can you add a light to a snowblower? - FSB Forums
Thread Tools Display Modes
Old 12-02-2005, 08:47 AM   #1
blueoval78
Building gold from crap
blueoval78's Avatar
i just bought a 9 1/2 hp brigss snowblower, but it donest have a light on it, i was thinking it might be a good idea to have one, maybe, i dont know, this may be the first year that i actually do any kind of snow removal, in the past,it was drive over the driveway lots, for the majority of the winter, our drive way was 2 feet higher than the street
but seriosly is there a way to hook up like a simple light?
someday............
blueoval78 is offline   Reply With Quote
Old 12-02-2005, 10:25 AM   #2
Broncobob
In The Matrix
Broncobob's Avatar
Bronco Info: 1994 Bronco
ducktape and a flashlight?
Broncobob is offline   Reply With Quote
Old 12-02-2005, 10:33 AM   #3
blueoval78
blueoval78's Avatar
thought about the red neck aproach, but, its too new for that, if it was older, id be all over that one
someday............
Old 12-02-2005, 02:22 PM   #4
hmthesing
hmthesing's Avatar
Bronco Info: '89 EB 302 C6
Should be able to. My dad's has a light on it. Makes it really nice to do the end of the driveway where it's really dark. Maybe try a Google search on it, should find something.
hmthesing is offline   Reply With Quote
Old 12-02-2005, 03:38 PM   #5
Bronco85
Screw the Jeep Thing
Bronco85's Avatar
You don't really need a light on it. My parents just got a snowblower with a light last winter. It's nice but I don't notice any really advantage to it.
you should be able to go to the Maker of your SnowBlower and get the Light kit from them. And a Battery. Or go to walmart and buy a small battery and a 12Volt Offroad light, and bolt it on somewhere.
CLICK ON THE BANNER MY 85 BRONCO (RIP old friend)
'84 Bronco (SOLD) - I6 Motor, ALL STOCK
'93 Bronco Eddie Baurer (SOLD) - 302, E40D, 1356, 6" Lift, 35x12.5 BFG AT's
'94 Bronco XLT - Build to play hard
Bronco85 is offline   Reply With Quote
Old 12-02-2005, 04:20 PM   #6
hmthesing
hmthesing's Avatar
What do you need a battery for? It should be able to run directly off the engine.
EDIT: Check this thread out, has some good info.
http://www.abbysguide.com/ope/discus...17757-0-1.html
Old 12-02-2005, 04:41 PM   #7
blueoval78
blueoval78's Avatar
ya i figured i should be able to run it right off the engine, ill have to look into it some more,
someday............
Old 12-02-2005, 04:57 PM   #8
djlarryp
djlarryp's Avatar
Bronco Info: 1978 xlt ranger
old parts off of a riding lawnmower maybe? i don't really know, someone already beat me to the ductape and flashlight.
djlarryp is offline   Reply With Quote
Old 12-02-2005, 05:14 PM   #9
Oldyeller
ASSSSS-HOOOOOLE
Oldyeller's Avatar
Bronco Info: Broncos Are Gay.
hmmm, maybe like one of those battery powered bicycle lights? y'know the sleek looking ones that go on the handlebars? Maybe fab up a mount or mount it to the handle?
Originally Posted by 4x4bronco925 View Post
Oldyeller seems to be in-human. He never makes mistakes and is always right. Enough said.
Originally Posted by 302 & 3-inline6's
my rear is getting real sloppy
Oldyeller is offline   Reply With Quote
Old 12-02-2005, 05:29 PM   #10
Broncobob
In The Matrix
Broncobob's Avatar
*clears throat* Pardon me, I meant to say zip ties and a flash light.
Old 12-02-2005, 05:50 PM   #11
Bronco85
Bronco85's Avatar
I figured IT needed one. I've never delt with them other then bought that way.
Old 12-02-2005, 05:57 PM   #12
hmthesing
hmthesing's Avatar
I've never seen one with a battery, that's why I was asking.
Old 12-02-2005, 07:55 PM   #13
broncoguy
broncoguy's Avatar
Check by the flywheel shroud if you see a single wire hanging out there that isn't attached to anything thats for the light. The light runs on AC current and there is no battery required. Most snowblower motors come with a lighting coil now, but if yours didn't then just go down with the model and serial number of the motor not the snowblower and buy the correct lighting coil and light and your done.
I worked for the Sears service department for years and they sourced all the motors the same, that is a 8hp blower with a light, used the exact same motor as one with out. We also used to offer a light kit for those that didn't come with one.
Hope this helps..
broncoguy is offline   Reply With Quote
Old 12-03-2005, 10:02 AM   #14
81Bronk36
FSB warrior
81Bronk36's Avatar
Bronco Info: was an 81, GT-40P, NP-435, NP208, 36s, 0" lift
AC current??? what power rating does a small engine put out on its own like that??
1BadBronco
was a81 Bronco Custom. Sold See my superford link for how I built her!
NOW83 F-250 6.9L IDI, built C-6 1345 D44HD and D70 rear with 3.55 gears. Sag pump, hydroboost, 3G, SD vacuum pump, bumpers, 34" swampers
81Bronk36 is offline   Reply With Quote
Old 12-03-2005, 12:53 PM   #15
blueoval78
blueoval78's Avatar
Hope this helps..
that does, because i was wondering what the hell that wire was for
someday............
  FSB Forums > Other Forums > Anything Else
You may not post replies
Forum Jump
