Slack in rear driveshaft - FSB Forums
Thread Tools Display Modes
Old 01-30-2014, 04:58 PM   #1
coxjam
Bronco Info: 1995 EB Bronco, 302, EFI, auto/overdrive, 135K mi, all stock truck
Mine is a 1995 5.0L, E4OD, 4x4 stock Bronco. There is a lot of slack in the rear driveshaft. The truck shifts very hard when it is running above 45 mph. When transmission mechanics look at the truck, they say it could be the transmission, the transfer case and the rear end. Of course, they have offered to rebuild all three. Is there a way to determine which it might be.
Thanks.
coxjam is offline   Reply With Quote
Old 01-30-2014, 04:59 PM   #2
jopes
gone fish'n
jopes's Avatar
Bronco Info: pile of parts
wrong forum. Please use the correct forums.
'01 F250, 444ci of straight piped oil burning fun. 4x4, 6 spd, GTP38R noise maker, Stage 2 injektorz. Lotsa fun!
Let's Go Fishing.
jopes is offline   Reply With Quote
Old 01-30-2014, 05:18 PM   #3
tr21triton
tr21triton's Avatar
Bronco Info: 1994 e.b. 5.8
have you checked your slip joint and u-joints ? with only 135k I don't think the rearend would be going out unless its had a hard life.
tr21triton is offline   Reply With Quote
Old 01-30-2014, 05:23 PM   #4
coxjam
too late to move it to the correct forum; sorry!!
Yes, u joints are fine.
Old 01-30-2014, 05:32 PM   #5
Direwolf95
Bronco Info: 1993 5.8L Lifted of course
Check for slack in the slip yoke, and is transmission slipping at all? check engine light on? thought of carrier bearing as well?
Direwolf95 is offline   Reply With Quote
Old 01-30-2014, 05:49 PM   #6
13.
13.'s Avatar
Bronco Info: '96 XLT, 5.8, E4OD, 4X4, HD Tow Package
Slip joint in shaft
Loose pinion nut
Can you get under it and see where there is play?
Don't ever go back to that shop if their answer starts with "It could be... we'll rebuild all 3". Unless you wanna pay them to throw parts at it.
'96 Bronco XLT 5.8, Auto, 4X4
'13 Explorer XLT 4x4
'13 CMax Energi
13. is offline   Reply With Quote
Old 01-30-2014, 05:50 PM   #7
coxjam
Havent checked the slip yokes, how do you do that? No the transmission doesnt slip at all. It actually shifts pretty good. What I hate about it is that at about 42 mph, if I try to accelerate rapidly, rather than have the transmission down shift immediately, it first feels like it hesitates, then downshifts very hard. When it then shifts to OD or 4th gear, it is a very hard shift, so much so passengers say it sounds like the transmission is about to fall out.
The driveshaft slack is such that if you reach up and grab the drive shaft, it turns significantly. I can't say how much now, but I can go under the truck and report back. Its just that when I took it to shop, the shop wanted to rebuild transmission, transfer case, and rear differential which seemed excessive to me.
THe truck now has 148K miles on it.
James
Old 01-30-2014, 05:52 PM   #8
coxjam
loose pinion nut....good thought. I'll check this weekend when somebody tells me how to check slip yoke too.
Old 01-30-2014, 05:54 PM   #9
13.
13.'s Avatar
Same Direwolf from ADV?
'13 CMax Energi
Old 01-30-2014, 06:10 PM   #10
tr21triton
tr21triton's Avatar
aint the slip yoke if you can turn it. has to be something in the rearend. even if the trans. or transfer case were shot u shouldn't be able to turn the shaft.
Old 01-30-2014, 10:14 PM   #11
13.
13.'s Avatar
When mine was loose I had vibration on deceleration at hwy speeds and when it got real loose, a clunk when taking off from a stop.
'13 CMax Energi
Old 01-31-2014, 08:37 AM   #12
tr21triton
tr21triton's Avatar
if it was the it's actually a slip joint it would be more of a fwd/aft movement unless the splines were fubar. its the joint between the 2 parts of the driveshaft under the rubber boot. you need to drop the driveshaft to inspect it. if you do a search on here there is a step by step thread on how to lube it.
Old 01-31-2014, 10:08 AM   #13
AFBronco235
AFBronco235's Avatar
Bronco Info: 91 Bronco w/ 5.0 L V8, Auto w/ E40D
When was the last time the transmission fluid was changed? It could be something as simple as gunk clogging up the lines in the transmission.
If you plan on changing the fluid, make sure you drop the pan so you can check for any debris or mud in there as well.
1991 Bronco w/ 5.0L V8, Auto w/ E40D trans, factory spare tire rack, factory limited slip diff, dual batteries, custom air intake, 8K lb. winch, tactical seat covers, drop down TV w/ CD/DVD player, 31's on stock suspension, roof baskets, new injectors,
To Do List: paint, new tires (33's), new rear bumper w/ tire rack & jerry can holder, hi-lift jack
My BKO build: Project Farmhand
AFBronco235 is offline   Reply With Quote
Old 01-31-2014, 10:29 AM   #14
tr21triton
tr21triton's Avatar
AFB I don't think that would let him be able to turn the driveshaft.
Old 01-31-2014, 10:31 AM   #15
AFBronco235
Maybe not, but finding metal shavings in the pan would go a long way towards figuring out what is going on.
Old 01-31-2014, 04:47 PM   #16
coxjam
its been about a year. the fluid was old looking but only fine fuzz on the pan magnet, no metal pieces at all. I then changed the valve body to one of those "Punisher Valve Bodies" as well as the soloniod pack in the transmission. Again, no metal parts in the fluid.
Old 01-31-2014, 04:49 PM   #17
coxjam
no forward aft motion at all. just a lot of play in the driveshaft with rotation. Ive pulled the cover on the differential, no missing teeth, no excess teeth marks or indentions however, I'm sure the original gears are still in place.
Old 01-31-2014, 04:50 PM   #18
coxjam
No vibrations, no real clunking when I start in motion from a dead stop.
Old 01-31-2014, 05:05 PM   #19
tr21triton
tr21triton's Avatar
did you remove the driveshaft ?
Old 01-31-2014, 05:17 PM   #20
tr21triton
tr21triton's Avatar
if it was the slip joint the front 1/2 and the back 1/2 of your driveshaft wouldn't move as one. if you can have someone turn the driveshaft while you look at the ring and pinion gear if you still have the diff cover off it should help you see where the slack is coming from. I would bet its something in the rearend. cant be the trans or transfer case unless it is two separate problems. even if your trans and t.c are in neutral the driveshaft wont move unless its on jacks. does this make sense ?
You may not post replies
Forum Jump
