Transmission Vent - Ford Bronco Forum
post #1 of 8 (permalink) Old 02-11-2009, 10:12 PM Thread Starter
Apache0715's Avatar
Bronco Info: 1987 XLT, Locked 9"/Posi D44 SAS, 4.10s, 351W/C6 37" STT 1995 XLT 6" lift, 351W/E4OD 35" AT
Transmission Vent
There used to be a link in the Tech pages on 2bigbroncos website and Soderbloms, but it is not available anymore. I am trying to figure out how to change the current vent on my C6 transmission to a barb fitting so I can extend the lines. Does anyone have a recommendation and or pics?
Apache0715
1987 Ford Bronco XLT362W/C6 Holley 4bbl Edelbrock Performer, Comp cams
8" SAS Lift, 37" Discoverer STT
D44 Eaton Posi 4.10, Strange 9" 35sp Detroit 4.11
3G Alt and hydroboost
1995 Ford Bronco XLT; 351W, E4OD, 6" Lift, 35" BFG AT
Apache0715 is offline
post #2 of 8 (permalink) Old 02-11-2009, 10:47 PM
Former owner of Shadofax
Is there some reason you can't make the stock C6 vent work? on the E4OD it's not barbed either, it might have had a little "bulge" at the end, can't really remember, but I just left it and put a piece of tubing on it after I had put a little sealant on the outside vent walls.
post #3 of 8 (permalink) Old 02-12-2009, 06:31 PM Thread Starter
Apache0715's Avatar
Its a weird fitting, almost like a screw head with a hole in the center, I removed the cap, its about 7/16 round and 3/8 long. Im sure I could rig something but I would rather put a barbed fitting in it so I know its proper. Oh and yes I tried "unscrewing" it, but it doesn't do anything but spin.
Apache0715
post #4 of 8 (permalink) Old 02-12-2009, 06:54 PM
rolling Rolling ROLLING....
Bronco Info: 98 TJ
I did not need to change the vent fitting on mine...just ran a longer hose and small hose clamp.
Tim
Newest token Jeep owner....
Redwagon is offline
post #5 of 8 (permalink) Old 02-12-2009, 11:32 PM
79BlueMule's Avatar
Bronco Info: 400/c6 wide ratio, 40" boggers with 6" lift soon to be 10"
its some kind of funky press in deal on a c-6. i used a screwdriver to turn mine, then i could pull it out. then i replaced it with a 90* fitting that was plastic and would have a press in fit. then i aimed the fitting towards the bellhousing and clamped the hose onto that. hope this helps
"The Blue Mule" 79 F150 - 400 w/ performer intake and carb, built wide ratio c6, 6" with 37" pit bull rockers.
soon to come... 4.56's and heim steering
79BlueMule is offline
post #6 of 8 (permalink) Old 05-15-2019, 07:49 PM
where exactly is the vent located on the trans 4EOD
[email protected] is offline
post #7 of 8 (permalink) Old 05-15-2019, 08:58 PM
fordbronco1995's Avatar
Bronco Info: 95 Ox White/Blue Int 5.8L 2 Level 33" Ridge Grapplers 17x9 M/T Classic IIIs Punisher Valve Body
Reach up around the trans, its on the top, its a check valve cap, you can feel it but not much room to get to it
EVERYTHING MANUAL EXCEPT THE TRANSMISSION:
fordbronco1995 is offline
post #8 of 8 (permalink) Old 05-16-2019, 09:30 AM
Yo corn,
As fordbronco1995 righteously advised!
E4OD Vent pic
Aftermarket replacement vent by https://www.transmissionpartsusa.com
Reviews:
"... easy to get to if you are willing to pull your carpet. There is a very convenient access panel in the center there and it makes reaching the top and sides of the tranny very easy..."
Source: by gunterelectric226 at FSB
And, "go inside the cab, and pull the carpet up so that you can unbolt and pull off the E4OD floor cover plate. You will then clearly see the little cap. get that off CAREFULLY, would not want any junk falling down into the breather hole.
...as I recall it has a little breather "hat" on it, which I had to remove"
... I was able to get that top hat of it off, leaving just a short tube, which I then attached a small breather hose to and ran up into the engine compartment."
by Shadofax
"...you can pop the trans tunnel cover and look at it. its a crimped on cap that allows excess fluid to boil out when it over heats." by jowens1126
