ |
#8 |
Clutch engagement point
88 Bronco 5.0l 5spd manual . Previous owner replaced the clutch when the trans was rebuilt . The clutch engages very high up on the pedal ,almost at the very top . Im having trouble getting used to it . Is there any way to adjust this so it engages at a lower point on the pedal travel ?
#9 |
iTrader: (98) Bronco Info: '83 VIN & title on '93 frame/body w/'95 4.9L & EB paint
#11 |
Its got 131000 but the trans was supposidly rebuilt about 2000 mi ago . The sound is sometimes in 2nd and always in 3 4and 5 . It sounds very similar to what off road tires sound like on pavement
#12 |
You thought what......
![]() Join Date: Oct 2012
iTrader: (0) Bronco Info: Sold the 79 waiting for a next to free 80s to snatch
Is there oil in your transfer case? Bad u-joints will make a growl on power and quiet when off power as well.
79 Bronco 6" lift, mild 460, and 3/4 tons----Sold ![]() 94 F150 4x4 302 zf5spd swap----run about 97 F350 Crew Cab 4x4 4" lift---work beast Old guys,......they're tricky. |
#13 |
Thanks 351w500
![]() ![]() Join Date: Mar 2005
Location: Northcentral,CA.Twain Harte, up here in the mountains
iTrader: (52) Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
Threads merged, please just add your new ?'s on the tranny here, no point in making new threads on one issue. Thank you.
![]() I take Prayer Requests. God Bless |
#14 | |
Ill also check the u joints .If it was u joints wouldnt it also do it in first gear ? |
#15 |
AKA: Butthead
Do more checking and less reasoning?
You'll get better results and get it faster both. ;) About Steve's information... read it slow and careful little by little, it's condensed information like poetry. ;) Alvin in AZ ps- Just found this picture. :) Cut a ~1/4" hole in the bottom (pinched it and used scissors) to increase the master cylinder's reserve volume because of a leaky slave was just getting to be a true pain...
#16 |
There's a reason it's sealed - it keeps water & everything else out of the fluid, and the fluid in the reservoir. Cutting a hole in it is like cutting out the floor to let a rain leak drain. If you have a leaky slave, fix the problem - don't create a new one to mask it.
#18 | |
AKA: Butthead
But that brings up the next question. What rain? LOL :) As far as fixing the slave that's been planned to do for almost a year along with replacing the bearings and a few gears (including their synchro sleeves) in the ZF. I got the new slave and ZF parts that long ago. Looking like it's gonna have to wait another few months and got tired of adding brake fluid almost every time we drove it so made it, so, now only have to add it every few times we drive it and it's now more convenient to add the fluid to, since that rubber baffle/seal don't have to be removed first. The wife's not complaining about the new setup, so why should you, Steve? ;) The slave is toast. The master is cheap and easy to replace if it gets damaged by dirt. (got an extra anyway) So what's there to protect at this point? :) Naco Culo Gringo en AZ ps- Oh BTW, I -drilled-holes- in the floor to let the rain out! LOL :) Did that in the bed of my '75 F150 when I first got it, drilled my dune buggies (that had a floor) and drilled holes in the groove under the plastic threshold on the Bronco. Anymore questions? ;) |
#19 |
Heres a bit of interesting information . I put the truck in 4WD H and the grinding noise goes away !! Im assuming thats a significant bit of info although I dont know what it means . Can someone please help
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
