Towing Question..... - FSB Forums
Thread Tools Display Modes
Old 12-11-2005, 02:40 AM   #1
Bronco Rob
Zombie Hunter
Bronco Rob's Avatar
Bronco Info: 1993 Eddie Bauer, 351, 5.8 liter V8, somebody come help me put all this junk i just bought on!!
It looks like i am going to be picking up a donor rig. It is a fullsize 92 Bronco. It's about 9 hours away from me.(Ohio to CT)
Here was my plan. Go rent a trailer dolley from U-haul, that is real close to the spot where i am picking it up. Hook up the non-running donor to the car dolley and take my time getting back.
Question 1:
Can a fullsize Bronco pull a fullsize Bronco for that type of haul......9 hours?
Question 2:
With these vehicles being a touch on the heavy side, will the u-haul dolley handle the weight?
Question 3:
Anyone got any better ideas?
Thanks.
Some more info:
Tow Dolly
The most economical way to tow your vehicle. U-Haul is the only national company that rents towing equipment independent of truck rentals.
More on U-Haul vehicle trailers Reserve now
Capacity
Max load: 3,450 lbs. when towing a front-wheel drive vehicle, 3,900 lbs. when towing a rear-wheel drve vehicle
Empty weight: 650 lbs.
Features
Ratchet-operated tire straps
Vehicle security chains
Advisements
Your towing vehicle:
Must be equipped with a hard top if it is an SUV. U-Haul does not allow any type of sport-utility vehicle not equipped with a hard top to tow U-Haul equipment.
Must weigh at least 3,500 lbs. (curb weight), and at least 750 lbs. more than the vehicle being towed
Must have Class 2 tow hitch (3,500 lbs. minimum weight-carrying rating)
Must have 1-7/8", 2" or 2-1/8" hitch ball (3,500 lbs. minimum)
Must not exceed maximum allowable hitch ball height 25"
Must have external mirrors on both sides
Must have fully operational lighting
Tow dolly lighting must be operational at all times, day and night, loaded or unloaded
Maximum recommended speed is 45 MPH
The vehicle being towed:
Must not weigh in excess of 3,450 lbs. if it is front-wheel drive, and 3,900 lbs. if it is rear-wheel drive
Must have a maximum outside-to-outside tire width of 72"
Note: outside tire width over 69.5" must use a swivel-platform U-Haul Tow Dolly.
Must not exceed a body width (at the doors) of 75"
Note: body widths over 72" must use late-model U-Haul Tow Dolly (identifiable by silver galvanized color)
Must have a maximum wheelbase (distance from front axle to rear axle, usually posted on the driver's side door jamb) of 133 inches.
Low-hanging equipment on the vehicle being towed such as spoilers, air dams, ground effects, etc., may be damaged by contact with the tow dolly during loading and unloading. Make sure there is enough clearance for these items.
Tow lights (tail/stop/turn) required at rear of vehicle being towed
Bronco Rob is offline   Reply With Quote
Old 12-11-2005, 04:37 AM   #2
locopny
They call me "MR FLAT TIRE"
locopny's Avatar
Bronco Info: Broke down, getting changed to a diesel one ton
no, Broncos cant tow anything.
ok enough smart ass comments....
my experience is that tow dollys tend to be on the lightweight side (broke my last one towing a Toy 4x PU)...
any reason you arent renting/borrowing a trailer? this tow photo'd here was a 5 hour tow from Vegas back to So.CA
I'll be damned, somebody around here knows how to search.
locopny is offline   Reply With Quote
Old 12-11-2005, 04:41 AM   #3
86eddieb
86eddieb's Avatar
Bronco Info: 1994 Eddie Bauer, 1986 Eddie Bauer, 1986 XLT
I've towed a lot of weight with mine, just take your time, the truck should handle it.
Originally Posted by Magnumpi
I kinda want to whack it off regardless
Originally Posted by ToddACimer
I'd stick it back in there, no sense in having it flop all around.
94 Eddie Bauer green / tan ,351 , AODE , 6" superlift suspension lift , grill guard coated in spray bedliner , 35x12.50x15 BFG Mud Terrains, diamond plate gap guards, 3" body lift..86 XLT to be restored stock, 86 Eddie Bauer to be parted out
86eddieb is offline   Reply With Quote
Old 12-11-2005, 05:02 AM   #4
Rick3373
Southeast Utah Native
Rick3373's Avatar
Bronco Info: 89 XLT
Question 1: YES
Question 2: YES, I towed my Bronco on a U-Haul tow dolly from Grand Junction, CO to Denver, CO. But I had to fib a little about what I was towing and I had to let air out of the front tires on the Bronco & then reinflate them to make the straps work.
Question 3: Not necessarily, but most U-Haul rental places will not rent the dolly to you to tow a Bronco.
Personally I don't feel that a dolly is any kind of problem in towing a Bronco, but there are those on this site who will say otherwise.
LIFE'S SHORT, PLAY DIRTY!
89 Bronco XLT, 351, C-6.
Understand how your use affects the land.
Adopt minimum impact practices.
Share in the costs of services, education & maintenance.
Rick3373 is offline   Reply With Quote
Old 12-11-2005, 10:29 AM   #5
adrianspeeder
USAF C-17 Avionics
adrianspeeder's Avatar
Bronco Info: '94, '92, '88, and '84 Broncos
Yeah it will work until you get into an emergency situation. Worth the risk of your rig or life? Get a flat deck trailer.
Adrianspeeder
adrianspeeder is online now   Reply With Quote
Old 12-11-2005, 11:28 AM   #6
Bronco Rob
Zombie Hunter
Bronco Rob's Avatar
None of my friends really run 4x4's. They run street cars. a FSB wouldn't fit on their trailer.
Any suggestions, other than U-haul where i can rent a trailer?
Old 12-11-2005, 11:39 AM   #7
fastpat
Fast member
fastpat's Avatar
Bronco Info: 96 XL, M5OD, 6 in. lift, JBA headers, MSD Offroad, full duals, 3.55's
My opinion, s**tcan the idea of the tow dolly, they're devices of satan.
Uhaul has a very nice car trailer that rents for about $50.00 per day local, more for a one way trip. It would depend on how much gas you'd burn towing an empty trailer as opposed to the extra cost to rent one for a one way trip.
Pat
fastpat is offline   Reply With Quote
Old 12-11-2005, 11:58 AM   #8
Larston
Larston's Avatar
Bronco Info: Broncoless, but I got a 1987 F250 to make up for it
A car hauler is a car hauler, why wouldn't your Bronco fit?
My Superford Site
Larston is offline   Reply With Quote
Old 12-11-2005, 12:56 PM   #9
Bronco Rob
Zombie Hunter
Bronco Rob's Avatar
The mental image i have of it right now, i can't picture a FSB with 31's fitting on it. I am going to call him tonight to see it will in fact hold it.
Old 12-11-2005, 01:32 PM   #10
Steve83
Steve83's Avatar
A tow dolly is cheaper & more stable than a trailer, but less maneuverable. Weight isn't a problem - but drop the rear d'shaft & put the front wheels on the dolly. One-way rental is MUCH more expensive than local, and they DON'T need to know the truth about what you're towing or where it is. Just rent it in your hometown for a day or 2 & tell them you're moving a VW Beetle.
31s are ~1/2" taller & wider than stock. But the rims don't change position, so if the tires rub the sides of the trailer, air them down to ~15psi & let 'em rub.
Old 12-11-2005, 02:01 PM   #11
rhetor
Bronco Info: 1995 F-150 4x4 4.9L
Thats really unsafe man.
you will be towing almost 5000lbs with no trailer brakes.
The bronco won't have a problem pulling the weight, but the steering is going to be real terrible, and the braking will be so bad you would probably be on the verge of criminal negligence if you were to rear end someone.
I know when you ask people on the internet you get way too exaggerated results, but to put it this way- i would tow a bronco on a tow dolly around town, but never on the highway more than a couple miles.
95 F150 - 300 - m5od - 4.10 LS rear, aussie front
33x10.5 BFG m/t
2" lift in front, about 3" in rear or so ish + or -
cleaned up head, torque cam, 2.5" exh, 19lb injectors
rhetor is offline   Reply With Quote
Old 12-11-2005, 04:21 PM   #12
Steve83
Steve83's Avatar
The distance doesn't matter - statistically though, you're much MORE likely to wreck on a short drive (near home). Also, braking would be worse on a short trip since you'd be using them more often than on a long interstate trip.
I've towed over 10,000 lbs with no trailer brakes for over 100 mi., and as long as you drive like you're towing 10,000 lbs, you can still be safe. Just increase the distance between you & the car in front, and look twice as far ahead as you normally do so you don't get surprised.
If you drive like you're NOT towing, you'll get in trouble fast.
Old 12-11-2005, 04:32 PM   #13
Bronco Rob
Zombie Hunter
Bronco Rob's Avatar
The majority of the trip is going to be interstate. I'm leaving myself 2 days to get home.....from a 9 hour trip.
It's not like I have to break any records, i just don't want to do irreversible damage to the drive train of the Bronco.....the body is already irreversibly damaged.
Old 12-11-2005, 06:13 PM   #14
RLKBOB
Ex Navy Nuke
RLKBOB's Avatar
Bronco Info: 1990 EB, 357, E4OD
I made that trip(kinda) last Jan to get tires and a lift kit and axles from Haustkraft. With the mountains and the winter weather and the fact that you're pulling a big ass Bronco I would use a trailer with brakes. The Bronco can handle it no problem I've pulled a bronco in my enclosed car hauler and on my dads open car hauler as well as a van and several cars. If your buddy has a trailer he can haul a car on then your Bronco WILL fit, measure it. You aren't planning on using a bumper hitch are you? i.e you have at least a class III receiver right? If I wasn't in the opposite direction you could borrow my hitch and weight distribution bars(which, BTW would be a really good idea pulling that much weight).
And Steve, the reason "statistically" you're more likely to get in an accident closer to home is because that's where everyone does MOST of their driving. If you drive 95% of the time w/in 5 miles from home and the other 5% farther away then obviously you're more likely to have an accident in the 95%
Bob Kulhanek, My Superford
Hit it harder or get a bigger hammer!!!
Originally Posted by DcSkater602
slap me silly im a mother F^%#$%*($ retard
Originally Posted by Bonzai View Post
Oh yea! Im definitely interested in a rear.
RLKBOB is online now   Reply With Quote
Old 12-11-2005, 06:31 PM   #15
slim
slim's Avatar
Bronco Info: 88 bronco with some white face gauges
I am looking at buying a carhauler right now. Some of them are only 76" wide. I know mine wont fit on one that is 76" with mt wheels and tires. I measured my tires and they were right at 83". I am not sure how wide one is with stock wheels and tires on it. Just somthing to keep in mind.
slim is offline   Reply With Quote
Old 12-11-2005, 07:59 PM   #16
blackbronco95
blackbronco95's Avatar
Bronco Info: 1995 xlt 351, E4OD, super cooling/ towing pkg
i haul a lot on the interstate between CT and GA and Indianapolis and Flordia with my bronco and i would never haul with a trailer that didnt have brakes on it. there have been way to many times when you get cut off or you come around a corner and traffic is stopped and your on the brakes hard. even with the trailer brakes you can still feel the trailer pushing you, and if its raining or snowing, it doesnt matter how fast your going, with the weight of a bronco on a trailer without trailer brakes you just asking for disaster. try pensky or ryder or maybe some local place. I own my trailer, 18 ft enclosed, big enough for a mustang and jeep( with the tires aired down) and would never pull anything without brakes. Especially with the short wheel base of the bronco. - chris
http://www.supermotors.org/registry/...il.php?id=7110
Blue 1995 351 Leather and clean as hell
blackbronco95 is offline   Reply With Quote
Old 12-11-2005, 08:12 PM   #17
Bronco Rob
Zombie Hunter
Bronco Rob's Avatar
I got a hold of my friend and had him measure his up, it's smaller than 76" with the rails he welded on. So thats out.
The only problem i have with a trailer with electric brakes is that i am not set up for electric brakes, i only run a 4 flat with my class III.
I am kind of stuck right now. I may just have to use the dolly and hope for the best. Like i said, i am not out to break any land speed records.
Old 12-11-2005, 08:44 PM   #18
rhetor
Its very hard to control the distance between you and the car in front of you.
even though you're probably going 10mph slower, people will be passing you and getting back into your lane right in front of you, because people are morons. people use their cell phones and smack the kids in the back seat.
The distance most definitely does matter. If you're on the road 9 hours, you will be using the brakes many more times than if you were on the road 1 hour. You will be seeing many more cars where something could potentialy happen.
I don't mean to start an arguement or anything. People tow like this all the time, i would just hate to say "you'll be fine" and lead you into a potential accident.
If you asked if you could tow it on a flatbed trailer with brakes, even though that is way over the rated GVWR of the bronco, i would say you'd be fine.
33x10.5 BFG m/t
Old 12-11-2005, 09:32 PM   #19
Steve83
Steve83's Avatar
You're the only one saying "He'll be fine." I'm saying "It can be done safely with a dolly if you pay attention."
I've made quite a few 9-hour trips in my life (and a few in the 24-hour range), and I can tell you that the brakes rarely got used compared to an in-town trip.
Old 12-11-2005, 09:47 PM   #20
Bronco Rob
Zombie Hunter
Bronco Rob's Avatar
Well, it's going to have to be the dolly, all the friends that have trailers that i called are either using them, or they aren't big enough.
Going to go with Steve83's advice and drop the rear axle, then air the tires down after it's on the dolly.
I used to drive for a living, i know how to pay attention and i am used to people thinking that a rig can stop on a dime. And as long as none of you are ODOT officials, there was plenty of times i ran overweight to make more cash.
Ever have a 53' truck in rush hour traffic in New York, New York? I have.
You may not post replies
Forum Jump
