my 9200 ranger build!! - Ford Bronco Forum
post #1 of 215 (permalink) Old 04-10-2011, 11:32 PM Thread Starter
bcbailey25's Avatar
Bronco Info: traded for BIG project
so as most of you may know i used to have a bronco but it started throwing way too many problems at me and it wasnt the right offroad vehicle for my current likings. though i did LOVE my bronco i just didnt have enough money to make a fullsize into a prerunner. so i traded my bronco for a 1992 ford ranger. it has 12" king dual rate c/o's w/ 330 over 550lbs in the front and 16" king double bypass piggybacks sitting over deaver long travel race pack in the rear. it has 3" over beams with extended radius arm mounted to a solo tranny x-member. also 4.56 gearing in a stock ranger 8.8, a 32gal jaz fuel cell and a ford 4.0 v6. but with anything i ever buy, it needs work. all the parts are there for a good mild prerunner but the execution just wasnt. ill let some pics do the talking.
Bringing it home.
Bye bye bronco
has been measured at 15" travel in the front and 18" in the rear..for now
the interior is was gutted minus sparco seats, a dash, and a little center console. this is after i started tearing into it.
despite what the PO says the truck was layed on its side at one time and broke the bedside mount and he "attempted" to weld it back on. one little wiggle and it broke off and left this.
he decided to wire the fuel pump and the tranny cooler relay with speaker wire.
a mess of useless wires pulled from under the center console.
cleaned up a little.
after doing all this work to the ranger i tried to register it and found out the back reg is $938!!!!! i said hell no!! so killing 2 birds with one stone, i decided a cab swap will fix my reg. problem and give me a non-damaged cab. yesterday the cab swap took place thanks to the help from Marc (worldclasssniper), Vic (Spectre), and my GF. pics of yesterdays activities will be posted shortly (currently uploading)
FUTURE PLANS:
-finish cab swap
-5" over beams
-swing steering
-9" rear end
-have fun!!
projects are never done so this list will always be changing.
ENJOY!!!
WEST COAST BRONCO MAFIA
...with my little ranger tagging along.
MY 9200 RANGER BUILD
bcbailey25 is offline
post #2 of 215 (permalink) Old 04-10-2011, 11:41 PM
I did all for the Nookie
huggyb1972's Avatar
I will be tuned in
FOTM DEC. 2011
huggyb1972 is offline
post #3 of 215 (permalink) Old 04-11-2011, 12:07 AM Thread Starter
bcbailey25's Avatar
so as stated above, yesterday we did the cab swap on my truck. we started around 8am and it turned out to be the perfect day weather wise for the swap. we started the day with a running truck and by the end of the day we had to tow it to where it has to sit. the original cab is a 1992 and the cab that we swapped on is a 2000, hence the nickname 9200 ranger. here are the pics..
for all of the pics and to see the final result check out the my supermotors page
the truck as of 7am
popped the doors off and Marc showed up and we dug in.
then vic showed up and the fun began
got the girlfriend involved too (she loved it)
the old coming off
at one point that was the little piece stopping the cab from destroying the rest of the truck
marc gets his money's worth out of cut off wheels
poor body work by the PO. BTW thats all bondo!!
post #4 of 215 (permalink) Old 04-11-2011, 12:46 AM
Spectre's Avatar
Bronco Info: 78 Bronco 400/C6
Where are the rest of the pics? I know there are some sketch pics out there. =)
Vic - W6VIC
1978 Ranger Bronco XLT 400/C6 with only 33's =(
2001 F250 - 6" SL. 37" tires Goliath
2007 Yamaha R1 Ricochet
Spectre is offline
post #5 of 215 (permalink) Old 04-11-2011, 12:54 AM
huggyb1972's Avatar
What was all the bondo in the bedside?
FOTM DEC. 2011
post #6 of 215 (permalink) Old 04-11-2011, 12:57 AM Thread Starter
bcbailey25's Avatar
bree has some on her phone i think ill have to get them off that.
no the bondo was on the cab under the extra cab window.
post #7 of 215 (permalink) Old 04-11-2011, 03:31 AM
dude that bondo looks like its .5 or .75 of an inch thick? I thought bondo was for a very small skim coat something like .05 or .10 of an inch.
dagamore is offline
post #8 of 215 (permalink) Old 04-11-2011, 05:12 AM
88LiftdBronco's Avatar
Bronco Info: 1988 Bronco Custom, 306 5.0L I6, ZF5 Manual, and the rest is under construction
Bondo should AT THE THICKEST an 1/8" from what I knew. I'd never put a thick coat of bondo on ANYTHING lol
Nice truck nonetheless
They're like the Chuck Norris of engines.
88LiftdBronco is offline
post #9 of 215 (permalink) Old 04-11-2011, 07:36 AM Thread Starter
bcbailey25's Avatar
yeah we were all shocked when we saw how thick the bondo actually was on the side. i cant believe someone actually thought that was ok.
post #10 of 215 (permalink) Old 04-11-2011, 08:33 AM
Mud God - R.I.P.
Rockford514's Avatar
Bronco Info: 66,79,79,87
NICE progress guys Keep it up !
Buddy
Rockford514 is offline
post #11 of 215 (permalink) Old 04-11-2011, 09:13 AM
Spectre's Avatar
But remember the PO swore it had never been rolled or laid on it's side.
Vic - W6VIC
Spectre is offline
post #12 of 215 (permalink) Old 04-11-2011, 10:15 AM
lol dumba$$... (not you guys, the PO)
post #13 of 215 (permalink) Old 04-11-2011, 10:18 AM
4:20 Enthusiast!
Northernguy's Avatar
He wasn't wearing a helmit and tends to forget about some details now!
Great build so far!
Northernguy is offline
post #14 of 215 (permalink) Old 04-11-2011, 10:28 AM
lifeizhard102205's Avatar
i have to admit...at one point in time i actually thought it didnt matter how thick the bondo was either. no one told me other wise at the time. i've learned over the years and if it wasn't for all the other evidence that it'd rolled and he wasn't lying to cover it up i'd say forgive his ignorance. but in this case i can't. guess the point i'm trying to make is we were all noobs once.
lifeizhard102205 is offline
post #15 of 215 (permalink) Old 04-11-2011, 11:05 AM Thread Starter
bcbailey25's Avatar
very true we are all newbs once but at least own up to the fact that it was rolled/layed over. anyways, thanks for all the positve comments. i hope this thing turns out better than i ever hope...but then again dont we all lol.
post #16 of 215 (permalink) Old 04-11-2011, 12:43 PM
Worldclasssniper's Avatar
Bronco Info: 92XLT D60/10.25 Disks 9 in 40's 351 jba headers k&n intake warn hubs Edelbrock Performer heads
The bondo was almost as thick as a quarter, not laying flat. It was ridiculous. I think Ian kept a few pieces. What happened to all the pics, you said there were like 85. I think I saw maybe 10...
Any idea what you are gonna do with the wiring yet...
My Build
Built not Bought!!
Worldclasssniper is offline
post #17 of 215 (permalink) Old 04-11-2011, 12:48 PM
navynuke's Avatar
another way to avoid those fee's is to get someone to register it in AZ for 6 months or so.
should wipe them clean.
is it beer 30 yet???
build thread
navynuke is offline
post #18 of 215 (permalink) Old 04-11-2011, 01:36 PM
I need that for my big truck...
My Build
Built not Bought!!
post #19 of 215 (permalink) Old 04-11-2011, 02:11 PM Thread Starter
bcbailey25's Avatar
here are the pics..
there are the rest of the pics.
navynuke- i could have done that but then id be stuck with a crappy cab and a small build thread!! lol
post #20 of 215 (permalink) Old 04-11-2011, 02:11 PM
"Bronco" John Galt's Avatar
Bronco Info: 87 FSB, Tru-Trac, Eaton Posi, built 306, MAF, 4" Pro Comp, 33" BFG
Looks like you guys did a hell of a job!
X2 on post up more pics here. I hate going over to another site like Supermotors and navigating through a bunch of pics. Would rather just click on the thread here, and scroll down and see it. Also helps if you have commentary/questions on particular pics.
"Bronco" John Galt is offline
HTML code is On
