How hard is it to replace a head gasket? - FSB Forums
Thread Tools Display Modes
Old 10-22-2004, 10:25 PM   #1
rsm688
Mr. Asks Alot
rsm688's Avatar
Bronco Info: 78' Bronco
how hard is it to replace a head gasket cus there is 2 broncos for 800 by me and one has a good engine and tranny but bad transfer case and one has a good tranny and transfer case but the head gasket is blown so how difficult is it to do and what all do you have to do?
~spencer~
78 Bronco:
SUPERMOTOR PICS
SOLD....well traded, to a dealership for $7000
rsm688 is offline   Reply With Quote
Old 10-22-2004, 10:41 PM   #2
blueoval78
Building gold from crap
blueoval78's Avatar
what year
if it is carbed it is a bit easier, less stuff to remove to get the heads off the block, if its EFI, there is more stuff to remove.
than haveing the heads resurfaced will run ya a bit, as log as the heads or in good shape.
remember to use good gaskets and bolt it back together
someday............
blueoval78 is offline   Reply With Quote
Old 10-22-2004, 10:46 PM   #3
rsm688
Mr. Asks Alot
rsm688's Avatar
it is an 89 so i believe it is efi???? about how much does it cost to resurface the heads and are you talking about resurfacing wherer the gasket was...and what is a good head gasket?
~spencer~
78 Bronco:
SUPERMOTOR PICS
Old 10-22-2004, 11:07 PM   #4
MikE2
MikE2's Avatar
Ain't really that hard, if you know what you are doing.
The head gasket set, includes head intake exhaust and all the other gaskets needed, usually goes about $80. Getting the heads surfaced is usually around $40.
MikE2 is offline   Reply With Quote
Old 10-22-2004, 11:10 PM   #5
locopny
They call me "MR FLAT TIRE"
locopny's Avatar
Bronco Info: 90 swapping to7.3IDI, ZF5 & 1 tons. 66 5.0 & AOD
not too tough. even doing it slow, it can be done over a weekend.
I tend to use Felpro gaskets...always have been good for me. cost just slightly more than the 'house' brand at my local parts place.
I'll be damned, somebody around here knows how to search.
locopny is offline   Reply With Quote
Old 10-22-2004, 11:24 PM   #6
rsm688
Mr. Asks Alot
rsm688's Avatar
alright thanks i might get those two and sell one of them to someone and fic the other or either fix both and sell one...would a hayes manual give detailed instructions on how to do it? i have one for my 78 but would have to get one for those 89s...
~spencer~
78 Bronco:
SUPERMOTOR PICS
Old 10-23-2004, 01:34 AM   #7
MikE2
MikE2's Avatar
You shouldn't attempt that job without the manual. Also be sure you have, or can get, a torque wrench and a timing light before you start. Be sure to label all the wiring and vacuum lines so they go back in the same place. Match mark the distributor to the block with a sharpie so it goes back in close to the same position.Drain the coolant before removing the intake, that should keep most of it out of the engine. Also be sure you clean out the cylinders real good before rotating the engine with the heads off. A blow gun works good for that. I ruined a 360 from spinning the engine with carbon that I cleaned off another piston that got caught under the rings and scratched the cylinder wall. After you get it all back together, change the oil before starting it.
Old 10-23-2004, 10:33 AM   #8
matt
sold
matt's Avatar
You may want to change the head bolts. I am not sure if you have to but you should.
1989, 4" suspension, 2" body, 36" Super Swamper TSL radials, 4.11's, lincoln locker in front, 9" conversion in rear, roller cam 302 with edelbrock 600 performer carb, Ford Motorsport headers, 2 &1/4 duals with 1 chamber flowmasters, xm radio, and my "Cowboy Up" tag
super motors
Ain't nothin' to it but to do it!!!
Originally Posted by Ogeechee 4x4
what kind of problems are you having with your TTB?
matt is offline   Reply With Quote
Old 10-23-2004, 01:34 PM   #9
MikE2
MikE2's Avatar
no need to replace head bolts unless they are the torque-to-yeild style, wich they aren't. Just run a tap in the threads to clean them out so you get an accurate torquing
Old 10-23-2004, 01:39 PM   #10
seboh
The head bolts should be good for a 2nd reuse, but that's all I'd give them.
The bigger issue to me is exactly how they diagnosed the bad head gasket. Water in the oil/oil in the water? Low compression in adjacent cylinders? Or just a good guess?
I'd pull both heads and have them cleaned and magnafluxed. My experience with a "blown head gasket" in a 302 turned out to be a cracked head instead.
seboh is offline   Reply With Quote
Old 10-23-2004, 02:16 PM   #11
Big_Rig
Make SURE you have the torque sequence, they made it up for a reason. Also if you do use a steel shim gasket coat both sides in aluminum spray paint, let dry and torque down. Also just as seboh said, make sure you know that its the head gasket so it won't be a waste of time and money. Good luck!
Big_Rig is offline   Reply With Quote
You may not post replies
Forum Jump
