Serpentine Tensioner and Idler Pulley replacement - FSB Forums
Thread Tools Display Modes
Old 03-06-2006, 12:01 AM   #1
sewiv
i like monkeys
Bronco Info: 1994 XLT 5.0, MSD coil/cap/rotor, SpiroPro wires, Ford Racing tranny cooler, PermaCool filter, 3G
Yeah, I know, who needs a write-up for something this easy?
Well, not everyone on the board does SAS on their Broncos on the weekends. Some people just might want to wrench a little on their DDs. This is a simple thing to get them started, and my first attempt at a write-up.
So, here we go:
When I changed the belt on my 5.0, I noticed that the tensioner didn't return very strongly or smoothly. The idler pulley was sticky as well (though I didn't notice this until I was doing the tensioner swap already.) I also occasionally have low voltage at idle, so I figured replacing these old parts wouldn't hurt anything, and might help my belt tension stay a little more constant.
I picked up the new tensioner from Ford, but got the idler pulley from a local shop this weekend. I'd rather have a steel pulley like the tensioner, but this'll do. At least it was cheap.
First step is to disconnect the negative terminal on the battery. You *really* don't want the engine starting while your hands are in the fan/belt area.
Second step is to remove the belt. Using a 15mm socket on the tensioner pulley bolt, rotate the assembly counter-clockwise to relieve the tension, and slip the belt off the idler first. Then you can just pull the belt out of the way.
Third step, remove the tensioner. It takes a T50 Torx bit, and it has a normal right-hand thread. I had to put a wrench on the pulley bolt again to break loose the mounting bolt.
New vs. old
Here's the mount on the engine. The blurry tab sticking out is what the tab on the body of the tensioner presses against (where you can see the non-rusty vertical scratch).
Here's a shot of the new tensioner part-way on. You can see that the tab on the body of the tensioner is against the tab on the engine.
Here's the tensioner all the way on. Tabs are more obvious here, and the spring has been pressed together like the old one was.
I needed to extend my little breaker bar a bit to get the bolt loose on the idler, so I used my jack handle. This is usually a *bad* idea, and you can break tools really quickly doing this, but in this case it was exactly enough to make it really easy to break the idler bolt loose. This bolt is also a normal right-handed thread. I used a T50 Torx bit, which worked, but I'm not certain that was the right size, it seemed a little loose. I had to clean a lot of sand out of the head of the bolt as well.
Old and new. You re-use the bolt.
Here's the mount for the idler. Just screw in the new one with the old bolt. (and ignore the coolant seepage) Then you can put the belt back on (again, relieving tension with the 15mm socket on the tensioner pulley bolt). Read your manual or the sticker under the hood if you can't figure out or remember how the belt is routed. Tip: smooth pulleys get the smooth side of the belt against them, ribbed pulleys get the ribbed side. And if you find yourself trying to get the belt to go around the fan blades, you're probably doing it wrong.
Here are the two new parts installed. Prettier, no?
I gave a small blood sacrifice to the knuckle god, so this was a pretty normal wrenching session for me. Total time, if I hadn't been taking pictures, 20 minutes.
Sandy
sewiv is offline   Reply With Quote
Old 03-06-2006, 12:33 AM   #2
SoCal XLT
SoCal XLT's Avatar
Bronco Info: 95 Bronco XLT 5.8L E4OD 4" Lift
LOL.... I do..... I need all the help I can get!!! Nice write-up.
It looks cool...... so hows it workin.......... things smooth out a bit?
Kevin
1995 Bronco XLT
5.8L E4OD 4" Lift
BW 1356 ESTC w/Manual Locking Hubs
BFG 32 x 11.50 x 15LT
SoCal XLT is offline   Reply With Quote
Old 03-06-2006, 02:37 AM   #3
hoot2dr
hoot2dr's Avatar
Bronco Info: 93 XLT with way too few mods to list here
Good write up. Thanks!!!
93 XLT, New 302, New E4OD, Posi rearend, True Dual MagnaFlows (no cats), Homebrew FIPK, Warn Premiums, 3G Alt, Taurus Fan, MSG 6A/Coil/Cap
hoot2dr is offline   Reply With Quote
Old 03-06-2006, 02:58 AM   #4
Joes93Bronco
All I got for X-Mas was a
Joes93Bronco's Avatar
Bronco Info: '93 Custom 351W/E4OD/1356 4"Susp. 33" Tires. Now rockin the soft top.
where the hell were you four years ago? the pulley on my tensioner DISINTEGRATED while i was on the highway. wrestlin' that bronco to the side of the road was a bee-yotch.
Baby Girl
My SuperCrap Site
"The Price Good Men Pay For Indifference To Public Affairs Is To Be Ruled By Evil Men"
-Plato
Joes93Bronco is offline   Reply With Quote
Old 03-06-2006, 09:21 AM   #5
sewiv
i like monkeys
SoCal XLT: Everything is nice and smooth now, and a whine I used to have at idle has gone away. My voltage seems to read even higher at idle now too, which is nice.
Joes93Bronco: Yeah, my idler pulley on my 4.0 Ranger seized on the highway, and unscrewed itself from the block. I pulled over to find it lying on the block, with the belt hanging loose. That was pleasant.
Mods: Can you add a 56K warning to this post, if necessary? I can't edit the title. Thanks.
Sandy
Old 03-06-2006, 01:22 PM   #6
SoCal XLT
SoCal XLT's Avatar
Awesome...... Nothin beats takin' something that aint workin' well...... and fixin it so it works the way its supposed to!!! Mission accomplished!!
Kevin
1995 Bronco XLT
5.8L E4OD 4" Lift
Old 03-06-2006, 02:08 PM   #7
Gacknar
The Anti Yam!
Gacknar's Avatar
Bronco Info: 86 Bronco XLT 357w/AOD
Cool wrightup
86 Bronco - 357W/AOD - 6" suspension lift, 3" body lift - 38" TSL Radials - 456:1 Gears
Sequential Multiport Mass-Air Fuel Injection from a 93 Mustang GT
My SuperMotors Site - My Engine
The Greatest Thread on FSB
Gacknar is offline   Reply With Quote
Old 03-13-2006, 04:46 PM   #8
Juice52
Just a good ol' boy
Juice52's Avatar
Bronco Info: *sold* 1996 XLT
squealing at start up
Hey there I recently swaped out my alternator, serpertine belt, and put back on my stock pulleys. It now squeals for a few seconds when I start it up. I have tried putting belt dressing on the belt, but it doesn't seem to help that much. A guy at a shop said it could be the tensioner or the fact that that the pulley on the alternator is painted. Its a Mean Green alternator and they come with the pulley painted green. Any ideas or do you think it the tensioner?
SOLD ....1996 XLT, Rebuilt 351, 9" of lift, 35" MTRs, 79 D44 front, 8.8 rear both w/ 4.56s and ARBs
as well as a bunch of other mods
Juice52 is offline   Reply With Quote
Old 03-13-2006, 05:04 PM   #9
sewiv
i like monkeys
Pull off your belt. Spin your tensioner pulley by hand. It should spin smoothly, not notchy or tight. Same thing for the idler pulley. If the tensioner pulley is tight or notchy, you can just replace the pulley, you don't have to replace the whole tensioner. My spring was weak, so I replaced the whole thing.
And yeah, the green paint, depending on what kind of paint it is, could be pretty slippery, which would cause belt squeal.
Check that the alt. turns freely with no load, as well. While the belt's off, check that all the accessories turn as they should, and check end play (tug forwards and push backwards) on the water pump pulley. It should be pretty tight. If not, your water pump could be going.
Basically, check that there's nothing that is really hard to start spinning, because that's probably where the squeal is coming from, something that's taking a while to spin up to operating speed.
Sandy
Old 03-15-2006, 11:07 AM   #10
Juice52
Just a good ol' boy
Juice52's Avatar
Thanks for the info I'll check em out!
Old 03-15-2006, 11:13 AM   #11
sewiv
i like monkeys
Tensioner pulley bolt is left-hand thread, I'm pretty sure.
Sandy
Old 03-15-2006, 12:08 PM   #12
MyFullSize
MyFullSize's Avatar
Bronco Info: Previously: '89 Bko XLT 351W
Mine came with the bolt, it was a straight R&R, as easy as lard is greasy, and it fixed all the belt squal I was having too! Mine was about $40 IIRC.
1993 Jeep Cherokee Sport
* USAR/ARNG 11B RET *
1/116 INF 29ID(L) - (My unit was 1st wave on D-Day)
Read the book "The Bedford Boys"
^^ My animated .GIF is better than yours! ^^
MyFullSize is offline   Reply With Quote
Old 03-16-2006, 05:03 PM   #13
broncobum
broncobum's Avatar
Bronco Info: '95, 5.8, some stuff
i got a new idler pulley from napa that was steel. it looks like the pulley that came on your tensioner. the same thing happened with my jeep. it had a plastic, but the replacement was steel. i like them much better.
95 xl 5.8 <- gone.
broncobum is offline   Reply With Quote
Old 03-16-2006, 08:42 PM   #14
sewiv
i like monkeys
I have since checked, and the idler pulley bolt is a T50. I tried a T55, and it was way too big. I think the sand in the bottom of mine was making the T50 bit fit funny.
Sandy
Old 05-13-2006, 01:09 PM   #15
burger213
burger213's Avatar
Bronco Info: 94 XLT 5.8 EO4D
OK- I recently replaced my idler pulley as it was a little sticky and I was getting a squeal @ approx 1800rpm. No change in the squeal! This morning I started the Bronc and the belt began to shred. I replaced it and still the same squeal. I checked all the other pulleys and they all are smooth rolling and I have not had the A/C or defrost compressor running when this has occured. Any ideas???
Black sport monochrome 94 XLT 351/E4OD Ignition upgrade/timing bump otherwise stock.146,000 on the odo.
burger213 is offline   Reply With Quote
Old 05-13-2006, 03:52 PM   #16
Dave's Bronc 90
Some assembly required!
Dave's Bronc 90's Avatar
Bronco Info: 90 EB, 351W, E40D, D60 SAS, 10.25 rear, ARB's front & back, indellible Cheerwine stain in carpet
It's going to take a little detective work on your part. Take the serp belt loose and try to rotate each of the pulleys by hand, that should show you where the problem lies. Recently the A/C compressor on our Taurus went south and started making god-awful belt noises, that is how we diagnosed it.
And on another note, I just replaced the serp belt tensioner on the 5.8L in mine, made a big difference. Ever since I replaced the belt and upgraded to a 3G alternator my belt had been slipping on startup, with the new tensioner it doesn't make a sound.
Dave's Bronc 90 is offline   Reply With Quote
Old 05-13-2006, 05:51 PM   #17
burger213
burger213's Avatar
I've checked all pulleys that can be rotated with the belt off and each one seems to roll smoothly. The compressor has not been engaged when this occurs. It only does it when I'm slowly climbing through the RPM's around 1800-2000 then disappears. It doesn't squeal at any other time. I believe it's the original alternator. Could this be causing it by creating drag @ certain RPMs?? The alt pulley seems okay by hand. The tensioner is original but seems to have plenty of tension.
Old 05-13-2006, 11:10 PM   #18
jar73186
jar73186's Avatar
Bronco Info: 1994 EB stock
Same thing happened to me a couple of months ago. The bearing in the pully siezed melted the plastic pulley and shot it out from under the bronco. Had to get towed to the auto parts store in Topeka to get parts. It sucked
Adam
My supermotors Account:http://www.supermotors.org/users/jar73186
jar73186 is offline   Reply With Quote
Old 06-06-2006, 04:47 PM   #19
bigpede
bigpede's Avatar
Bronco Info: 1996 5.8L V8 Mostly Stock
Thanks for the write up
Thanks for doing the write up, but I cannot seem to find the t50 Torx bit anywhere, went to Advance, they were out, Lowes, out. Any thoughts? i saw plenty of kits for $14.95 that had the bit in it, but I don't need all the other sizes.
Thanks
bigpede is offline   Reply With Quote
Old 06-06-2006, 05:30 PM   #20
sewiv
i like monkeys
Best suggestion is to look in the phone book for auto parts suppliers or hardware stores. It's not that uncommon a thing.
If you are only buying a T50, you're probably going to pay $3-5. If you *ever* need another one of the bits in the kit, you're going to kick yourself. I'd just spend the $15 and be done with it.
Sandy
  FSB Forums > Bronco Discussions > Technical Write Ups
You may not post replies
Forum Jump
