GOOD EATS - Ford Bronco Forum
 25Likes
post #1 of 29 (permalink) Old 07-03-2019, 08:33 PM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
GOOD EATS
I spent the last three hours making these up. There a lot of work to make, but there good eatin'. I know the Mass, RI, NY, NJ and Maine guys will know what they are, but curious if you other Midwestern guys know what they are.(there's one missing 'cause I was hungry)
curtwow likes this.
MY BUILD THREAD
cobrajoe is offline
post #2 of 29 (permalink) Old 07-03-2019, 08:41 PM
MS88Bronc's Avatar
Those look damn good. I don’t think I’ve ever seen those, but I’ll wager a guess and say Deviled Clams, since they look like deviled crabs, which I’m very familiar with.
MS88Bronc
Don't be fooled by the name,
4.56 gears with lockers
-->My Build Thread<--
MS88Bronc is online now
post #3 of 29 (permalink) Old 07-03-2019, 08:49 PM
MidlifeCrisisUndrWay
CDA 455's Avatar
Bronco Info: '94 XL/2"front spacer/1ton TRE Flip/Upgraded E4OD(To PSD specs)/2"rr lift blk/5100 Bilstein/33"BFGs.
<-----Baltimorian
Crab cakes.
μολὼν λαβέ
CDA 455 is offline
post #4 of 29 (permalink) Old 07-03-2019, 08:53 PM
CDA 455's Avatar
This thread brought to you by:
JACK DANIELS
It's not just for breakfast anymore!
silver70, cobrajoe and BroncMom like this.
μολὼν λαβέ
CDA 455 is offline
post #5 of 29 (permalink) Old 07-03-2019, 09:02 PM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
Originally Posted by CDA 455 View Post
<-----Baltimorian .
43rd 'Gem' State=Idaho
Baltimore?
MY BUILD THREAD
cobrajoe is offline
post #6 of 29 (permalink) Old 07-03-2019, 11:51 PM
Eric
Bronco Info: '88 BKO XLT, 5.0, AOD, welded 8.8, carbon 4L10, 33's, Lightning headers, Saginaw, 3G
The local grocery store sells things that look similar to those but are much smaller... and sadder-looking.
I think they're crab cakes. I dunno though. I live in the desert. Things like "snow" and "the ocean" are foreign concepts to me.
However, they seem to be some kind of seafood (shells are a dead give-away) item and look like they would go great with a Corona.
cobrajoe likes this.
silver70 is online now
post #7 of 29 (permalink) Old 07-04-2019, 06:33 AM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
HINT:
MY BUILD THREAD
cobrajoe is offline
post #8 of 29 (permalink) Old 07-04-2019, 07:13 AM
MS88Bronc's Avatar
Well of course they’re clams - I’ll try again. Clam cakes?
MS88Bronc
post #9 of 29 (permalink) Old 07-04-2019, 07:27 AM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
Technically its called a Q _ _ _ _ _ _
Although both are a type of clam, we call the one pictured on the right a Clam
MY BUILD THREAD
cobrajoe is offline
post #10 of 29 (permalink) Old 07-04-2019, 07:35 AM
MS88Bronc's Avatar
Ok the quahog.
MS88Bronc
post #11 of 29 (permalink) Old 07-04-2019, 07:50 AM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
@MS88Bronc they are called Stuffed Quahogs. They are made by steaming the quahogs in beer, sazon, olive oil and garlic until they open up.
Then they are separated from the shells, chopped up and then placed back in the "broth" from steaming. Next you fry some Portuguese ground up Chourico in olive oil. Add chopped garlic, onions and peppers until tender. I strain the chopped quahogs and add them back into the mix. You can use bread crumbs, but I use croutons that I run through the food processor and dump them into the pan (I use a BIG pan) Add some Worcestershire, some hot pepper flakes, some more olive oil, chopped parsley and mix thoroughly. I then ladle in the broth until I get a thick paste consistency, something that you can pack into the half shell. I taste and adjust my seasoning as needed. Remove it from the heat and separate and clean your bigger shells so you can use them to make the stuffies. Pack your mix firmly into the shells and bake at 350° for 20-30 minutes to get a "crust" on the top. When done, add a pad of butter and grab a bear.
BigAggie likes this.
MY BUILD THREAD
cobrajoe is offline
post #12 of 29 (permalink) Old 07-04-2019, 08:01 AM
MS88Bronc's Avatar
I’ll reiterate my previous statement - those look damn good. I grew up in Charleston SC and used to throw cast nets for shrimp and leave out pots for blue crab. The blue crabs along the SC coast aren’t huge, so one of the things we would do is grind up all the crab meat and do something similar and stuff the crab’s body with a similar concoction - Deviled Crabs. I’ve never experienced the stuffed Quahog - but I bet it’s delicious.
MS88Bronc
post #13 of 29 (permalink) Old 07-04-2019, 08:16 AM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
Thanks.
I love crab meat, nice and sweet, actually enjoy it more than lobster. We make the same thing here except we call them Crab cakes.
I also like to steam them whole in beer and eat them with some melted butter.
Weber likes this.
MY BUILD THREAD
cobrajoe is offline
post #14 of 29 (permalink) Old 07-04-2019, 08:22 AM
MS88Bronc's Avatar
Ah I see. We also had crab cakes, but they were more like “crab croquets” as they did not use the shell to hold them - more of a patty.
MS88Bronc
post #15 of 29 (permalink) Old 07-04-2019, 10:15 AM
CDA 455's Avatar
Baltimore?
Navy brat.
Born in Baltimore, MD
Lived in:
VA
MS
CA
ID
AZ
ID
Swam on both sides, as well as in the central, Pacific Ocean.
Swam in Western Atlantic Ocean.
Swam in the Northern and Western Gulf of Mexico.
μολὼν λαβέ
CDA 455 is offline
post #16 of 29 (permalink) Old 07-04-2019, 10:37 AM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
Navy brat.
That explains A LOT!
MY BUILD THREAD
cobrajoe is offline
post #17 of 29 (permalink) Old 07-05-2019, 08:19 PM
Eric
... When done, add a pad of butter and grab a bear.
This is terrible advice. Have you seen the size of those things? I think I'll just have that Corona I mentioned.
Weber, BigBlue 94 and curtwow like this.
post #18 of 29 (permalink) Old 07-05-2019, 09:04 PM Thread Starter
Ford-a-Holic
cobrajoe's Avatar
Lol, I hate auto correct. My bad, BEER
curtwow likes this.
MY BUILD THREAD
cobrajoe is offline
post #19 of 29 (permalink) Old 07-10-2019, 10:52 AM
elpancho's Avatar
Bronco Info: 1996 XLT, 351W, E4OD/BW1356, BFG 33x12.5 KM2
elpancho is offline
post #20 of 29 (permalink) Old 07-10-2019, 02:58 PM
paul rondelli's Avatar
Bronco Info: 1993 XLT 4:56 gears, Detroit locker, 35 inch BFG mud radials. 1996 XL 302, all manual
They look wickad.
Next thing you know you will have a some smelts fried up.
Watched the HBO series about that crazy bitch that texted the 18 year old kid about suicide until he killed himself last night. I'm sure you know all about it since it happened right around you.
paul rondelli is offline
