Recommened rear differential gear oil? - FSB Forums
Thread Tools Display Modes
Old 03-27-2006, 09:21 PM   #1
nezzer
Bronco Info: 1996 Eddie Bauer 5.8L
I am going to be replacing a leaky seal on my rear differential. My 96 5.8L has (to the best of my understanding) an 8.8 rear end with out the limited slip differential.
Another post suggested a 75w-140 gear oil but that was for a 9" rear end. A chain automotive store suggested 80w-90. Which one would you guys recommend?
Thanks!
nezzer is offline   Reply With Quote
Old 03-27-2006, 09:27 PM   #2
Ogeechee 4x4
Ogeechee 4x4's Avatar
Bronco Info: '95 Bronco, 351W, NP435/205, Solid D44 front, 35" MTR's, 3.55 gears
Do you have the owners manual still? It should say in it...
My SuperFord
'95 Eddie Bauer-- 351W, NP435/205, D44 SAS
Ogeechee 4x4 is offline   Reply With Quote
Old 03-27-2006, 10:45 PM   #3
MikE2
MikE2's Avatar
Use the 80/90 or 75/90
The 140 is reccomended for very heavy gear loads, such as drag racing and in truck axles
MikE2 is offline   Reply With Quote
Old 03-28-2006, 12:42 AM   #4
TheUnforgiven
Huh Huh vanzercool
TheUnforgiven's Avatar
Bronco Info: 2005 Chevrolet Venture, 1997 Acura TL
i just did mine last week. i used 80w90, get 4 quarts, it says less in the owners manual, but it's wrong. if it is a limited slip, you will know it when you open it up. this is an Ford 8.8 rear differential WITH the limited slip. for this differential, you will need the little 4 ounce bottle of the friction modifier. buy the bottle anyway, just in case, if you don't need it, cool, return it. better to be safe than sorry. if it needs the Friction Modifier, dump the FM in FIRST, then fill it with 80w90 until it comes out of the fill hole, then, you're all done.
Ford 8.8 Limited Slip Rear Differential.
2005 Chevy Venture. 1997 Acura TL. $500 beater.
New nuts are in the plan.
TheUnforgiven is offline   Reply With Quote
Old 03-28-2006, 02:59 AM   #5
Dan90FSB
Dan90FSB's Avatar
Bronco Info: 1990, 351W, E4OD, 8 lug Dana 44 SAS, 14 Bolt, Lockers, 37" IROKS, 10 point cage, sliders, winch
80 90 is where its at...take a wiff of that old oil for me...yummy!
Under Construction 4x4- www.uc4x4.com
Dan90FSB is offline   Reply With Quote
Old 03-28-2006, 10:27 AM   #6
Runnin'OnEmpty
Runnin'OnEmpty's Avatar
Nezzer, you have a choice of 4 weights in two types of gear oil.
  • Mineral 80W90
  • Mineral 80W140
  • Synthetic 75W90
  • Synthetic 75W140
Ford has been recommending Syn 75W140 in later model truck diffs. That's the one to use if you want to fill and forget for the next 100K miles. It's also the most expensive at about $13/qt.
The mineral 80W140 is just as good, but isn't as shear-stable as syn, and it won't flow quite as well, if you live in a cold climate.
As was stated, the 75/80W90's are fine in a light vehicle that's not used for towing, but they won't handle shock loads as well as the heavier oils.
1978 Bronco Ranger XLT, Trailer Special with FreeWheeling Package, 351M, NP435, Ford alloys w/BFG 31's, MAC/IMCO hybrid exhaust.
Runnin'OnEmpty is offline   Reply With Quote
Old 03-29-2006, 02:18 PM   #7
broncAR
broncAR's Avatar
Bronco Info: 1986 Bronco XLT EFI
What friction modifier are you guys using in your LSD?
Rodolfo
"Difference between men and boys is the price of the toys...."
My Supermotors Garage
broncAR is offline   Reply With Quote
Old 03-29-2006, 03:11 PM   #8
85f150
Stuck like a MoFo
85f150's Avatar
Bronco Info: Srry no Bronk only a F150
none....
it is used to make the clutches slip so they don't chatter, never had any chatter so i don't run any
Truck Porn mooseracing.org
1985 F150 300 cubic inches of raw tq
79 XS 1100 SF
79 Firebird & T/A
64/65 Studebakers
85f150 is offline   Reply With Quote
Old 03-29-2006, 08:58 PM   #9
Bronco4Life
Bronco4Life's Avatar
Bronco Info: smells like gear oil
Hmm, thinking about going synthetic 75w-90 in my 8.8 rear with a detroit.
Think the 75w-140 will be better, even with the detroit, or should I stick with the 75w-90. I don't remember off the top of my head what the detroit needs.
92 EB - 302/E4OD (205,000mi) - Eric
+ lots of cool crap.
Originally Posted by dgmid61
I am sorry to have bothered you on your forum, you should post on the home page though, dont ask any questions cause if you dont know you are stupid...
Bronco4Life is offline   Reply With Quote
Old 07-13-2006, 01:35 AM   #10
djdan
djdan's Avatar
Bronco Info: 1992 EB 5.8 Durabak Black Chuck Norris "Thumbs Up" Edition
Bringing back an old thread instead of making a new one.
I am switching to Royal Purple Fluids in the T-Case and both front and rear gear.
This is a fully synthetic fluid...what weight should I be buying? I looked in the manual and in my Haynes and did not find an answer.
I don't tow and will do mild to moderate off-roading a few times/year.
Thanks in advance for the help.
djdan is offline   Reply With Quote
Old 07-13-2006, 01:37 AM   #11
MikE2
MikE2's Avatar
get the 80/90 or the 75/90
Royal Purple has a great FAQ on their site too. Check it out because theres pages about their oils and what weight to run
This is my favorite right here. Hasn't let me down yet so I'll stick with it (plus I like saying I have a full Mobil1 drivetrail)
I run it in every axle I got because everything I have tows something too. I wouldn't even think of running the dino oil in the rear of the SD with that diesel dragging all the weight up the hills.
Old 07-13-2006, 01:50 AM   #12
djdan
djdan's Avatar
Honestly I'd have no problem with Mobil 1 either. I ran it in my old Bimmer and I run it in the fiances Lexus. I bet I could pick it up at the ol' Wally world too for a fraction of what RP cost.
Maybe I'll go with Mobil 1...anythings better than what's in there now!
BTW that is a good looking rear diff. Mine is just a stocker 8.8 and will remain so for quite some time!
Old 07-13-2006, 11:01 AM   #13
Shadofax
Owned 19yrs, now for 20
Shadofax's Avatar
Bronco Info: 95XLT351 E4OD SAS 44/ARB/Alloy shafts-joints. D60 rear/Detroit. 4wheel disc,37" MTR Kevlar, 4.56etc.
Royal Purple Tranny fluid for the tcase, yea?
______________________
Click my supermotors link for tech on TCase, SAS, OBA, Soft Top, Overhead Console, Stock bumper Winch install, much more..:
http://www.supermotors.net/registry/628
Shadofax is offline   Reply With Quote
Old 07-13-2006, 06:57 PM   #14
TheUnforgiven
Huh Huh vanzercool
i guess you didn't read the thread, the viscosities are all over it.
either way, 80W90 for the rear, and i believe ATF for the T-case. at least there was ATF in my friends Explorer.
Old 07-13-2006, 07:18 PM   #15
okst1
Bronco Info: 1973 EB/1995 Big Bronco
The specs are 80W90 for front and rearends and MERCON in the transfer case. I changed over to Royal Purple about a month ago.
okst1 is offline   Reply With Quote
Old 07-13-2006, 08:50 PM   #16
MikE2
MikE2's Avatar
If you have a manual transmission that uses the auto fluid, Don't use Royal Purple's ATF. Royal Purple makes a oil specially designed for manuals that need ATF.
Old 07-13-2006, 09:27 PM   #17
Slickerthanyou
Currently FSB divorced
Slickerthanyou's Avatar
Bronco Info: Had a 1990 XLT 5.8L Parting out to buy a '79 by spring 08
Just did mine too. Used same
Broncoless at this time Yip she left me!!
Originally Posted by Ranger1 View Post
I beat on it, beat on it and beat on it some more and I have the fork tool in there almost until it can't go in anymore.
Is there a trick to this ?
Slickerthanyou is offline   Reply With Quote
Old 07-20-2006, 03:08 AM   #18
djdan
djdan's Avatar
Aamco was the last person to do my diff right when I took posession of the truck...what the hell was I thinking? At any rate they did a shoddy job and gooped on the sealer instead of doing a gasket so it had a slow leak as well as dino oil in it. You can see in the pics where it was leaking and rusting on the bottom. I cleaned it all up before I reinstalled the cover. Who knows if Aamco actually even opened it.
Just got done doing mine this evening and it appears I have a limited slip...I didnt think I did! Could someone verify this for me please.
I also found out I do, in fact have 3.55's as it is stamped right on the gear so that was easy.
Ended up using Mobil 1 instead of Royal Purple due to ease of availability and a bit better price. I used 75-90. I did NOT add the friction modifier as the Mobil 1 bottle says its already in there.
When I closed it up I decided to follow someones advice and use a Fel-Pro gasket which was under $5 at Advance Auto. I must say that was a good way to go vs. a bunch of goopy gasket maker crap.
I also decided to clean up the cover and paint it with some hammer paint. It was rusty as hell and looked pretty bad. I wanted to do it black but my black spray paint can clogged.
How hot does a rear diff get?
The paint I used said not to use it on items that go over 200 Deg. F....if it comes off I don't really care..it looks better for the time being.
I also replaced the vss/abs sensor as my speedo needle fluttered quite a bit and my ABS light was going on and off quite a bit even after I cleaned it up and reinstalled the original.
I was also surprised that my diff swallowed 3.75 bottles of fluid. The jacklegs @ AutoZone told me that I only needed three bottles...they even looked it up in the (obviously sucky) database. I had to run to the store to grab another...of course!
Front Diff here I come!
Here be the pics-
Old 07-20-2006, 12:51 PM   #19
GTRider245
It's BTW Not AKA!
GTRider245's Avatar
Bronco Info: 92 F-150 4x4, 302, BBK Shorties, Flowmaster Duals, M5OD, 2" Rancho Coils, 33x12.50 M/Ts
Cover looks good. I also used Mobile1 when I did mine, although it didnt take 4 qts. That sure does seem like alot...
1992 F-150 4x4
East Coast Firefighting- Only the Best
http://www.supermotors.org/vehicles/...il.php?id=4768
Originally Posted by dogonmut View Post
NTB stole my baby's momma away from me when she was on her way down to the check cashin' store to pay my beeper bill.
Originally Posted by stan the man View Post
I spent $330 for 4 BJs.
GTRider245 is offline   Reply With Quote
Old 07-20-2006, 04:54 PM   #20
Audra
Audra's Avatar
Bronco Info: Some Broncos
Originally Posted by 85f150
none....
I've had a lot of problems with chatter from my rear pumpkin. Usually end up adding some every year or so according to the previous owner, I've had to add since I bought the truck. Stuff works wonders.
The Trucks
www.FourDoorBronco.com
Audra is offline   Reply With Quote
You may not post replies
Forum Jump
