Brake Fluid - Ford Bronco Forum
post #1 of 23 (permalink) Old 05-10-2012, 02:57 PM Thread Starter
Brake Fluid
I have a 1980 bronco, When I got in it today I felt very little pressure on the brakes so I poped open the Master Cylinder and its pretty low on fluid. Anyways the question is you just pour some fluid into it until its full? Also should be a certain brake fluid im buying for it?
Timtim89 is offline
post #2 of 23 (permalink) Old 05-10-2012, 03:08 PM
Yes, add some DOT3 fluid ASAP. Then start diagnosing WHY it's low. Is there a leak? Are the rear cables or autoadjusters stuck? Or are the front pads worn? For more info, click my black Bronco in my signature & read the captions in the Brakes & Hubs album.
post #3 of 23 (permalink) Old 05-10-2012, 03:10 PM
Madcat455's Avatar
Bronco Info: 89 XLT daily driver
Short answer... DOT3 fluid, and yea... About 1/4 from full.
Long answer... You don't "use" brake fluid, it had to go somewhere... You need to find where before you drive it. Its hard enough to stop a 6,000lb beast, you don't need to try with a busted line as well.
Madcat455 is offline
post #4 of 23 (permalink) Old 05-10-2012, 03:12 PM
Bronco Info: 1989 Eddie Bauer
The fluid went somewhere. It may be a good time to do a good inspection, correct the problems and flush the the system. I flush the fluid about every 18 months. Just my .02
Motion is offline
post #5 of 23 (permalink) Old 05-10-2012, 03:20 PM Thread Starter
Well the cylinder itself is around 20 years old this truck has work to do on it, My father and I havnt really had any time to work on it much but its gettin done little by little.
Timtim89 is offline
post #6 of 23 (permalink) Old 05-10-2012, 03:39 PM
deadmans bronco's Avatar
Bronco Info: 1984 5.8 351w c6 np208f
ya i got a leak to but it aint that bad i just check it every few days to make sure it is good but i think my leak is from the lid on the mc cheap ebay parts i know u get what you pay for
deadmans bronco is offline
post #7 of 23 (permalink) Old 05-10-2012, 04:56 PM
4DI2D's Avatar
Bronco Info: '93 Custom, '90 Lincoln TC 302, E4OD, 31s, posi front diff,QFL
Synthetic DOT 4 works like a charm and improves the safety factor.
Only DOT 5 can't be used with any other fluid.
4DI2D is offline
post #8 of 23 (permalink) Old 05-10-2012, 05:33 PM
Yes, calipers "use" brake fluid temporarily. When you change the pads, the fluid returns to the MC.
post #9 of 23 (permalink) Old 05-10-2012, 05:46 PM
95bronco12's Avatar
Bronco Info: 1995
Breaks who needs em!
Deffently look around and check for leaks also check pads.
95bronco12 is offline
post #10 of 23 (permalink) Old 05-11-2012, 06:12 AM
When changing pads/shoes it bad practice to "push" the old fluid from the caliper/wheel cylinders back into the system, it's better to open the bleeder and expell the old into a container and refill the system with fresh fluid. Just my .02
Motion is offline
post #11 of 23 (permalink) Old 05-11-2012, 10:54 AM
Roller rockers are gay
TheUnforgiven's Avatar
no it isn't. brake fluid doesn't go bad, it just gets dirty and laden with water. that doesn't mean it won't work, it just lowers the boiling point.
and that fluid doesn't stay just in the calipers, it is fluid and will move around the system.
if the system is fine (not the case in the OP's post) without leaks or anything, there's no reason to open the system just to replace part of the fluid. full flush? fine, but just to save from pushing the fluid back up no.
New nuts are in the plan.
TheUnforgiven is offline
post #12 of 23 (permalink) Old 05-11-2012, 11:06 AM
Madcat455's Avatar
Would ABS be an exception to this?? I've heard from several mechanics that it's a bad practice to push fluid backwards through the ABS module...
post #13 of 23 (permalink) Old 05-11-2012, 11:12 AM
i've never opened a caliper to expel the fluid when replacing the pads, ABS or not. Ever. I've never seen anyone else do that either.
think about it, fluid moves through it to the calipers when you apply the brakes, when you RELEASE the brakes, the fluid flows backwards through the pump/module back to the master cylinder. which is exactly the question you asked. it does that ALL the time every day, every stop. you won't hurt anything.
post #14 of 23 (permalink) Old 05-11-2012, 12:11 PM
Think about it, the volume of fluid used when applying the brakes(thousands of an inch) is way less then the volume of fluid pushed back when replacing the pads (thickness of the new pads). And yes I do believe in changing the fluid (pressure bleeding only) every 18 months regardless weather or not I've worked on the system. Just my .02
Motion is offline
post #15 of 23 (permalink) Old 05-11-2012, 12:37 PM
When changing pads/shoes it bad practice to "push" the old fluid from the caliper/wheel cylinders back into the system...
Not according to Ford.
...it's better to open the bleeder...
That's how you get contamination & air into the system: by opening it unnecessarily. Don't.
Not in Ford HCUs, but MOST other brands (especially GM) can be totally destroyed by pushing fluid backward. So almost all OTHER brands of vehicle w/ABS require that the bleeders be opened when changing pads. But never Fords; ABS or not.
post #16 of 23 (permalink) Old 05-11-2012, 02:13 PM
That's how you get contamination & air into the system: by opening it unnecessarily. .
The system is open to atmosphere thru the vent int the master cylinder cap, which is why periodic flushes are necessary. Just my .02
Motion is offline
post #17 of 23 (permalink) Old 05-11-2012, 05:19 PM
Former owner of Shadofax
I don't believe the cap is vented.
post #18 of 23 (permalink) Old 05-11-2012, 05:33 PM
4DI2D's Avatar
If the m/cyl cap wasn't vented it would blow off the top when you put the jumbo screwdriver in to push the caliper pistons back!
4DI2D is offline
post #19 of 23 (permalink) Old 05-11-2012, 05:41 PM
I don't know about the jumbo screwdriver, I use a c clamp, but that makes sense, except it seems to me the cap must be pressure activated, meaning after a certain amount of pressure in pressing the pads in and forcing fluid back into the MC it would open and begin to vent. But I don't think it's just "vented". So the only time it would be vented would be when doing brakes, which is when you're opening the cap to play with fluid level anyway.
Edit: I guess it's the cap diaphragm that allows this....."Further, energy is required to open the vent, which results in brake fluid movement delay. Also, brake fluid can leak out through the vent slit."
post #20 of 23 (permalink) Old 05-12-2012, 12:00 AM
DOT3 brake fluid is EXTREMELY hygroscopic, so it's NOT vented. Of course, there's a safety release like the A/C system has, but that doesn't qualify as a "vent", either.
As fluid moves into the calipers due to pad wear, the diaphragm in the cap follows the fluid level down, maintaining a seal between the outside air & the fluid. When you compress the calipers, that fluid moves back to the reservoir. So as long as you have NOT added fluid since the last pad change, it won't overflow the reservoir.
