Go Back   FSB Forums > Bronco Discussions > Noobie Bronco Tech Questions. Flame free zone!
Thread Tools Display Modes
Old 10-03-2003, 03:08 PM   #1
Aikidoka
Who needs oil anyways....
Aikidoka's Avatar
Bronco Info: 86 Bronco 351W
Broken wheel stud
Well I snapped one of the studs for a lug nut taking a tire off. Eventually I'll have to put the tire back on so I need to find my options for repairing it. Can just the studs be changed or do I need to replace the whole wheel piece? I figure I'll change out my rotor also since it is grooved. Any suggestions/advice?
Aikidoka is offline   Reply With Quote
Old 10-03-2003, 03:12 PM   #2
Rockfrog
Rockfrog's Avatar
yep, disassemble the hub assembly (might as well clean and repack the bearings while you're in there) punch the studs out the back knock the rotor off, buy new stud (might as well get all 5) slap it back together and away you go.
Dave G
81 Bronco Project (actually 76 f250, 76 f150, 81 Bronc, 84 Bronc, etc) 300-6/NP435/NP203/NP208 d44/9" 3.50's on 33's .. 75% done
Rockfrog is offline   Reply With Quote
Old 10-03-2003, 03:12 PM   #3
jermil01
Charlie doesn't surf!!
jermil01's Avatar
Bronco Info: 1992 xlt, 351EFI bored .040, E40D, D44 SAS w/Trutrac, 8.8 Detroit locked rear
Yeah, you can pull the hub, pound the broken stud out and replace it..I am pretty sure that NAPA sells replacement studs.
Vote 4 Top 4x4 Site!!!
jermil01 is offline   Reply With Quote
Old 10-03-2003, 03:20 PM   #4
Aikidoka
Aikidoka's Avatar
Thanks. I'll probably do all the studs since it's all kinda crappy. Then I'll have a nice shiny rotor and new studs yet a rusty looking wheel. Anyway to clean it up? I imagine if I wanted to sand blast it I would have to get the bearings out and tape off the areas I don't want sand in.
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
