eec ground wire - Ford Bronco Forum
post #1 of 13 (permalink) Old 10-03-2006, 02:58 PM Thread Starter
Bronco Info: 89 bronco 5.8L
Exclamation eec ground wire
89 Bronco 351W EFI/C6
Ok, when trying to start the bronco, the starter only turns the motor over for a second or two and then comes to a stop. Then I noticed some smoke coming from the eec relay ground wire at the battery. Has anyone ever run into this? Why is it doing this? Also, I checked the battery, it has 12.76 volts.
Help Please?
beanedbronco is offline
post #2 of 13 (permalink) Old 10-03-2006, 05:43 PM
BigSteve77's Avatar
Bronco Info: 95 EB Full Size
You have a short somewhere. Its the only reason it would do that. Check everything at the solinoid first then work from there.
95 EB Full size
New 351W 4/20/2010
Headers and custom Exhaust
6" Skyjacker lift
35" B/F Ats tires
BigSteve77 is offline
post #3 of 13 (permalink) Old 10-03-2006, 05:54 PM Thread Starter
Ok I'll start there. Thanks
post #4 of 13 (permalink) Old 10-03-2006, 07:42 PM
The EEC PWR relay ground wire isn't anywhere near the battery. What are you looking at?
Smoke from a ground terminal doesn't indicate a short - it indicates high resistance right there. Remove, clean, reattach, & tighten it. If it strips, drill a new hole & tighten it down again.
BTW
There's no solenoid on an '89. They weren't used until ~'91, and then only on V8 starters.
post #5 of 13 (permalink) Old 10-03-2006, 09:09 PM Thread Starter
Then why is there a solenoid on the fender well right behind the battery? I believe its the starter solenoid. the + cable goes straight to it and a cable from the other post goes straight to the starter.
post #6 of 13 (permalink) Old 10-03-2006, 09:12 PM Thread Starter
The wire I am looking at is coming out from behind the radiator with a whole group of taped up wires. There are actually two there, and plug together at the ground terminal on the - battery cable.
post #7 of 13 (permalink) Old 10-04-2006, 03:35 AM
There isn't; never has been; never will be. There's a relay there...
It's not. A starter solenoid is ON the starter. Take a look:
The ground wires you're describing are for MANY things, but not the EEC PWR relay. That ground is near the air filter box. The ones you're looking at are known to get loose & lose contact, so definitely clean & tighten them.
post #8 of 13 (permalink) Old 10-04-2006, 04:40 AM
Try it now!!
kf4amu's Avatar
Beaned...you mean this?
Those wires eventually connect back to the EEC case (which is grounded) and the pins on the connector that need to be grounded...but then again every ground connects to each other on a Bronco.
If this is not connected, it will have nothing to do with your starter spinning the motor over.
kf4amu is offline
post #9 of 13 (permalink) Old 10-04-2006, 11:03 AM Thread Starter
But when they are not connected, there is no power to the inside of the truck. Nothing comes on. It must have something to do with the ignition switch cause i can't even crank the motor. Not even the dome light comes on. By the way those are the wires.
Does anyone know where I can find a good wiring diagram for the engine and all of the ignition wiring?
post #10 of 13 (permalink) Old 10-04-2006, 11:14 AM
Bronco Info: 1994 XLT 5.0, MSD coil/cap/rotor, SpiroPro wires, Ford Racing tranny cooler, PermaCool filter, 3G
Haynes. Or the ford CD.
Have you cleaned and re-grounded that connection?
Sandy
sewiv is offline
post #11 of 13 (permalink) Old 10-04-2006, 02:38 PM Thread Starter
Yes I have cleaned them and re-connected. I'll give the manual a try.
post #12 of 13 (permalink) Old 10-04-2006, 02:57 PM
Also, check your ground cable from the battery to the block, and to the body.
There shouldn't be that much amperage going through those little electronics grounds, that's what the big ground cable really close to the starter is for. If the big cable is broken or highly resistive, the current may be trying an alternate path.
Sandy
sewiv is offline
post #13 of 13 (permalink) Old 10-04-2006, 03:51 PM
The Riddler
78CERBERUS's Avatar
Bronco Info: 1979 FSB 351M
Maybe you have your wires (one wire) wrong on the fender relay (solonoid) .
.http://www.eliminatorracecars.com/ne...20Solenoid.JPG
http://www.smpcorp.com/
http://www.smpcorp.com/web_app/catal...liccatalog.asp
78CERBERUS is offline
