Headlight Cleaner/Restorer - Ford Bronco Forum
 2Likes
  • 1 Post By MikeW
  • 1 Post By MikeW
post #1 of 6 (permalink) Old 09-21-2019, 02:40 PM Thread Starter
JScatt's Avatar
I got a set of used headlights to replace the ghetto aftermarket ones on my Mustang.
As you can see they are cloudy but not that bad.
Was looking for some recommendations on cleaning/restore kits. Not sure if I really need one of the kits with sandpaper and drill attachments etc.
Thanks!
-Archie Bunker
bron·co/ˈbräNGkō/
Noun:
JScatt is offline
post #2 of 6 (permalink) Old 09-21-2019, 04:00 PM
The Tennessee Warden
MS88Bronc's Avatar
I don’t know if it works, but I’ve heard about people using insect spray, like “OFF”.
MS88Bronc
Don't be fooled by the name,
1996 XL - 5.8L/E4OD/BW1356/4.56s
Sept 2019 FOTM
-->My Build Thread<--
MS88Bronc is online now
post #3 of 6 (permalink) Old 09-21-2019, 05:48 PM
Bronco Info: 1993 Bronco Custom Trim - 302 Stock - E4OD Transmission
Walmart Auto dept has offered a headlight restore service for a while. They charge $30 to do it around here. Came out decent on a project I was doing with headlights I didn't really care about but they also didn't mess up. Check out if the Wally in your area does it.
1993 Ford Bronco Custom Trim w/ 302 V8
pollux is offline
post #4 of 6 (permalink) Old 09-21-2019, 09:48 PM
In Front of Jopes
MikeW's Avatar
Bronco Info: Need $$$ to restore 1996, and DD is 2001 F-350 PSD
I used this 3M headlight restoration kit with two different vehicles, I recommend it.
Yes, you will need a drill.
First get toothpaste and a bunch of wet wipes, rub in toothpaste in circular motion and then rinse off.
Then use the headlight restoration kit.
https://www.amazon.com/3M-39008-Head...95993833&psc=1
Thanks!
JScatt likes this.
MikeW is offline
post #5 of 6 (permalink) Old 09-21-2019, 10:04 PM Thread Starter
JScatt's Avatar
I'll give it a try! I was trying to avoid using a drill because they aren't installed on the car so I'll be working on a bench, thinking they will be hard to hold and work the drill at the same time, I'll figure something out
-Archie Bunker
bron·co/ˈbräNGkō/
Noun:
JScatt is offline
post #6 of 6 (permalink) Old 09-21-2019, 10:52 PM
In Front of Jopes
MikeW's Avatar
Its best to have the headlights out anyway, cover up any holes so the compound doesn't get into the inside of the headlamp. Put them in a woodworking style bench vise.
JScatt likes this.
MikeW is offline
  Ford Bronco Forum > Off Topic Section > Anything Else
