Sparks fly when I try to reconnect my battery! - FSB Forums
Thread Tools Display Modes
Old 08-14-2005, 05:43 PM   #1
INVALIDUSERNAME
INVALIDUSERNAME's Avatar
Bronco Info: '89 Eddie Bauer 5.8L Red & Tan
Question Sparks fly when I try to reconnect my battery!
Alrighty I was doing the 3G upgrade on my 1980 Bronco with a 5.8M 4sp manual with Granny 1st. I got one off of '94 Mustang and it was going great until I went to turn the ignition. The starter got stuck and it wouldnt turn over. I took out the key and the starter was still kicking, so I disconnected the negative cable. That stopped it. However When I went to reconnect the battery, all I got were sparks. What could I have done wrong to cause this and what damage could I have caused with my obvious stupidity? Please Help!! btw this is my DD.....
INVALIDUSERNAME is offline   Reply With Quote
Old 08-14-2005, 06:47 PM   #2
Weber
I ♥ TTB
Weber's Avatar
Bronco Info: 89 lifted a smidge
If the solenoid is stuck, its still trying to pull power, so it's gonna spark when you try to hook it up...
Originally Posted by Broncogirl89 View Post
Well try snatch next time.
-In Heaven you get love and peace.
In Hell you get to party with Pirates and Ninjas.
Weber is offline   Reply With Quote
Old 08-14-2005, 07:47 PM   #3
INVALIDUSERNAME
How do I Un-Stuck it? I think you are right
Old 08-14-2005, 07:49 PM   #4
hunter234
hunter234's Avatar
Bronco Info: '86 w\ 6'' lift, mass air converted 5.0L, AOD, and 4.10 LS front and minispool rear diffs
Tap it with a hammer. If that doesn't work than replace it.
1986 w/5.0L with ford racing mass air conversion, AOD, 6" lift, 35x12.50x15 Procomp Xterrains, JBG extreme coils up front, LS front and minispool rear, Flexalite dual electric engine fans, heavy duty tranny cooler w/ 950cfm fan, Warn winch up front, saginaw powersteering pump, and serpentine conversion using brackets from 88 E150.
hunter234 is offline   Reply With Quote
Old 08-14-2005, 08:01 PM   #5
INVALIDUSERNAME
So i tap it with a hammer, then I try to reconnect it, If no sparks, Im good to go?
I know that its hard to diagnose over the web, but I guess I was just hoping that I was not the only one to have made this mistake.
Old 08-14-2005, 08:57 PM   #6
DogFuzz
Tastes Like Chicken
DogFuzz's Avatar
Bronco Info: 1981 351M stock everything
How bad is it sparking? If it's just a little, that's kinda normal if you have an aftermarket radio or anything else that has continuous power.
If they're worse than that, the solenoid already mentioned is likely the case.
Originally Posted by Bronkzilla
stop playing with the nipples and mount them
Originally Posted by Luv70sFords
\"Gee, if it wasnt for the shemale, I might be stuck doing this myself.."
DogFuzz is offline   Reply With Quote
Old 08-14-2005, 11:57 PM   #7
Dave's Bronc 90
Some assembly required!
Dave's Bronc 90's Avatar
Bronco Info: 90 EB, 351W, E40D, D60 SAS, 10.25 rear, ARB's front & back, indellible Cheerwine stain in carpet
I'd say if tapping it with a hammer frees it up I would trust it just long enough to drive to NAPA and buy another one. If it stuck once it can stick again, and that can burn up your starter, or worse. Assuming that you have everything wired corrrectly, definitely replace it.
Dave's Bronc 90 is offline   Reply With Quote
Old 08-15-2005, 02:29 AM   #8
mrains30
mrains30's Avatar
Bronco Info: 87 XLT 351W,C6,MANUAL 1356,33"BFG's
Replace the solenoid and if it happens again. Then you probably have a grounding issue or short.
mrains30 is offline   Reply With Quote
Old 08-15-2005, 10:07 AM   #9
INVALIDUSERNAME
I should've mentioned that it was starting up great before the upgrade, The sparks are BIG i mean i little piece of the terminal of the top got burned off...
To he point that I am almost afraid of reconnecting, Not for safety, but for effing up something else. I must have connected something wrong to cause this.
It should be right now but I havent gotton a chance to go tap the starter yet because we had some serious thunderstorms last night.
I disconnected the radio, I dont even have a dome light in my truck, my rear window actually works, I know its the starter solenoid causing this, I think I'll just buy a solenoid and replace it. Shucks. I would have someone do it but I bought this truck knowing I was gonna get my hands dirty, plus I'm broke!
Anyway Off topic, Ill tap it tonight and hope that works....
Old 08-15-2005, 03:11 PM   #10
collinsperformance
I got tools-i can fix it
Bronco Info: 1983 Full Size Bronco
check you wiring you might have miss connected something and if all is good tap the solinod and you should be good to go..mike
collinsperformance is offline   Reply With Quote
Old 08-15-2005, 03:20 PM   #11
BigBroncoXLT
BigBroncoXLT's Avatar
Bronco Info: 1985 XLT
Jeff
The Alpha Male Mobiles
88 Bronco XLT 4" superlift, D44 SAS, 8.8 rear, 33.12.50 BFG MT's 302/AOD/208 SOLD
http://www.supermotors.org/vehicles/...il.php?id=4849
85 Bronco XLT 2.5" rough country lift 351W/C6/208 9" rear TTB up front.
http://www.supermotors.org/vehicles/...il.php?id=9181
Originally Posted by MANNY
I love when i can play with my stuff.
BigBroncoXLT is offline   Reply With Quote
Old 08-15-2005, 04:55 PM   #12
GHOSTRIDER
Old Man with an Old Truck
GHOSTRIDER's Avatar
Bronco Info: 90 XLT/351W, 6" LFT SAS, 9" 35" TIRES , 4.56, LOCKED, REALLY COOL SNORKEL, OTHER COSTLY CHIT
Same thing kind of happened to mine, replaced the solenoid with one from the Zone, jproblem went away
Riding on in the mist of morning, no one dares stand in my way...possessed by some distant calling, riding on through night and day.
PETE HALEY
GHOSTRIDER is offline   Reply With Quote
Old 08-15-2005, 05:35 PM   #13
INVALIDUSERNAME
100% correct, tapped the solenoid, Sparks went away.
Now I know I connected one of the wires incorrectly, The only one that I have an issue with on the swap to 3g is the one from the plug labeled "I" color green. The alternator is from an 94 mustang. Before I eff it up, Remembering that it is a 1980 with a 5.8m Carbed, duh, What cable should I connect it to? THere is a green cable with a red stripe on it coming from the solenoid, is that it?
Old 08-15-2005, 06:02 PM   #14
INVALIDUSERNAME
I appreciate All the help from you guys but before you flame me....I actually have two green/red wires in that area which one do I pick? One is much thicker than the other. but I cannot see where it runs to.
This thread seems to have run dry I started a new one here http://www.fullsizebronco.com/forum/...ad.php?t=47501
Old 08-17-2005, 07:59 PM   #15
INVALIDUSERNAME
She is alive! for whatever reason my Hot when in run key is Blue/Orange! She is making 13.98 volts and I can nowturn on my wipers and my headlights and close my rear window at the same time!
Old 08-17-2005, 07:59 PM   #16
INVALIDUSERNAME
PS thanks to all for your help!!!
You may not post replies
Forum Jump
