Not starting - FSB Forums
Thread Tools Display Modes
Old 02-24-2013, 10:57 PM   #1
medic2731
Bronco Info: 1994 Bronco EB Edition, Dark Blue c Camel Top, 157Kmiles, 5.8L E4OD Trans, push button 4WD
Not starting
Ok, been awhile but I went out from work yesterday morning and my 94EB would crank, but not turn over. Almost sounds like it is out of fuel. Had the battery replaced last week, and I can hear the pump priming when I turn the key. Really sounds like a dead empty tank. Maybe Fuel pressure regulator? Any ideas or suggestions?
Thanks in advance!
Patrick
medic2731 is offline   Reply With Quote
Old 02-25-2013, 07:48 AM   #2
472SCJ
472SCJ's Avatar
Bronco Info: 78 Bronco,472 Super CobraJet,C6 3500 stall,39.5 Super Swampers, 5:14 Ratio
check to see if there is fuel pressure at the injector rail, by pushing in on the valve after you turn on the key, better yet if you have a pressure gauge screw it on the valve and check pressure...always need to determine if it is electrical or fuel related , before throwing money at a problem
472SCJ is offline   Reply With Quote
Old 02-25-2013, 03:31 PM   #3
Ssrkid86
Ssrkid86's Avatar
Bronco Info: 1978 Ford Bronco 351 4x4
Agreed. Make sure there's pressure at the rail. It's never a bad idea to replace the fuel filter. Gas nowadays suckssssssss so replacing the filter for the 10$ it costs is never a bad preventative maintenance measure.
1978 Ford Bronco 4x4 (351m) - Just for fun
1989 Ford Mustang conv. (4cyl) - DD
1988 Ford Mustang GT (331 stroker) - Race Car
2005 Ford F-150 (5.4 3v) - Towing rig
Ssrkid86 is offline   Reply With Quote
Old 02-26-2013, 05:47 PM   #4
medic2731
Ok. Truck sat for 2 days, had a friend that is an auto tech go to check it out and it started right up for him without a problem. Kind of confused, but I am obviously happy. Maybe wet wires from the rain? I guess it is kind of a moot point now, but....
You may not post replies
Forum Jump
