Ford Bronco Forum - View Single Post - UPDATED: PNW FSB Members Map
post #1 of (permalink) Old 07-18-2010, 02:37 PM Thread Starter
gos
Bronco Info: 1996 Bronco XLT, Cummins 6Bt Powered, E4od trans, Eaton Trutrac, Lifted with 32's on Ultras
Exclamation UPDATED: PNW FSB Members Map
I think I have finally created a 'self-serve' map for PNW FSB Members! Below is the link and instruction on how to drop a pin where you are located, we might want to make a sticky out of this post if the map works like you all like. JS.
PNW FSB Members Map
Click on the link above.
When the map opens, click on 'additions'
Click 'add marker'
Enter the name you want to use and at least a zip code, if you want your address add that too. You can also change your pin color here as well.
Click the details tab to add information about your Bronco or whatever.
Then click submit.
admin edit: sorry. sig pic to large
March 2011 FOTM
gos is offline
