Code 33 - EGR Valve Fault/ Not Closing - Ford Bronco Forum
post #1 of 13 (permalink) Old 05-27-2010, 04:05 AM Thread Starter
My Bronco Isn't My Only
WuTang's Avatar
Bronco Info: 1988 Ford Bronco 302 AOD|1993 Ford F-150 302 E4OD
I was finally able to pull codes on my '88 which has been running like garbage once it gets warmed up and seems to almost die when I give it throttle.
Pulled codes and the only one I got was a 33.
I don't really have the cash to run out and just buy a new one and would like to attempt to clean it first. I did do a search first and found this thread, but it only talks about a way of cleaning it with a drill bit? Is there any other way?
Originally Posted by B-man View Post
I dont' care about gas mileage. I am broke as hell, and I will STILL drive my gas guzzlin, smog pollutin FSB.
Originally Posted by paintballdude902 View Post
the only way to say goodbye to a bronco is a viking style ceremonial burning. climb inside, lock the doors, turn on stair way to heaven and light a match.
WuTang is offline
post #2 of 13 (permalink) Old 05-27-2010, 04:25 AM
Satyr of the Midwest
SigEpBlue's Avatar
I'd try testing the EVP sensor on top of the valve, first. The code means it's trying to open the EGR valve, but it's not able to tell that it's opening. That's why you're getting that stumble: the PCM is trying to get it open by applying a greater vacuum signal, and it is probably doing so to an excessive amount because it doesn't have any clue it's really opening.
SigEpBlue
SigEpBlue is offline
post #3 of 13 (permalink) Old 05-27-2010, 06:17 AM
green ones make me horny
imlikeojnow's Avatar
test both the EVP And EGR sensor, and see which one is bad and go from there. also check and make sure your vaccuum lines going to it are good to go as well.
imlikeojnow is offline
post #4 of 13 (permalink) Old 05-27-2010, 09:50 AM
yo
x3
Location pic in an 89 5.0 (part of his valve cover and oil pan gasket job); Miesk5 Note EVP is light gray & attached to the top of the EGR Valve
Source: by Waltman at SuperMotors.net
Please VOTE in our Full-Size of the Month (F.O.T.M.) & Full-Size of the Year (F.O.T.Y.) Contests @ https://www.fullsizebronco.com/forum/27-f-o-t-m-voting/
post #5 of 13 (permalink) Old 05-27-2010, 05:59 PM Thread Starter
WuTang's Avatar
Are you sure? The fault code says not closing properly.
How do I do this?
yo
x3
Thanks, pictures always help
WuTang is offline
post #6 of 13 (permalink) Old 05-27-2010, 06:07 PM
rla2005's Avatar
DTC 33 indicates the valve opening is not detected: Two Digit Codes 33-58
rla2005 is offline
post #7 of 13 (permalink) Old 05-27-2010, 06:11 PM
rla2005's Avatar
You can test the EVP signal feedback with a volt/ohm meter. You can use a handheld vacuum pump/gauge to measure and apply a vacuum to the EGR valve. Reference this for how the EVP works and the expected output: EGR Valve Position sensor (EVP)
rla2005 is offline
post #8 of 13 (permalink) Old 05-28-2010, 12:24 AM Thread Starter
WuTang's Avatar
I have a Ford Code Reader and under code 33 it states Code 33 (cars only) EGR Vavle not opening correctly, Code 33 (trucks only) EGR Valve Fault / not closing properly.
Incorrect?
WuTang is offline
post #9 of 13 (permalink) Old 05-28-2010, 12:41 AM
Bronco Info: 93 XLT 5.0
Mine was throwing that code when the vacuum line to the EGR valve/sensor was broken. Replaced the line and it's all better now.
pappabacon is offline
post #10 of 13 (permalink) Old 05-28-2010, 10:08 AM
DTC 33 is triggered when the EVP sensor is not closing; so EZiest & cheapest checks are to inspect & repair/replace repair any bad vac lines
then do what our pal RLA Advised if vac lines are ok
for a <$ vac line test; I pull em off and use the straw sucking (here we go w/da comments..lol) test; one finger over one end and ...ya know?
post #11 of 13 (permalink) Old 06-01-2010, 04:58 AM Thread Starter
WuTang's Avatar
How would I test the EGR sensor? Is it located INSIDE the EGR?
Where would I place the leads? Sorry, very new to testing sensors and whatnot.
Is there a cheaper alternative to a vacuum pump other than using your mouth? The one I found at Autozone is about $55.00 and that seems a bit expensive.
I think I may be over thinking this, but the vacuum line comes off of the EGR and leads down into a cluster of other vacuum lines. Is there a way to separate these easily without tearing the whole thing apart so I can test the lines?
Maybe I'm missing something obvious?
WuTang is offline
post #12 of 13 (permalink) Old 06-01-2010, 06:59 AM
It is on Top of the EGR Valve as shown in this pic in an 88 5.8; Miesk5 Note EVP is light gray & attached to the top of the EGR Valve
Source: by Travis L (kemicalburns) at SuperMotors.net
No problem; we were all at that point at least once in our lives;
EVP Connector pin-Out Diagram
by Ryan M (Fireguy50)
Testing & Operation; "...The EGR Valve Position (EVP) sensor monitors the position of the EGR valve pintle. The EVP sensor converts the mechanical movement of the pintle into an electrical voltage signal which is relayed to the PCM. The EVP sensor is a linear potentiometer in which resistance varies with the EGR valve pintle movement.Voltage is fed to the EVP by the signal return circuit. As the EGR is opened the EVP directs more voltage to the EEC and less down the voltage reference circuit. The EVP sensor provides the PCM with information on EGR flow and EGR system failures. The EVP should read between 0.24 and 0.67 volts at idle with a closed EGR valve..." read more
Source: by Ryan M (Fireguy50) at http://fordfuelinjection.com/index.php?p=35
Testing; "...Using the Haynes manual's procedures, you should be able to back-probe the EVP line and ascertain whether the EVP voltage is correct. It should be below 0.67V @ zero vacuum on the EGR, slowly increasing with applied vacuum from a hand pump. DO NOT apply more than 10 in-Hg to the valve..."
Source: by SigEpBlue (Steve) at FSB
Testing & Operation
Source: by Tomco Inc. tomco-inc.com
Vacuum Pump Build Plans, DIY; built for less than $20, we call it the "Cheap Little Sucker"
Source: by Jame R and Tim C at http://www.berkut13.com/sucker.htm
Vacuum Pump Build Plans, DIY; convert a tire inflator-type air compressor into a vacuum pump
Source: by drcrash at http://www.instructables.com/id/conv...ressor-into-a/
Vacuum Pump Build Plans, DIY; make a manual vacuum pump for under $20 by converting a bicycle pump
Source: by drcrash at http://www.instructables.com/id/make-a-manual-vacuum-pump-for-under-$20-by-convert/
Isn't that vac line from EGR Green?
depiction by Fireguy
you can do it w/out puling lines apart... need to lok at your VECI label for the vac diagram
I forget your eng type...
Will bbl.
post #13 of 13 (permalink) Old 06-01-2010, 08:51 AM
pfun41's Avatar
i had code 33 too, the vacume line to the egr had a hole chaffed in it.
pfun41 is offline
