#1 |
iTrader: (0) Bronco Info: 1988 XLT, 351W. stock hight right now with little 31X 10.5 tires. soon to have 33 X 12.5
4" lift with 33's VS. 6" lift with 35 or 36's
I am putting 33's on my 88 Bronco now. i know they will fit with no issues on the stock rims. I plan on doing some trail riding with this thing so extra ground clearence is a good thing. I am thinking about going with a 4" and keeping the 33's. But as everyone says if you go with a 4" you will wish you did a 6. But if I go with a 6 then I will want the bigger tires so it doesn't look silly and then I get into a whole nother issue of more stress on the axles from the bigger tires, have to do a gear change to compensate for the bigger tires, alignment issues etc...... My question is what are the pro's and con's between these 2 setups with the type of driving I am wanting to?
I did not buy it to make it pretty, i am going to beat the hell out of it! |
| Sponsored Links | |||
Advertisement | |||
#2 |
Screw the Jeep Thing
In my opinion there is no real con of going 6" over 4" or 33s over 35s. You'll get about 1" of ground clearance which will make a bigger difference then you'd think.
35's are still a good street tire to have. You can regear or not, just depends on how you like the truck with less get up. If you drive alot on the highway you'll be ok. Cost difference isn't really an issue either maybe $200 more for 6" and 35's. Alignments wont be an issue as most kits are the same for 4 and 6". the TTB brackets will have both holes in them. The radius arm brackets are the same.
'84 Bronco (SOLD) - I6 Motor, ALL STOCK '93 Bronco Eddie Baurer (SOLD) - 302, E40D, 1356, 6" Lift, 35x12.5 BFG AT's '94 Bronco XLT - Build to play hard |
#3 |
I guess the only other issue would be axle breakage but as long as I don't go nuts trail riding/mudding I shouldn't have to worry about it?
#4 |
iTrader: (0) Bronco Info: 1991 XLT 33" MT/r, 351,355s, Powertrax rear locker, aussie front, 4" BDS long arm, hefty sliders
I went 4" as to still fit in the garage. Also wanted to keep the center of gravity as low as possible.
If I decide to go 6", figured I would just do a shackle flip and put new coils up front and use the bottom pivot mount holes instead of the top ones. As of right now, I have no plan to go to 6". I am very satisfied with the 4" and 33s.
#5 |
![]() Join Date: Jan 2010
iTrader: (1) Bronco Info: 1996 EB Bronco 5.8, E4OD, BW1356 Transfercase, 6 inch BDS Lift w/Procomp Leafs,172,000Miles
You can do 4 inch lift with 35's. they should fit fine. My old bko had a 4 inch lift with 33's and had plenty of room to do 35's.
"hold my beer and watch this" ![]() Hydroboost walkthrought My Build Thread!! II My Build Thread!! - retired |
#6 |
iTrader: (5) Bronco Info: '86 302, Bassani Y, 3" exhaust, 6l ignition, 33" KM2, Saginaw, Drop in K&N, Chopped Top
I don't know *anything* about suspension/alignment, but don't you start running into TTB issues as soon as you get beyond 4"? Something about the proper lift parts not being available to do it right?
#7 | |
There is a truck around the corner from me that has 35X12.5's on stock wheels with no lift at all. It looks cool but you can tell as soon as that thing hits a city titty in the road it will rub....lol.
#9 | ||
#10 |
The kits will have drop brackets for the pivot points. Most with have an upper hole (4") and lower holes (6"). The radius arms will then either have drop brackets, or extended arms with new brackets around 15" back from the original ones.
#12 |
Maybe if you don't lift it correctly. But I had 6" lift on 2 broncos and never had an issue with the alignment. I think post people things it's a bad alignment because it wanders more then it used too. But it's a TTB with bigger tires. I think thats really the only reason.
#13 |
iTrader: (0) Bronco Info: 1988 XLT, 4" Rancho lift, Steel Wheels w/33" BFG's, Line-X on sides for scratch protection
I have a 4" on 33" BFG's and the thing rides nice. Have never had an issue with ground clearance, but im in the desert and don't know how that compares to the woods and other terrain.
Ford Certified Parts Counterman |
#14 | |
For what it's worth, I'd stay stock with 33s until you feel like you need a lift. 33s fit very nicely from stock (on my 86, not sure the difference for you) and I still haven't felt an actual need for a lift. What I have felt the need for is a rear locker. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
