94 bronco stereo wiring diagram - FSB Forums
Thread Tools Display Modes
Old 09-10-2005, 09:09 PM   #1
gakr2000
gakr2000's Avatar
Bronco Info: 94 Bronco 5.8 EB
Angry 94 bronco stereo wiring diagram
Can anybody help me sort out this mess. Just bought a 94 EB with no stereo and an trying to install one. Problem is i have a big hole and two connectors with no radio? If anybody can clearify the color codes for the speakers etc. i would greatly appreciate it. Thanks in advance.
gakr2000 is offline   Reply With Quote
Old 09-10-2005, 09:51 PM   #2
bronkx1
bronkx1's Avatar
Bronco Info: 92 EB 302ci
Dont cut off the plugs.Go to best buy or simular store and ask for a wire harness for your truck.It will connect to the plugs in the dash and all the wires will be marked with what connects to what.Cost under $20
WU Tang Financial
CREAM
"Cash Rulez Everything Around Me"
Under the CREAM methodology,
individuals not only invest in stocks, bonds, commodities,
etc... but also put money into guns, drugs, and ho's. "
bronkx1 is offline   Reply With Quote
Old 09-10-2005, 09:54 PM   #3
Rick3373
Southeast Utah Native
Rick3373's Avatar
Bronco Info: 89 XLT
Definitely get the kit to use the existing connectors.
LIFE'S SHORT, PLAY DIRTY!
89 Bronco XLT, 351, C-6.
Understand how your use affects the land.
Adopt minimum impact practices.
Share in the costs of services, education & maintenance.
Rick3373 is offline   Reply With Quote
Old 09-11-2005, 12:38 AM   #4
MikE2
MikE2's Avatar
+3
dont **** up the factory plugs, get the plug ins and do all the connections on that
MikE2 is offline   Reply With Quote
Old 09-11-2005, 12:47 AM   #5
Steve83
Banned
Steve83's Avatar
I'll fourth that. You'll be much better off splicing on an aftermarket connector than the factory wires.
BTW MikE2
Your avatar is some animal's muzzle, right? Maybe a kangaroo...
Old 09-11-2005, 12:50 AM   #6
MikE2
MikE2's Avatar
lean your head all the way to the right and its a lot clearer
Old 09-11-2005, 01:18 AM   #7
Steve83
Banned
Steve83's Avatar
Yeah, I got that, but what animal is it? It almost looks like a Taun-taun...
Old 09-11-2005, 01:37 AM   #8
gakr2000
gakr2000's Avatar
Holy Sh** i guess i m going to go with the aftermarket plugin. I knew it was going to be easier i guess i was just being lazy. Thanks for bringing me back to reality
Old 09-11-2005, 07:02 AM   #9
imlikeojnow
green ones make me horny
imlikeojnow's Avatar
Bronco Info: 1994 w/ built 302, E4OD, 33in tires, custom exhaust, upgraded ign. running like a raped ape
at least you got to go with an aftermarket one. Damn when i got my truck all i had was a bunch of wires and no harness, well harness was there had one wire going to it. I rewired everything took like 5 hours with the dash off and all, big pita. Good luck
Originally Posted by SigEpBlue View Post
No, I don't have this problem. Money grows on trees here in Michigan, and my Bronco gets 45 mpg. It emits sunshine and a light berry scent, and it never needs service or parts.
imlikeojnow is offline   Reply With Quote
Old 09-11-2005, 11:21 AM   #10
gakr2000
gakr2000's Avatar
Ok i am going to give the color code for the sake of people using the search (Which i use just about everyday). I will go get the connector from Bestbuy but for those who have the connectors ripped out this could be for you. I am not sure of the years this will cover i just know it works for my 94 Eb.
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Red or Black
Illumination Blue/Red
Dimmer N/A
antenna Trigger N/A
antenna Right Front
Front Speakers 5X7
Left Front+ Orange Green
Left Front- Black/White
Right Front+ White/Green
Right Front- Black/White
Rear Speakers 6X9 Side Panels
Left Rear+ Pink/Green
Left Rear- Pink/Blue
Right Rear+ Pink/Blue
Right Rear- Green/Orange
Got this info from the12V.com
Dont really understand how some of the wires are the same color like the left rear- and right rear+ but i havent really looked at the connector though plus nothing an ohm meter couldnt solve. I am still getting the connector from bestbuy though. Just thought i would share because i couldnt find anything in the search about it. Thanks for all the help guys. Now time to go to the store and start the fun.
Old 09-11-2005, 11:29 AM   #11
gakr2000
gakr2000's Avatar
done
Old 09-12-2005, 05:52 PM   #12
gakr2000
gakr2000's Avatar
Ok i am a retard Just got back from best buy with my connectors for the stereo. Anyway, here i have been soooo worried about what color was what trying to ghettofy the install and it ended up taking me more time to splice the wires from the connector then it did to install the damn radio Thanks for the enlightment guys , once again this site rocks
You may not post replies
Forum Jump
