95 bronco front passenger brake line repair (abs fitting) - Ford Bronco Forum
post #1 of 7 (permalink) Old 09-12-2019, 01:50 AM Thread Starter
RLVBronco's Avatar
Bronco Info: 1995 Ford Bronco Eddie Bauer Edition 5.8Liter
Alright guys, I need some help from the experts! So as the title says I have a 95 ford bronco that has or had (I plugged the abs port) broken brake line. Now I do have a brand new rubber line that connects to the caliper I just need the hard line that goes to the abs module or whatever its called and it has a special fitting that I cant find anywhere.
fitting thread pitch for abs pump connection ?
brake line diameter ?
RLVBronco is offline
post #2 of 7 (permalink) Old 09-12-2019, 10:28 AM
Bronco Info: 1995 XLT, 302 - work in progress, currently "Barn Rat" status
I was able to order pre-bent stainless brake lines from LMC that fit. Replaced all of them on my truck but I think you can buy individually.
PhillyFullSize is offline
post #3 of 7 (permalink) Old 09-12-2019, 12:29 PM
wood4d's Avatar
Bronco Info: 96 351 xlt sport, 93 EB 302 , 93 xlt 351 33s, 93 EB 351, 93 custom 302 parts rig
You can take the fitting from the old line and use it again. Just cut the brake line before the flare. Or you can do it in 2 steps, with an adapter bushing from the parts store. I dont remember what size they are but maybe 3/8 to 1/4 and that fits premade brake lines for the fords.
wood4d is offline
post #4 of 7 (permalink) Old 09-12-2019, 02:35 PM
nekkidhillbilly's Avatar
part store will have brake line in varying lengths just bend as needed and the adapters
90 xlt bronco 302 aod (ronco)
07 Silverado 3500 cc lb 6.0
66 buick gs 401 nailhead
nekkidhillbilly is offline
post #5 of 7 (permalink) Old 09-12-2019, 05:35 PM
Bronco Info: 1995 5.8 Eddie Bauer
Sorry I may be confused here but the ABS line no thread pitch, it's a plug and play wire..
https://www.amazon.com/SKP-SK970020-...y&sr=8-1-fkmr0
NYFSB is offline
post #6 of 7 (permalink) Old 09-12-2019, 05:53 PM
that's a wheel speed sensor total different then a brake line? those are just a electrical component that sends a signal to the ecu. no fluid involved. so what exact part are you needing then? the other side of the plug?
post #7 of 7 (permalink) Old 09-12-2019, 07:53 PM
Originally Posted by nekkidhillbilly View Post
that's a wheel https://www.fullsizebronco.com/forum...ml#post7244696 total different then a brake line? those are just a electrical component that sends a signal to the ecu. no fluid involved. so what exact part are you needing then? the other side of the plug?
I get that it's the speed sensor, but RLVBronco said he needs the ABS Line, he has a caliper line so I am confused as to what he really needs. A pic would be helpful..
NYFSB is offline
