Ford Bronco Forum - View Single Post - SAS NEWBIE QUESTIONS - NO FLAMING ALLOWED
post #15 of (permalink) Old 02-13-2007, 04:08 PM
va92bronco
va92bronco's Avatar
Bronco Info: 93 Bronco 357W carbed, C6,NP205, 9inch rear(detriot), SAS D44 (ARB), 6 inch lift with 35" BFG KM2
Originally Posted by Ralphenstein View Post
That doesn't include TRE's though, and that price is for just the tie rod, the drag link would be comparable, so their prices are comparable to Stonecrusher's in the end. Plus these guys use the weld in adapters...I am not sure how I feel about those...
I think that I am going to give the guy from Stonecrusher a call to see if he'll build a set with Chebby TRE's instead of heims. He mostly does Bronco work AFAIK.
Thanks fo the links!
The $123 is for 4 adapters,four jam nuts, and two three foot runs of tubing(but you need four feet for the tie rod now that I think about it so the cost will be $133.
The stonecrusher set up is pretty good if you can use TRE's.
va92bronco is offline
