Go Back   FSB Forums > Bronco Discussions > 1980-'96 Bronco Tech
Thread Tools Display Modes
Old 11-10-2005, 03:28 AM   #1
Herbie Hancock
is it just me or do summit racing shorty headers suck?
I had purchased a pair of Summit Racing shorty headers for my Bronco (302), mostly because my manifold was leaking anyway, plus I wanted it to be louder. Anyway, myself and a Ford ASE certified mechanic put them on last Saturday and we cannot seem to get them to fit quite right. No matter how we tighten here-and-there it always seems that there is a leak somewhere. We went over it again last night and it sounded a little bit better, but then I was driving to class today and all of the sudden it started that ticking sound much worse. It was all ready ticking but it got MUCH worse, and is bordering on totally embarrassing. It sounds terrible... You know when the clicking is more loud than the exhaust coming out of the tips it's bad.
Has anyone else had this experience with Summit headers or other types, and what did you do? I know that these are supposed to "bolt on", and I know that term is usually b.s. but this is rediculous. I am driving it to work tomorrow (I work at a Ford dealership) and I want this to be the last time I drive it with this rediculous racket because I hate to be reduced to driving my Fiance's Mitsubishi Eclipse, which is almost as embarrassing as driving a truck with 1000 decibels of exhaust leak.
Herbie Hancock is offline   Reply With Quote
Old 11-10-2005, 05:54 AM   #2
NDIXIE
NDIXIE's Avatar
Bronco Info: '95 Bronco
Why don't you call Summit and tell them. Maybe you have a set that was done on a Friday and just aren't quite to spec, maybe they will replace them.
I put a set on mine about 3 months ago and I have not had one problem with mine.
NDIXIE is offline   Reply With Quote
Old 11-10-2005, 08:05 AM   #3
89_Bronco_Magnum
Bronco Info: 89 Bronco Magnum
Just double gasket them. I have had to do that with brand name headers. Lots of times they come a little warped after welding. Give it a shot, I have had good luck with it.
Real Trucks are Built NOT Bought
89_Bronco_Magnum is offline   Reply With Quote
Old 11-10-2005, 08:30 AM   #4
jimsl78
jimsl78's Avatar
Bronco Info: 1996 XLT 5.0
I used The "Summit" Headers on my 302, and had to file off some weld slag to make them flush against a piece of glass. Also used MR Gasket "ultra seal" gaskets.
(other than the PITA instalation.......no problems here)
jimsl78 is offline   Reply With Quote
Old 11-10-2005, 08:43 AM   #5
ScottMoore
ScottMoore's Avatar
Bronco Info: 1996 5.8L, 6" CII Lift, 3" Body, 36x14.5x15 Rad. TSL's, 4.56 & Aus Lock, Elect. Fan, & other stuff
call summit and tell them, they have great customer service. summit has another company make them for them, i could be wrong but i think it is flowtech. personally, if they leak bad enough to have to use two gaskets i would send them back. if they are leaking i would not drive the truck to much because it can mess up the exhaust valve.
-Scott Moore
Arguing online is like winning the special olympics, even if you win your still retarted.
Web Site: http://www.supermotors.net/vehicles/registry/15436
ScottMoore is offline   Reply With Quote
Old 11-10-2005, 08:45 AM   #6
Kenny's 94
Kenny's 94's Avatar
Bronco Info: 5.0 w/ e40d,4:10's,AR-23's,BFG KO's 33x12.50,K&N,2 1/2" lift,headers,Bassani Y pipe,BBK 56mm.
I had a pair and was never able to stop the leaks, finally I made them replace the headers with another brand. Your right they suck. By the way are they leaking at the Y pipe like mine were?
Kenny's 94 is offline   Reply With Quote
Old 11-10-2005, 08:55 AM   #7
1clean5.8
1clean5.8's Avatar
Bronco Info: 1991 Eddie Bauer 5.8. Flowmaster exuast, SAS 35 mickeys 7" lift, 4.88s locked
I had JBAs on my mustang they leaked so I took them off and replaced the gaskets with a thicker gasket then tightend from the inside out. it got rid of the problem.
Originally Posted by MYXD40 View Post
okay so scrap the 1 ton and throw in a D60?
1clean5.8 is offline   Reply With Quote
Old 11-10-2005, 09:28 AM   #8
kemicalburns
Never Done
kemicalburns's Avatar
i to had bad luck with the summit brand headers. i even bought expensive felpro gaskets and that didnt help either. the summit headers are manufacturers seconds already from either flowtech or pacesetter. if you want leak free headers you need to spend the extra doe for some good ones like gibson,jba, edelbrock or bassini.
headers should always be tightened down from the center out. and good gaskets should always be used.
94 XLT 5.8/E4OD Trans-go stage II
6" Stage II ProComp,35x12.50BFG/MT
4.88 f (aussie) / r (open) / Custom Sliders
JBA headers,Custom Y pipe hi flow cat & Full 3"
http://www.supermotors.net/vehicles/registry/17069
kemicalburns is offline   Reply With Quote
Old 11-10-2005, 10:15 AM   #9
lightnin
Excessively Engineered
lightnin's Avatar
Bronco Info: 83 XLT, 351W, C6, NP205, Soon a D60 Welded, Power lok'd D70 Rear, 4.10's, 10" lift, 35" tires
Didn't you sign the Declaration of Independance. lol "ha ha John Hancock, It was Herbie Hankcock"
Online 4x4 game. Click to sign up.
http://www.4x4country.net/register.php?REF=5016
lightnin is offline   Reply With Quote
Old 11-10-2005, 11:01 AM   #10
Injected
Injected's Avatar
Bronco Info: '88 408ci/AOD................. Pretty Paint Is For Parkin' Lots - Be Original, Be Rusty!
Same problem I had with mine on my 351, I had to double gasket them to get rid of the leaks.
She's just one more bad habit that I'm too blind to see......
Injected is offline   Reply With Quote
Old 11-10-2005, 11:06 AM   #11
85f150
Stuck like a MoFo
85f150's Avatar
Bronco Info: Srry no Bronk only a F150
Its a hedder thing. There is that new deadsoft copper gasket i have heard great reviews about. On my inline i am just using the heddman paper gasket but the num 1 cyl leaks slightly but i don't care.
Truck Porn mooseracing.org
1985 F150 300 cubic inches of raw tq
79 XS 1100 SF
79 Firebird & T/A
64/65 Studebakers
85f150 is offline   Reply With Quote
Old 11-10-2005, 12:24 PM   #12
badpony93
badpony93's Avatar
on my 351 i bought gibson shorties and had to take the inner fender wells out which gave me much better access and i went through and made sure every bolt was tight. and then i noticed the egr tube had a nice crack in it, so that had to be replaced now it sounds great, no leaks at all.
badpony93 is offline   Reply With Quote
Old 11-11-2005, 12:03 AM   #13
raynman
raynman's Avatar
i had nothing but problems w/ my summit/pacesetter shorties. i contacted summit and they offered to bring them back, sell them as used and give me a piece of the action. they did not seem to concerned that the pair they shipped me had a pair of o2 bungs that my, otherwise stock, 95 had no use for and i had to plug w/ a pair of sparkplugs that i broke off the insulators and screwed in.
i have since put my stock manifolds back on and almost have them sealed up to by bassani pipe. summit had a deal that threw in a free set of header bolts (the kind that lock) w/ the purchase of a set of their branded headers. the bolts suck. if you can't get on them 100% they round off like the potmetal pos's that they are and the allen head holes are for crap.
raynman is offline   Reply With Quote
Old 11-11-2005, 12:54 AM   #14
Kenny's 94
Kenny's 94's Avatar
After sending back my Pace Setter headers, I had Summit send me a set of Hedman headers, thats been over 2yrs. ago. They bolted up with no problems, in 2yrs. I've had no header leaks and the upgrade cost me $20.00
I can't believe Summit is putting their name on this junk.
Old 11-11-2005, 02:36 PM   #15
93BIGBLACKBRONCO
93BIGBLACKBRONCO's Avatar
Bronco Info: 93 xlt 5.8 Bassani headers and 3" Bassani exhaust. 4" Tuff Countrylift 33/12.50/15 BFG A/T's
You get what you pay for.
93BIGBLACKBRONCO is online now   Reply With Quote
Old 11-11-2005, 03:23 PM   #16
B-man
B-man's Avatar
Bronco Info: Tore down, Beat down, just F*CKED.
Exactly.. YOu get what you pay for. I got Summits on my rig.. No problems with them.. My ticking only came when the header bolts came loose.. Fixed that up. No probs.. I had a set of Hedman's on there before and they lasted a year. These are going two years I believe? Maybe one. can't remember.. But, still seem to be going strong.. The Ford stock Y-pipe design for the exhuast sucks on any header from what I was told.. Guess, some got lucky with the Summit's and some didn't. Hope you get your situation all figured out..
88'/90'/91 XLT Bronco,393W w/Pacesetter headers,35X12.5 BFG KM2 M/T's,7inch Rough Country Lift,D44 Locker , Locked 8.8, 4:11 gears E4OD
Originally Posted by marv
I just dunno. If you want to resign from the human race, where do you send the paperwork?
B-man is offline   Reply With Quote
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
