Spout connector - FSB Forums
Thread Tools Display Modes
Old 01-28-2006, 07:23 AM   #1
NineT3
NineT3's Avatar
Bronco Info: 93 Eddie Bauer 5.8L Stock except for drop-in K&N, Warn Premium hubs and Warn winch bumper
Spout connector
Gents,
Trying to adjust the timing on my '93 5.8L and can not find that damn spout connector. Without that pulled the timing is not at base and I don't want to screw it up. I have looked all over the wiring to the distributor and still can't find that spout. HELP!!
Later,
NineT3
NineT3 is offline   Reply With Quote
Old 01-28-2006, 09:37 AM   #2
85f150
Stuck like a MoFo
85f150's Avatar
Bronco Info: Srry no Bronk only a F150
very good informative ---> fordfuelinjection.com it has where it shouold be in the harness.
I am not sure which style your year would has as i know they used different ones.
My 85 had the one that the plugin was tube shaped and had a single wire only goin in and out of the plug in.
Here's some from google images
This one looks more like my 88's style, the thing on the right of the pic, that you can almost not see. It is kinda like how a jumper is used on a computer to short 2 pins or leave them open
Truck Porn mooseracing.org
1985 F150 300 cubic inches of raw tq
79 XS 1100 SF
79 Firebird & T/A
64/65 Studebakers
85f150 is offline   Reply With Quote
Old 01-28-2006, 11:33 AM   #3
Kenny's 94
Kenny's 94's Avatar
Bronco Info: 5.0,e40d,9" 4:11,locker AR-23's,BFG 33's,K&N,2 1/2" lift,Bassani headers/Y pipe,BBK 56mm, sliders
Nine give this a shot, it's the location of the spout connector on my 94. Click on the picture and you will get a much larger view, the connector is located on the right side of the picture.
Hope it helps.
Kenny's 94 is online now   Reply With Quote
Old 01-28-2006, 11:47 AM   #4
Streetgang
CAUTION K-9 UNIT
Streetgang's Avatar
Bronco Info: 93 E. B. Mostly stock
It will be in the same area as the ECU test port and ABS test port.
Look right up close to the firewall on the left side (drivers side in the USA).....like right at the left side hood hinge. It is usually gray.
93 E.B. 302/E4OD, 31/10.5 BFG AT's, Flowmaster 40 w/1 cat, K&N FIPK, Hella 500's & FF50's, Warn Premiums, and a Optima Red Top with a 160A 3G alt.MSD rotor/cap/coil, Ford Racing 9mm wires, Goodyear High-Mile hoses, B&M stacked plate trans cooler, AutoMeter gauges.
Sig picture to big, resize before posting.
Streetgang is offline   Reply With Quote
Old 01-28-2006, 12:26 PM   #5
Steve83
Steve83's Avatar
Regardless of year & ignition type, the SPOUT is always within a couple inches of the ignition module. '85-91 TFIs are on the distributor; '92-96 TFIs are under the L hood hinge.
Old 01-28-2006, 08:27 PM   #6
jem270
jem270's Avatar
Bronco Info: 88 Ed Bauer. 302. AOD. Manual BW 1356 and hubs. Tow package with f & r anti-sway. 32 BFG AT. 3.55 LS
Here is a picture of the one on my 88. You can see it hanging down just above the waterpump.
1988 EB Bronco - 302 - AOD - 3.55 Limited Slip - Manual Hubs and Transfer Case- Firestone 31/10.5 AT - 212,000 miles
jem270 is offline   Reply With Quote
Old 01-29-2006, 07:00 AM   #7
NineT3
NineT3's Avatar
Spout connector
Kenny's 94,
Thanks for the diagram. The spout is hidden on the harness in front of the ignition control module. Yes, Steve83 it is under the drivers side hood hinge. Thanks for the help guys, timing will get adjusted now.
Later,
NineT3
You may not post replies
Forum Jump
