351m / 400 transmission & TC options - FSB Forums
Thread Tools Display Modes
Old 07-29-2013, 11:48 PM   #1
landshark99
Too many broncos!
landshark99's Avatar
Bronco Info: 1969 and 1976 Broncos
351m / 400 transmission & TC options (chose ZF-5 + Dana20)
I have done quite a bit of reading over at FTE but wanted to post up here as well as this forum is a bit busier (more active) so might get more eyes on.
I have about had it with the NP435, love the granny gear but hate just about everything else. Shifts like a bag of hammers, clutch takes the hulk to engage (centerforce clutch?), gearing is spaced out like half of Colorado and while I could probably live without the overdrive I do quite a bit of highway miles, enough that it would make a difference to have it.
I know my options are pretty limited considering I will need a transmission that has the big block bolt pattern while trying to keep the rear driveshaft as long as possible.. this is on an early bronco by the way. I love the granny gear, would like to retain that either through the transmission or transfer case. Overdrive.. half the reason i would like to do this swap.
Keeping a manual transmission what are my options, what about transfer cases?
EDIT: Decided to go with a ZF-5 out of a 460 truck and use the adapter to retain the Dana 20. I will keep this thread updated as my build thread too :)
I'm currently leaning toward a big block zf-5 (some machine work and fab envolved) with either the $$$ adapter mated to a D20 or an $$$$ atlas... I know the np205 mates directly to the zf-5.. but the length!
landshark99 is offline   Reply With Quote
Old 07-30-2013, 07:16 AM   #2
79F150
Dictator/Tyrant
79F150's Avatar
Bronco Info: 1979 F-150 400/NP 435/NP 205/D60/10.25
C-6 would be the easiest swap for an auto but no OD. ZF would be another option and not a hard swap. E4OD would be a PITA but not impossible. You would have to use a stand alone computer set up.
A 205 is not that long of a case and I think the D20 is same mating pattern? Not to sure about the input spline count?
79F150 is offline   Reply With Quote
Old 07-30-2013, 10:31 AM   #3
landshark99
Too many broncos!
No auto for this rig, keeping the manual.. plus this is on an early bronco (69) never get the e40d to fit without a stretch and I don't think it will fit between the frame
Dana20 requires an adapter to mate to the zf... I think it runs close to $700 - I'm on my way to an atlas at that price...
NP205 mates right up to the zf but its heavy and makes things even longer.. every inch counts as they say especially on an early bronco.
I need to take some measurements, but to check my boxes I think the zf is the only candidate. I have been reading a few threads of guys who have adapted it to the 351m/400 and there are quite a few hurdles and machined parts to make it work correctly... not afraid just want to do it right!
Old 07-30-2013, 03:04 PM   #4
79F150
Dictator/Tyrant
79F150's Avatar
I thought it was as simple as pulling a ZF out of a 460 truck and it would bolt right in? Not doubting you on the adapters because I have never don it. What issue are you having with the NP 435? I like mine a lot in my wheeler and I know Ogeechee has had good luck with his even on the road. I know its not a trans your going to speed shift gears with but not sure what you experiencing.
Old 07-30-2013, 03:06 PM   #5
79F150
Dictator/Tyrant
79F150's Avatar
Its very odd that someone put an M block into an EB. Usually every one uses a 302 or 351w. Then you would have all kinds of choices.
Old 07-30-2013, 03:37 PM   #6
InfoFord
InfoFord's Avatar
Bronco Info: Picador 4 door bronco EFI 460 E4OD electric shift 1356 Tcase 3.55 10.25 rear, 3.54 Dana 44 front
I don't think a E4OD would work in a EB
the ZF would be the way to go it is lighter and within a inch of the NP435 4x4 version
if your 435 is of the 2wd flavor with that dana20 it be pretty hard to get to that shorter length
you more then likely have a three finger clutch if it is really hard to push
go with a diaphragm version and you will enjoy pressing the clutch pedal
I thought you could get a OD unit for a Dana20 Tcase
Trent
NORTH COUNTRY SPECIALTIES
Picador (1979 4door Bronco)
79 Ford CrewCab 4X4(My Dually Project)
79 Ford Bronco and My Boat
InfoFord is offline   Reply With Quote
Old 07-30-2013, 04:03 PM   #7
landshark99
Too many broncos!
The bolt pattern is the same however there isn't enough spline engagement so you have to have a Custom pilot bushing machined A few have done it with no problems.. just a matter of getting it done right. There are a few other issues such as the flywheel and starter spacing etc..
I'm just not a fan of the NP435.. shifts like rocks, heavy HEAVY pedal, gears are really far apart and although with the 400 its probably less noticeable than a smaller engine.. it just adds onto the pile for me. Also I drive quite a bit on the highway.. I need that OD... but want to keep the granny if possible. I drive my bronco allot.. not just for wheeling so headed toward making it more "road friendly"
Tell me about it.. but its what i have and its fuel injected and its a torque monster.. less than 1800 miles on a total TM rebuild so I will live with it for now :)
I can't see an E40D being installed on a stock length early Bronco.. I dont want the heat issues either.. the 400 is enough!
Even if i throw on a different clutch or go hydraulic.. its still going to behave the same way.. I would rather solve most if not all the problems and be done with it :)
Same goes for the OD for the dana20.. just a bandaid, would rather just replace and checkoff most of my boxes, was just wondering if there were any other options for transmissions..
I will have to go take some more measurements, I know i can do it and will loose some rear drive shaft length, but I can make up an inch or so by moving the rear axle back and sticking with a TC case solution that will keep the length down...
Old 07-30-2013, 04:43 PM   #8
outlawbob
Bronco Info: 1978 & 1990
put in a hydraulic clutch
outlawbob is offline   Reply With Quote
Old 07-30-2013, 06:31 PM   #9
OX1
OX1's Avatar
What about an NV4500 using 400 bellhousing and adapter?
May be easier with the input spline adaptation??
http://www.ifsja.org/forums/vb/showthread.php?t=148194
http://www.460ford.com/forum/showthread.php?t=125229
Could even still use 205, but again may be too long.
http://forum.ih8mud.com/sale-parts/1...05-t-case.html
79 XLT, 400/C6/mog 404's/42 IROKS, 8.5" lift.
79 XLT, 400/C6/D60-D44 8 lug, 2" lift, 35 BFG AT
74 Bronc build, 408/C6/Black Box/205/406 mogs/43 SX stickies
OX1 is offline   Reply With Quote
Old 07-30-2013, 08:44 PM   #10
7LBRONCO
7LBRONCO's Avatar
Bronco Info: 78 XLT, 429 Thunderjet, C6, sh ackle flip in rear, 4" springs in front, 4.56 gears, f& r trac loc
It's a long shot, BUT......................
Back in the late 70s, early 80s, Ford used a version of the Mopar 883 4 speed, with 4th gear changed to an OD gear. If you can find one for a 4x4 application, there ya go.
7LBRONCO is online now   Reply With Quote
Old 07-30-2013, 09:55 PM   #11
InfoFord
InfoFord's Avatar
no matter what transmission you use the clutch is going to behave the same
3 finger requires extra effort to disengage regardless of transmission
diaphragm requires less effort to disengage regardless of transmission
since this is a conversion you may have your linkage in a bind causing even more effort to work the clutch
Trent
Old 07-31-2013, 01:28 AM   #12
landshark99
Too many broncos!
Well i have been reading about the NV4500, and it seems like a great transmission but also seems like a more expensive route to take. It looks like I can use the NP435 bellhousing with an Adapter plate.. plus a few other bits and pieces to get it to mate to a d20.. or suck it up and go with the 205..
Besides the expensive and the problem of finding one cheap.. I have found out the following about the NV4500
The bellhousing pattern is the same for the 400 and 460 but the 460 bellhousing is a 1/2 inch or so longer. If you put a NV4500 on a 400 bellousing with an Advance Adapter kit you will need to trim the input shaft and bearing retainer a little for a proper fit.
Requires special very expensive transmission fluid, I guess only available from a GM dealer.
5th gear nut likes to back off..
Lots of adapters and thats going to cost allot of money...
good news is, its short
I will keep researching. I have not really found a definitive article talking about an actual install onto a Ford 400 but only looked tonight.
I can pickup a big block ZF-5 for $89 right now.. haven't seen a Dodge NV4500 under $1700.. but haven't been looking too hard.
I will do some research and see what I can dig up.. i found a Clark 5 Speed for sale.. but wrong bolt pattern and don't think it has the .73 final drive.
I was going to on the NP435.. but will probably wait until I install the new transmission. No matter what I go with I will install a Hydraulic clutch with slave. The big bolt pattern ZF has an external setup.. I think the NV does too.
I think your right as the clutch rod that goes through the floor and attaches to the clutch lever on the frame is kind of hacked on (PO) .. not happy with the angles. Honestly I could live with the heavy pedal if i wasn't unhappy with the gear ratios, hard shifts and lack of OD.
I understand the NP435 is not a race car trans.. i know its tough, and like i said I can see the appeal for most trail rigs but its just not for me :)
plus this gives me another excuse to work on the Bronco!
Thanks for the ideas guys.. i will keep on researching, its part of the fun.
Old 07-31-2013, 06:19 AM   #13
InfoFord
InfoFord's Avatar
the NV will use what ever clutch linkage system that goes to the bell housing the transmission itself does not have any provisions for clutch linkage
Trent
Old 07-31-2013, 07:18 AM   #14
OX1
OX1's Avatar
@ $89, I think you already have your answer.
Old 07-31-2013, 10:45 AM   #15
landshark99
Too many broncos!
Awesome good to know, i will keep an eye out and keep reading up.
It's high on my priority list Not in a hurry on this and looking for a 400 block to mockup to so will take my time and make sure I have everything to do the swap...
Old 08-07-2013, 12:21 AM   #16
landshark99
Too many broncos!
Well I just secured a good ZF-5 that was behind a 460, comes with the Hydraulic clutch bits plus a few other things I need. Still looking for a 400 shortblock to mock it up to...
Old 08-11-2013, 07:53 AM   #17
r-clar
r-clar's Avatar
Bronco Info: 78 bronco
Well I see you already got your Trans but I've been researching an OD swap for my 78. I'm going with an AOD. A couple companies I've found that make a bellhousing for it. Cut the old one off the housing and bolt this one to the pump bolts. I'm leaning to this route. With an EB would probably be the best size for your rig.
Sent from AutoGuide.com App
r-clar is offline   Reply With Quote
Old 08-11-2013, 10:34 AM   #18
InfoFord
InfoFord's Avatar
AOD is a automatic transmission OP wants to stay Manual
Trent
Old 08-12-2013, 08:18 AM   #19
Ranger429
Moderator
Bronco Info: 79 Bronco, 47 Binder
Originally Posted by Jasonsteffan View Post
C-6 would be the most convenient exchange for an automatic but not on OD. ZF would be another choice and not a difficult exchange. E4OD would not be so much difficult. You would have to use a position at an individual setup.
What?
Ranger429 is offline   Reply With Quote
Old 08-12-2013, 09:32 AM   #20
landshark99
Too many broncos!
Originally Posted by Ranger429 View Post
What?
almost looks like his posts are automatic replies.. or maybe going through a language convertor.. or some kind of spammer...
  FSB Forums > Bronco Discussions > 1978-'79 Bronco Tech
You may not post replies
Forum Jump
