| Home |
| Register | Blogs | FAQ | Donate | Members List | Calendar | Mark Forums Read |
Transmission Mount for e4od
#1 |
Moderator
![]() ![]() Join Date: Oct 2004
iTrader: (3) Bronco Info: 1996 EB Bronco, 5.0, E40D, Dana 44 SAS, 4.88 gears. 35" SuperSwampers
These are in my SAS build thread. been getting some questions on it so I thought it would be nice to put all the pics together.
To make room for the Cage Radius Arms mounts, it is necessary to relocate the OEM transmission cross member back a couple inches. Thus requiring a fabrication of a new cross member. Some OEM pics ![]() ![]() ![]() ![]() Purchase some square tubing 2 X 4" 1/4" thick ![]() remove the transfer case skid plate ![]() ![]() Cut to length (37") ![]() Trial fit ![]() The OEM cross member can stay in place while fabing, notice the notching on the passenger side OEM to make room. ![]() ![]() Making the bridge for the transmission mount (4.5") ![]() Cut at 45% to ease nut access ![]() Using a tall Axle stand to support the transmission so OEM cross member can be removed ![]() Tack everything together ![]() ![]() ![]() Take it off and weld it up ![]() Painted and installed ![]() ![]() ![]() ![]() ![]() Plenty of room now! ![]()
-Steve My SAS Build http://fullsizebronco.com/forum/showthread.php?t=69270 3" Exhaust http://www.4x4preservation.com/forum...read.php?t=201 My SuperMotors http://www.supermotors.net/15991 4x4 Preservation 4x4preservation.com |
| Sponsored Links | |
Advertisement |
#2 |
Nice job! Would you be able to make a template for others?
#5 | |
Moderator
see. Don't want my transfer case being the lowest thing on the belly. ![]() |
#6 |
Master Bater
iTrader: (17) Bronco Info: 4 wheels, 4 sticks and 3 pedals
I disagree that nothing would be gained. Currently, you have a 300 plus pound tranny and Tcase assembly hanging off 3/16 flat metal pice of frame. Your frame mounts are two pieces of 1.4 that have been bent witha break, which arguable pre weakens the steel and makes it prone to bending. Couple that with a 6500 pound bronco, and iff you hit that xmember on a rock, or get hung up, there is not much in the way of reinforcing to keep from bending or tearing the frame. You have two C type pieces of metal that will leverage off each other, and bend the frame, which will in turn twist the tranny mount as one side raises, which will affect your shaft angles, motor mounts, and potentially all the way up to your fan, whcih will then hit the fan shroud.
I understand your point about the tcase and not wanting it low, but that is what a well built skid plate is for. And, instead of an approximate 6" square area where the belly pan would need to dip down to clear the tcase, you have an entire 2x4 piece of steel hanging down. Moreover, that is right at the breakover angle on our rigs, so if you are climbing a ledge, its gonna hit. Its well built, Im not trying to bash your work, Im just telling you from experience what the truth is. Take it or leave, but I think you need to redesign the mounts. Last edited by plug ugly; 05-07-2007 at 05:01 PM.. |
#7 | |
Moderator
EDIT: plug is right about the frame being 3/16" |
#8 |
![]() Join Date: Apr 2003
iTrader: (3) Bronco Info: 88 bronco(?)/96 F250; both with D60s
Trailer hitch isnt a good comparison, it only sees one load, directly in line with the frame. its not putting side-loads on it like the trans xmember would see while wheelin.
I have to agree with plugugly on how it mounts to the frame; just having a heavy gauge plate on the outside that bolts to both the frame & the xmember would probably help stiffen it up as well. It scary how much stress the front susp will put on the frame. I wont argue having it below the frame; its all about the vehicles intended use, and yours is definitely used differently than pluglys. |
#9 | |
Moderator
My front suspension isn’t attached to my trans mount so I don’t understand why you mention that, and yet no one has had an issue with the mounts. Lets keep this simple, The OEM trans mount worked fine. Many if any have never had an issue with it. The only time they might have an issue is when they drag it over some rocks and it bends as a result. It’s of very light steel, don’t know off hand but much lighter than what I used. My trans-mount is of heaver metal and mounts over a larger area then the OEM one. Therefore it’s much stronger than factory. The trans mount its self is rubber!! Surly to god my mount is stronger than rubber. And how about this - its been 9 months of no problem, no flex marks on this mount. Its proven. Looks like the day I installed it. |
#10 |
No really... Its dumb
![]() Join Date: May 2007
iTrader: (0) Bronco Info: 93 "Custom" 1 Ton, Locked Front/Rear, EFI460, C6, Hydro assist,Ballistic High Steer,44 boggers, etc.
That does look like a hang up point. IS there a way maybe to contour the xmember into the frame rails? You would think that the first bad stump in the swamp you'd get stuck on, would rip that thing right out. Although the OEM member is not nearly built that tough, it won't see nearly the impact that that one will..... just my .02, then again its prob more like .01, have you seen my Fordcoction?
#11 | |
Moderator
#12 |
As long as the skid plate goes almost the full width of the member.... on the OEM member, only the part that is under the drive train is below the frame rails, where as all of your member is below the frame rails.... but I imagine it could be resolved with a good skid plate... good fab job though, wish I could figure out how not to weld in bugers...
#13 |
No need to get defensive, im not questioning your work
It just seems to me that a trans xmember w/ radius arms attached to it would see alot more sideloads than a trailer hitch since 99% of the time the trailer is right there behind you, not swerving way to the left or right pulling hard, sideways, on the vehicle. I have no doubt that your trans mount is beefier than stock, only agreeing with plugly that when ford designed the xmember, they mustve attached to more than just the bottom of the frame rails for a reason, and that maybe yours would be even stronger if you did so too. |
#14 | |
Moderator
#15 | |
Moderator
Correction: I went out and looked at the old mount. On the passenger side it mounts with 3 bolts into the side of the frame but none below, on the drivers side it mounts via one bolt in the underside of the frame and than uses and extension to reach the top of the frame where its help by 2 bolts. |
#17 |
Stuck in the 70's & 80's
![]() Join Date: Jun 2003
iTrader: (11) Bronco Info: 95XLT351 E4OD SAS 44/ARB/Alloy shafts-joints. D60 rear/Detroit. 4wheel disc,37" MTR Kevlar, 4.56etc.
I'm not seeing an issue with da member. It is a little different than what plug did, and what I did in following, and it does hang about 1" lower than mine, but that also means it clearances the front DC style driveshaft easy and mine is going to be really close (have not done this yet since I'm sure it will fit, but GKR's does and his 'member is like mine). In any case, skid plate I went with:
______________________ http://www.supermotors.net/registry/628 "TheJuice...yes, that was my name. I come back to you now at the turn of the second decade...my name is Shadofax" |
#20 |
![]() Join Date: Dec 2004
iTrader: (9) Bronco Info: 1995 black sport,6''DC Stage II 35''DC-FC_II,MT Classic Locks 4.56 Gears FIPK,Bronco Air rear bumper
Since this was brought back up and since the new cage arms are bigger than the old ones and would make the mount to far back, i had any idea for a trans mount.
I want to take 2 stock cross members and cut the driver side off of one and the passenger side off the other and make one mount kind of like this pics i stole from Bossind and cut up. What do you think, i would reinforce it as well. ![]()
![]() ![]() I WAS BORN TO BLEED, FIGHTING TO SUCCEED, BUILT TO ENDURE WHAT THIS WORLD THROWS AT ME. Silent One's Supermotors Page New Steering Wheel Thread Back Seat Hi-Lift Mount January 2010 FBOTM Winner |
| Thread Tools | |
| Display Modes | |
© 2007 FullSizeBronco.com | ||||
| Powered by FSB | |||||
