| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
Mercon V
#1 |
Mercon V
I have a '95 fsb 5.0 5 speed. In a bit of speed shopping at pep boys (too many things to do on a sunday...) I grabbed mercon V and used it in my transfer case fluid swap. Its' Penzoil mercon v and it says it can be used in all ford vehicles that require mercon or mercon v. YES I SEARCHED but I got a few conflicting answers so I figured I would post one definite question:
Is it ok to use Mercon V in a '95 transfer case? What about the tranny - going to do that next (I have the mazda 5 speed)? Thanks! |
| Sponsored Links | |
Advertisement |
#2 |
F*ck 'em all
![]() Join Date: Sep 2006
iTrader: (0) Bronco Info: 1992 Bronco XLT 5.8 E40D, York OBA, 3G Alt, K&N, 3" body lift, 4" susp lift, 37" Goodyear MT/Rs
according to FMC, mercon V has replaced Mercon and is an acceptible substitute.
http://www.supermotors.net/users/92builtbronco |
#4 |
F*ck 'em all
FORD: 1980-1997 Crown Victoria
1981-1997 Mustang, Thunderbird 1981-2003 Escort 1986-1993 Festiva 1986-1997 Taurus 1989-1997 Probe 1994-1997 Aspire 1995-2000 Contour 1980-1996 Bronco 1981-2003 F-150 1981-2004 E-Series, F-Super Duty 1983-1996 Ranger 1986-1996 Aerostar 1991-1997 Explorer 1993-2004 F-53 Motorhome Chassis 1995-1998 Windstar 1997-2004 Expedition 2000-2005 Excursion 2001-2007 Escape 1987-2000 F- & B-Series 2000-2007 F-650, F-750 LINCOLN: 1980-1997 Town Car 1981-1997 Continental 1993-1997 Mark VIII 1998-2004 Navigator 2002-2003 Blackwood MERCURY: 1980-1997 Grand Marquis 1981-1997 Cougar 1986-1997 Sable 1987-1999 Tracer 1995-2000 Mystique 1999-2002 Cougar 1993-2002 Villager 1997 Mountaineer 2005-2007 Mariner MERKUR: 1985-1989 XR4TI This article supersedes TSB 01-15-7 to update the vehicle application chart. ISSUE: MERCON® Automatic Transmission Fluid is being replaced by MERCON® V as a service fluid. ACTION: Beginning immediately all automatic transmission / transaxle applications requiring MERCON® can now be serviced using MERCON® V or MERCON® Automatic Transmission Fluid or dual usage fluids labeled MERCON® / MERCON® V. After July 1, 2007, MERCON® Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory. SERVICE PROCEDURE Service automatic transmissions requiring MERCON® with MERCON® V or MERCON® Automatic Transmission Fluid or dual usage fluids labeled MERCON® / MERCON® V For proper fluid application on current and past model vehicles equipped with automatic transmissions / transaxles refer to the fluid usage chart. (Figure 1) CAUTION: AUTOMATIC TRANSMISSIONS / TRANSAXLES THAT REQUIRE MERCON® V SHOULD STILL ONLY USE MERCON® V OR DUAL USAGE FLUID LABELED MERCON® / MERCON® V. CAUTION: MERCON® SP, MOTORCRAFT PREMIUM AUTOMATIC TRANSMISSION FLUID AND MOTORCRAFT M5 ATFS ARE UNIQUE FLUIDS AND MUST BE USED IN APPLICATIONS RECOMMENDING THAT PARTICULAR FLUID. USE OF ANY OTHER FLUID MAY CAUSE REDUCED FUNCTIONALITY OR TRANSMISSION DAMAGE. CAUTION: THE FUNCTIONAL CHARACTERISTICS OF FLUIDS FOR CVT TRANSMISSIONS ARE VERY DIFFERENT THAN THOSE OF OTHER AUTOMATIC TRANSMISSION FLUIDS (ATFS). USE OF A FLUID OTHER THAN MOTORCRAFT CONTINUOUSLY VARIABLE CHAIN TYPE TRANSMISSION FLUID OR ONE LABELED AS MEETING MERCON® C WILL CAUSE FUNCTIONALITY CONCERNS AND INTERNAL TRANSMISSION DAMAGE. CAUTION: DO NOT USE AUTOMATIC TRANSMISSION FLUID SUPPLEMENTS, ADDITIVES, TREATMENTS OR CLEANING AGENTS. PART NUMBER PART NAME XT-2-QDX MERCON® (Quart) XT-2-DDX MERCON® (55 Gal. Drum) XT-5-QM MERCON® V (Quart) XT-5-DM MERCON® V (55 Gal. Drum) WARRANTY STATUS: Information Only Figure 1 - Article 06-14-4 -------------------------------------------------------------------------------- NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford, Lincoln, or Mercury dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources. Copyright © 2006 Ford Motor Company |
#6 |
![]() Join Date: Nov 2003
iTrader: (4) Bronco Info: 1990 Bronco XLT 302/AOD ELocker Rear/ custom 8.8. 1986 Bronco XLT. 1981 Bronco Custom
I use the synthetic version in my t-case. The temps get insane and well above the rating of dino tranny fluid. Plus, they only hold 2 qts.
#7 |
Perspicuously Pernickety
![]() Join Date: Jul 2003
iTrader: (91) Bronco Info: '83 Custom w/'95 4.9L & EB paint
92builtBronco
Do you have any objection to my reposting that in the TSB thread? |
#8 | |
F*ck 'em all
#9 |
green ones make me horny
Man it is good to know that Mercon V can be used. It is getting harder to find just mercon or mercon 3 anymore. Thanks for the TSB.
Now will mixing this affect anything cause i have mercon in mine now? |
#10 |
Thanks! I appreciate all the info. Now to swap the tranny fluid. Thats if I can find a funnel that looks like a crazy straw to get the fluid into the fill hole. Not exactly the easiest place to empty a quart bottle....
Thanks again. This board rules. |
#11 |
hahahah you got to get one of the funnels with the plastic flexible thing on the end of it at wally world for like 5 bucks or so
#12 |
iTrader: (0) Bronco Info: 95 Bronco, black. a few extra's.
so im probably mistaken but dont we have conflicting information ???
steve83's link states : " MERCON® V Automatic Transmission Fluid: Engineered and recommended by Ford Motor Company for use in automatic transmissions ONLY where MERCON® V is specified. " and 92builtbronco's info states : "ACTION: Beginning immediately all automatic transmission / transaxle applications requiring MERCON® can now be serviced using MERCON® V or MERCON® Automatic Transmission Fluid " so am i just reading this backwards ... or wtf??? im already loosing it because taxes suck and are confusing. |
#13 |
FSBs Greeze Monkeh
![]() Join Date: Jul 2006
iTrader: (0) Bronco Info: 89 E. Bauer Edition-5.8/C6/factory towing/loose nut between wheel and go pedal
Find a parts store that sells fluids in quart or gallon jugs with a hand pump and hose. My coworker has a quart bottle with a pump and hose that we use for pumping ATF into manuals and xfer cases.
#14 | |
anyone? |
#16 |
i like monkeys
![]() Join Date: Dec 2005
iTrader: (16) Bronco Info: 1994 XLT 5.0, MSD coil/cap/rotor, SpiroPro wires, Ford Racing tranny cooler, PermaCool filter, 3G
Most Walmarts will also have long straight funnels that work fine for filling the transmission.
-- Sandy |
#17 | |
It's BTW Not AKA!
iTrader: (0) Bronco Info: 92 F-150 4x4, 302, BBK Shorties, Flowmaster Duals, M5OD, 2" Rancho Coils, 33x12.50 M/Ts
Or try a fluid pump
1992 F-150 4x4 East Coast Firefighting- Only the Best http://www.supermotors.org/vehicles/...il.php?id=4768 Quote:
#18 |
REdeployed C-17 MX
![]() Join Date: Dec 2004
iTrader: (1) Bronco Info: '92, '88, and '84 Broncos
Only the NEW "reformulated" Mercon V is supposed to be used in the E4OD/4R100. Unfortunately there is no way to tell the new from the old other than the bar codes, and I have yet to see what Ford did to "reformulate" it for compatibility. It was rumored that people saw Ford taking back all the old Mercon V from stores and spot checking the bar codes to make sure only the new stuff was sold when that TSB came out.
The M5OD-R2 and BW1356 ain't gonna care, but I'd be worried about E4OD/4R100 owners. Mercon V was originally made 4 years after the intro of the 4R70w because plain ole Mercon which doesn't have friction modifiers. The 4R70w needs friction modifiers, but the E4OD/4R100 is designed not to have friction modifiers in the fluid and there are many reported cases of the E4OD/4R100 dieing after the old Mercon V was mistakenly put in. In conclusion, who the hell knows with Ford. I'd just like one hour to talk with a powertrain engineer there. Adrianspeeder
'08 F250 PSD 6spd 4x2, '02 F250 PSD auto 4x4, '97 F150 4.6L 5spd 4x4, '79 F100/250 302/351M 4spd 4x2/4x4, '79 F150 351M C6 Dually, '74 F250 360 C6 Hiboy, '71 F100 302 4x2 3tree, '66 F250 352 4x2 3tree, '96 Exploder XLT Sport 4.0L, Broncos: '92 XLT 302, '90 XLT 302, '88 XLT 302/351, '84 Lariat 351HO '85 M-1009 (K-5 Blazer) 6.2L auto US Army Surplus ReDEPLOYED C-17 Avionics Journeyman USAF DAFB |
#19 |
F*ck 'em all
Adrian, the powertrain engineers don't know which end is up half the time either.
#20 |
I Shear Bolts
iTrader: (0) Bronco Info: 1991 XLT, 5.8L, E4OD, BW 1351, Just Stock...
oooo, good read. I'm I saw this cause I just bought a case of Dexron III / Mercon and I gotta ask how that'll do. I got it to change the fluid but the stuff that's in there is still bright red and clear, but that's what the dipstick shows. I wonder what's lurking down there in the pan?
So how's the Dexron III / Mercon gonna do me? Should I return it?
"Respect The Mountain Or It Will Consume You" -NSP Far West Region |
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
