Taurus Fan wiring diagram - Ford Bronco Forum
post #1 of 6 (permalink) Old 10-21-2005, 11:27 AM Thread Starter
3 wheeler
nbaff's Avatar
Bronco Info: 98 Z71
I need some approval or maybe even some suggestions on how to make this more efficient.
nbaff is offline
post #2 of 6 (permalink) Old 10-21-2005, 02:54 PM
Try it now!!
kf4amu's Avatar
looks fine to me....whats wrong with it?
kf4amu is offline
post #3 of 6 (permalink) Old 10-21-2005, 04:15 PM
coloranger's Avatar
Bronco Info: 1978 Bronco XLT, 408, 1-ton axles, doubler, 37" Tires on H2 rims
All i would say to do is add a circuit breaker/fuse and go.
Doug
1978 Bronco 408, Edelbrock 4 barrel, Dual Fuel (propane/gas), C6, ORD Doubler, Triple-Stick, D60 open, 14b Detroit, 4.56, 37x12.5x17 on H2 rims, 10K ft winch, 8K rear winch
http://www.superford.org/registry/ve...630&profile=1]
coloranger is offline
post #4 of 6 (permalink) Old 10-21-2005, 05:09 PM
FSB warrior
81Bronk36's Avatar
Ya its perfectly fine, exept add a fuze from the batt to the relay
1BadBronco
81Bronk36 is offline
post #5 of 6 (permalink) Old 10-21-2005, 06:49 PM Thread Starter
3 wheeler
nbaff's Avatar
Bronco Info: 98 Z71
awesome any idea what size fuse?
nbaff is offline
post #6 of 6 (permalink) Old 10-22-2005, 03:27 AM
Southeast Utah Native
Rick3373's Avatar
Bronco Info: 89 XLT
At least a 60 amp maxi fuse or a 80 amp regular fuse. That's what I found I had to use with mine. Anything smaller would blow.
LIFE'S SHORT, PLAY DIRTY!
89 Bronco XLT, 351, C-6.
Understand how your use affects the land.
Adopt minimum impact practices.
Share in the costs of services, education & maintenance.
Rick3373 is offline
