Picture of fuse panel cover '86 Bronco needed - FSB Forums
Thread Tools Display Modes
Old 02-23-2005, 02:51 PM   #1
pinky1352
Bronco Info: '86 Eddie Bauer 302 5.0
Would anyone have a picture of the fuse panel cover? I don't have owner's maunal, and am trying to track down why dashboard lights don't work. Replaced headlight switch, dashboard lights were dim at best before, now they're not working at all. Top row of bulbs in dashboard work fine (turn signals, etc), but dash illumination does not.
Also have a few other minor electrical problems, so could really use the fuse diagram.
Thanks!
pinky1352 is offline   Reply With Quote
Old 02-23-2005, 09:09 PM   #2
DogFuzz
Tastes Like Chicken
DogFuzz's Avatar
Bronco Info: 1981 351M stock everything
Until you can pick up a manual autozone has the diagrams online. This is the link to the main repair page, navigate to the electrical section. http://www.autozone.com/servlet/UiBr...Parameters=002
Originally Posted by Bronkzilla
stop playing with the nipples and mount them
Originally Posted by Luv70sFords
\"Gee, if it wasnt for the shemale, I might be stuck doing this myself.."
DogFuzz is offline   Reply With Quote
Old 02-24-2005, 12:05 AM   #3
pinky1352
DogFuzz,
Thanks for the link. I should've beem more clear. I already have a Chilton repair manual for it (and the online link looks about the same), but it doesn't have a picture or diagram for the fuse box layout. These were supposedly in the car owners handbook, and that's what I don't have (along with the fuse panel cover)...
Old 02-24-2005, 12:58 AM   #4
Steve83
Banned
Steve83's Avatar
This is from my '83 - yours should be similar.
Old 03-15-2005, 07:16 PM   #5
pinky1352
Steve83,
Just wanted to say thanks for the diagram. It helped me figure out where to look for the problem. The driver's side front running light bulb actually separated from it's brass base when I tried to remove it, the side panel running light on passenger side was blown, AND one of the wires off the driver's side panel running light socket had a 1/4" piece of it's of sheathing stripped (maybe previous owner tried to tap into power there?).
Take your pick as to what kept blowing the fuse, as I changed/fixed it all at once. My bet's on the latter tho ! For the time being the fuse isn't blowing.
If it hadn't been snowing or so cold lately, I could've worked on it sooner.
Old 03-15-2005, 11:20 PM   #6
4Wheelin Rust bucket
4Wheelin Rust bucket's Avatar
Bronco Info: 1986 xlt 5.0 stock an 1983 xlt 92 mustang 302,6"lift,rear locker,ghetto fab roll cage,cheapo 35's
ive got the same prob but mine didnt even have connectors wired into the fuse block for the dash light fuse....i popped the fuse in an out it fell......i dunno really its too cold out to be crawling around fixing things on the truck an i can live with out dash lights lol
The only purple grape bronco with a neon green 9inch around
4Wheelin Rust bucket is offline   Reply With Quote
Old 03-15-2005, 11:32 PM   #7
Steve83
Banned
Steve83's Avatar
An '89 is VERY different. Look in the Haynes manual - it shows your fuse panel layout, and tells you which feeds what.
Old 03-15-2005, 11:45 PM   #8
EvlErn69
EvlErn69's Avatar
Bronco Info: 1984 Fullsize bronco...
its kinda hard to see but hope it helps...
80-86 style
96 style
84 ford bronco - 302 - c6
4 inch coming soon (andys old setup)
EvlErn69 is offline   Reply With Quote
You may not post replies
Forum Jump
