79 bronco with Daina 44 and ford 9 inch to Rockwells - FSB Forums
Thread Tools Display Modes
Old 02-26-2013, 03:47 PM   #1
waylan88
Has anyone ever put a bronco on rockwells? I know it has been done, but trying to get more information. I have 351 with a cam pushing 52's AT2A goodyear military tires. I just took off the old axles and am working on putting on the rockwells. It is just for a mudding truck so not too worried about the smaller 351 engine. Hoping the rockwell gears will even it out. Any opinions?
waylan88 is offline   Reply With Quote
Old 02-26-2013, 05:28 PM   #2
LarryP
Thanks 351w500
LarryP's Avatar
Location: Northcentral,CA.Twain Harte, up here in the mountains
Bronco Info: 88 Centerion 460 Dana 60/10.25 78 Bronk Cromo shafts,Detoit 4.56's lift 7" Deavers 38's 9"rear disk
please look where you post. thread moved
I take Prayer Requests. God Bless
LarryP is offline   Reply With Quote
Old 02-26-2013, 07:09 PM   #3
I6 Bronco
Bronco Info: 300 I6, 79 bronco Frame 84 F150 cab
Wow, just skipping the stearling/dana swap? Pictures? How did the 9" like the 351 pushing those 52s and how long did that last?
I6 Bronco is offline   Reply With Quote
Old 02-26-2013, 07:54 PM   #4
waylan88
Still putting the rockwells on. Gonna have it done this weekend. Had 456 gears on 46s and the 351 crawled fine. Bumped it to 671 rockwell gears so im gonna try to turn 52s. not looking to spin them, just drop it in 4 low and crawl. Will be looking for 460 engine swap after the next mudfest.
Old 02-26-2013, 10:19 PM   #5
Dovepower
Dovepower's Avatar
Bronco Info: '79 Bronco 460 C6 coilsprung D60front/D70rear 1410Driveshafts 40"swampers 6"susp/3"body. 2003 Excur
You NEED a subframe if you want it to last more than a few years. Ask Rockford 514. He has a 79 frame with rockwells at the house and it is catching all kinds of hell and is not holding up well. His 87 bronco is subframed and is holding up great. Except for that tree incident but we won't get into that
"Everything feels tight when you're full-sized!"
Dovepower is offline   Reply With Quote
Old 02-27-2013, 01:54 AM   #6
88Bronco300
Why do you want to see my
88Bronco300's Avatar
Bronco Info: '88 XLT, 4.9/C6/BW 1356, 38.5" SX/Bogger combo on 10 inches. Stock rears, stock gears. For now!
I want to see pics of this beast.
88Bronco300 is offline   Reply With Quote
Old 02-27-2013, 07:35 AM   #7
badass1tonf100
badass1tonf100's Avatar
Bronco Info: F100,460, 1tons, 203/205 doubler, sitting on 42" pitbull rockers.
PM Spare Parts Doug, Flight 429, and Rockford514 on TGW.com Forum All very knowledgable.
badass1tonf100 is offline   Reply With Quote
Old 02-27-2013, 05:41 PM   #8
Rockford514
Mud God
Rockford514's Avatar
Bronco Info: 66,79,79,87
X2 on a subframe
Buddy
Better To Be An Open Sinner Than A False Saint
Rockford514 is offline   Reply With Quote
Old 02-28-2013, 09:56 AM   #9
waylan88
thanks guys. Im trying to upload some pics, but having some problems. It wont let me copy and paste. Im looking into subframes now. Have all the rockwells ripped apart. One of the problems Im having is getting rims for the rockwells. Having someone build them, they are about 2000. I have the old rims off the axles, so Im thinking about buying steel rims, cutting the centers out of both and switching and welding. Anyone done this?
Old 03-01-2013, 08:34 AM   #10
cajunrebel
Chillin on the Gulf Coast
cajunrebel's Avatar
Bronco Info: Blue 89' EB 5.0, E4OD, OBDII, Mass Air, Saginaw, Hydroboost, 3G alt
R-centered hummer wheels are good if you can run em. If not then I would PM rockford and get his recommendation.
μολὼν λαβέ
Build the best you can with what you have to work with. Quality parts and quality installation is where it all starts.
"It is idle to say that combinations of old elements cannot be inventions; substantially every invention is for such a 'combination': that is to say, it consists of former elements in a new assemblage."
Supermotors
cajunrebel is offline   Reply With Quote
Old 03-02-2013, 08:56 AM   #11
Rockford514
Mud God
for the 52s ? I have a set mounted on stock 2 1/2 wheels
Buddy
Old 03-02-2013, 10:16 AM   #12
waylan88
Yes I'm looking for 20 inch rims anywhere between 11-14inches wide that will fit on 2 1/2. Having a lot of difficulty finding a set thats affordable. That's y I was considered cutting and switching centers. This is a first for me on makin wheels. Would much rather buy some,
Old 03-03-2013, 10:03 AM   #13
Rockford514
Mud God
If your in Florida check out one of these guys
http://www.tgwforums.com/?forum=190572
Buddy
Old 03-05-2013, 10:16 AM   #14
waylan88
Thanks, they were able to give me some new information that that helped alot. Still thinking im going buy older steel rims and replace the centers with the ones off the original rockwell wheels. Have a friend that is pretty good with a plasma cutter. If any of yall are putting rockwells under your bronco your gonna need 4 york arms and bushings for the front axle. They are type 1, the brand is Euclid, and the part # is E-5256. Were putting the axles on today.
Old 03-07-2013, 03:38 PM   #15
waylan88
Any ideas on what engine would be a good swap for the bronco? I have a 351 in her now, but pushing 53 inch tires im wandering if it can handle it. Even with the 671 gears of the rockwells im thinking it may overheat the engine. Planning on putting electric fans on the radiator to help with overheating. Any other ideas? or engine size swap?
460? would a bigger engine ex. 550 stroker pushing 700+ horse be too much for these tires?
Old 03-09-2013, 08:58 AM   #16
Rockford514
Mud God
any pics
460 best Ford engine
Buddy
Old 03-19-2013, 10:48 AM   #17
waylan88
The 351 has very low miles so Im prob just going to run it awhile. Using 4 tork bars in the front and 2 in the back worked great. The type of 18 wheeler tork bars I used are listed in above listing. The 671 gears in the rockwells work great. Still waiting on upcoming mudfest in El campo texas on april 14th. Switching the a pinion break system on the drive shaft is much better than using the wheel breaks. Easy to set up and very affordable. $150 shipped w/o caliper.
You may not post replies
Forum Jump
