1995 Bronco 347 MAF Build - Ford Bronco Forum
  • 1 Post By jermil01
post #1 of 17 (permalink) Old 07-08-2018, 03:48 PM Thread Starter
Bronco Info: 1995 EB 5.0 MAF E40D
Hello Everyone,
I’m currently in the process of collecting parts and knowledge to complete a 347 and MAF swap into my 1995 EB SD 302 E40D. On some what of a budget before Aug 15.
Parts
347 long block with ported GT40 heads ( orderd )
10 psi fuel pressure regulator ?
Fiveology MAF ecu and wiring kit ?
Pro m 19 lb/hr calibrated 75mm Mass Air sensor ?
Bassini y pipe?
Questions
Will I be able to tune the SD system? if not is it possible to tune the MAF kit without SCT, Quarter horse or Tweecer?
Is it worth upgrading the stock injectors or intake system to the typhoon intake?
The final all encompassing question is there anything that I am missing other than photos that will be posted during the build?
lp670SV is offline
post #2 of 17 (permalink) Old 07-09-2018, 11:59 AM
aka: kemicalburns
TravisITGuy's Avatar
your 95 bronco should already be MAF with 302. 94+ bronco XLT, Eddie's etc.. had mass air. the XL models didnt i guess though. you can go to a wrecking yard and get the wiring harness from a 94-95 MAF bronco, grab the computer also.
The stock intake will work and the gt40 heads will probably be more of the bottle neck. What cam are you planning to run? I assume you already have headers and free flowing exhaust?
24lb injectors will probably also be necessary.
TravisITGuy is offline
post #3 of 17 (permalink) Old 07-09-2018, 06:39 PM Thread Starter
Sadly the truck has duel intake runners. Will a stock MAF system be able to keep up with the 347? The engine currently has a trick flow .499/.510 cam. Thank you for the reminding about the exhaust. Are there any cheaper alternatives to the bassini y pipe?
Thank you for your time
lp670SV is offline
post #4 of 17 (permalink) Old 07-09-2018, 07:21 PM
aka: kemicalburns
any MAF will require tuning, starting with the stock wiring etc.. would be cheaper.
Headers, hi flow cat, have a shop build a custom mandrel bent y pipe (2.5") into single 3" exhaust.
post #5 of 17 (permalink) Old 07-09-2018, 10:02 PM Thread Starter
Thank you for the advice regarding the exhaust. Will tuning require an sct etc..?
lp670SV is offline
post #6 of 17 (permalink) Old 07-11-2018, 12:31 PM
aka: kemicalburns
you would want to ask the shop that will be doing the tune for you. You also shouldnt need an adjustable fuel regulator. the stock regulator will be fine.
post #7 of 17 (permalink) Old 07-11-2018, 03:34 PM
Charlie don't surf!!
If you're going to tune it or use a tuner, you'll want the adjustable FPR..most tunes will require you to bump the pressure up a bit.
TravisITGuy likes this.
jermil01 is offline
post #8 of 17 (permalink) Old 07-11-2018, 04:16 PM
aka: kemicalburns
Good call Jermil01
post #9 of 17 (permalink) Old 07-11-2018, 04:45 PM
Here's a great link that explains the right way to size injectors..keep in mind you're not going to be running at 100% duty cycle.,.
https://lmr.com/page/Mustang-Fuel-Injector-Size-Guide
jermil01 is offline
post #10 of 17 (permalink) Old 07-14-2018, 12:05 AM Thread Starter
After reading the link I think it will be necessary to upgrade to 24lb injectors. Did ford ever make a 24lb injector with 4 ports like the explorer injectors. What parts would you guys recommend for the MAF swap? Thank you for your time.
lp670SV is offline
post #11 of 17 (permalink) Old 07-18-2018, 09:43 PM Thread Starter
This is were my understanding of MAF is at.
Pro m 75mm sensor 24lb (ordering)
Federal way1 cpu ?
1996 wiring harness ?
Am I missing anything?
lp670SV is offline
post #12 of 17 (permalink) Old 07-19-2018, 12:47 PM
aka: kemicalburns
you want an 94-95 XLT-EddieB MAF harness. the 96 harness is OBD-II.. more of a headache.
post #13 of 17 (permalink) Old 07-19-2018, 10:01 PM Thread Starter
Do I need the entire harness or just the engine harness?
lp670SV is offline
post #14 of 17 (permalink) Old 07-20-2018, 07:54 AM
Ford Hoarder
I would call up these guy's and just get one of their kits. https://shop.fiveologyracing.com/198...KIT-FSEMAK.htm
Also if you do get the Pro-M MAF be sure to get the extra transfer function sheet with it, it will come in hand should you want to get your truck tuned later. Pro-M makes nice stuff, I have their 75mm one on my 92.
CrazyBRONCOguy is online now
post #15 of 17 (permalink) Old 08-02-2018, 01:07 PM Thread Starter
The engine got here yesterday and the installation will be taking place next week. Some good news the truck has the stock maf system. Don't ask how I got them mixed up as I am still trying to figure that out.
With that said do I need to modify the existing maf system other than a tune?
Pictures are on there way.
lp670SV is offline
post #16 of 17 (permalink) Old 08-02-2018, 04:37 PM
aka: kemicalburns
should only need a Tune, i would recommend calling some dyno shops and asking some questions.
post #17 of 17 (permalink) Old 08-03-2018, 06:43 PM Thread Starter
OK so I have been shopping for injectors and I am wondering why the fiveology injectors are $150 yet the cheapest 30lb injectors on summit are $320?
lp670SV is offline
