Go Back   FSB Forums > Bronco Discussions > Technical Write Ups
Thread Tools Display Modes
Old 05-07-2007, 01:51 AM   #1
Steve83
Steve83's Avatar
Bronco Info: '83 Custom w/'95 4.9L & EB paint
Steering Box Preload Adjustment
This applies to all Ford truck (& many car) steering gear boxes used from the mid '70s to the '00s.
1. Disconnect the pitman arm from the sector shaft using a Pitman Arm Puller (Tool T64P-3590-F).
2. Disconnect the fluid return line at the reservoir and cap the reservoir return line nipple to retain the fluid in the reservoir.
3. Place the end of the return line in a suitable container and turn the steering wheel from stop-to-stop several times to discharge the fluid from the gear. Discard the fluid.
4. Turn the steering wheel to the right stop, then back left 45 degrees.
5. Attach an inch-pound torque wrench to the steering wheel nut and determine the torque required to rotate the shaft slowly approximately one-eighth turn (45°) toward center from the initial 45 degree position. Note this first value.
6. Turn the steering gear back to center and determine the torque required to rotate the shaft back and forth across the center position (± 90°). Compare the center value to the first value, using the following criteria:
* Vehicles with less than 5,000 miles (8046 Km):
If total meshload over mechanical center is less than 15 in-lb (1.7 Nm) or greater than 24 in-lb (2.7 Nm), RESET to first value PLUS 11-15 in-lb (1.2-1.7 Nm).
* Vehicles with more than 5,000 miles (8046 Km), or with new sector shaft:
If meshload over mechanical center is NOT 7 in-lb (0.8 Nm) GREATER than the first value, RESET to 10-14 in-lb (1.13-1.6 Nm) GREATER than first value.
7. If reset is required, loosen the adjuster locknut and turn the sector shaft adjuster screw until the reading is the specified value greater than the torque at 45 degrees from the stop. Hold the sector shaft screw in place, and tighten the locknut.
8. Re-check torque readings and replace the pitman arm and steering wheel hub cover.
9. Connect the fluid return line to the reservoir and fill the reservoir to specification with the specified fluid. Check belt tension & adjust if necessary.
Do not pry against the reservoir to obtain proper belt load. Pressure will deform the reservoir and cause it to leak.
BEFORE POSTING IN ANY TECH WRITEUP THREAD, read this post.
Old 06-11-2007, 11:07 PM   #2
MuddyBronco13
Hmmm....
MuddyBronco13's Avatar
Bronco Info: 96 Eddie Bauer, 3" BL, 33's, Exhaust, Grille Guard, and a couple of lights
do you so happen to use Mitchell guides online?
MuddyBronco13 is offline   Reply With Quote
Old 06-12-2007, 01:19 AM   #3
waltman
Lick my balls
waltman's Avatar
Bronco Info: 1989 bronco, 3" suspension lift, rebuilt 302 with cam, 33' big-os
Nice write up Steve. Consider that noted, thanks.
there is no such thing as stupid questions, just stupid people.
Only that in you which is me can hear what I'm saying
No matter where you go or what you do, you live your entire life within the confines of your head
I don't suffer from insanity; I enjoy every minute of it
waltman is online now   Reply With Quote
Old 06-12-2007, 02:49 AM   #4
Steve83
Steve83's Avatar
No. Mitchell & I both use this.
Old 06-13-2007, 08:40 PM   #5
MuddyBronco13
Hmmm....
gotcha, i use mitchell at work and access it at home as well, its a nice thing to have
Old 06-14-2007, 06:04 PM   #6
bronco boy
bronco boy's Avatar
Bronco Info: No More Bronco
I just got a version of AllData, and it puts my old Mitchells' to shame.
Chris B
bronco boy is offline   Reply With Quote
Old 06-15-2007, 11:54 PM   #7
brutus84
brutus84's Avatar
Bronco Info: 1984 bronco XLT 351 winsor new 33's
where do you get one of these mitchell's and what is it exactly?
brutus84 is offline   Reply With Quote
Old 06-16-2007, 11:44 AM   #8
bronco boy
bronco boy's Avatar
They are cracked non-legal versions. Available on the internet of from the guy standing on a street corner.
You may not post replies
Forum Jump
Back to top
© 2007 FullSizeBronco.com
Powered by FSB
