F.O.T.M Voting > JULY 2017 F.O.T.M., VOTE HERE!!! - Page 4 - Ford Bronco Forum
View Poll Results: Choose your favorite Fullsize Bronco for JULY 2017!!!
stm 9 20.00%
Elliott000 13 28.89%
johnnyk8 6 13.33%
'89Bronco302 17 37.78%
Voters: 45. You may not vote on this poll
 415Likes
Closed Thread
post #61 of 141 (permalink) Old 07-18-2017, 08:02 AM
johnnyk8's Avatar
Bronco Info: 1984 Rebuilt 5.0 Free Wheeling Package
Looks like so much fun!
Sent from my Nexus 7 using Tapatalk
1984 Full Size Ford Bronco w rebuilt 302 and Auto w/OD
Lotsa Rust - Lotsa Noise - Lotsa fabricating
Project Alpha Bronco
F.O.T.M Nominee for July - Get Out the Vote
johnnyk8 is offline
post #62 of 141 (permalink) Old 07-18-2017, 08:47 AM
MS88Bronc's Avatar
@stm , I love that you have a parachute rope from an airplane's braking system - a Mig, too. That's awesome!
MS88Bronc
Don't be fooled by the name,
4.56 gears with lockers
-->My Build Thread<--
MS88Bronc is online now
post #63 of 141 (permalink) Old 07-18-2017, 06:15 PM
Erik
'89Bronco302's Avatar
Bronco Info: '89 Bronco
So at some point I got rid of my stock tailgate entirely. Ordered one of the new shells with intentions of modifying it. Here it is on the bronco, with the key hole patched up.
And the handle holes patched.
Somehow I don't have a picture.. But I also closed the window slot entirely and smoothed it over. Need to grab a pic.
It just closes with some cheap barrel latch locks. Works perfect for me on this particular bronco.
And leftover chain used to hold it up. Surprisingly you don't hear them at all back there.
BikerPepe`, JGR and stm like this.
'89 Bronco Build Thread
Ď92 Bronco Build Thread
'85 F350 CCLB-Fummins tow rig/dd
'61 F350- Pumpkin Truck
'89Bronco302 is offline
post #64 of 141 (permalink) Old 07-19-2017, 12:04 PM
Elliott000's Avatar
anyone else having supermotors issues? I went to get on to make a big post and it says my username/pass incorrect then I request a info confirmation email and its telling me something about my email i supplied does not match the one on file??? WTF
1984 Bronco Xlt, Dana 60/14b, zf5, 5.13, 351w w/ truck avenger 670 and headers on iroks
http://www.supermotors.net/registry/28155
Elliott000 is offline
post #65 of 141 (permalink) Old 07-19-2017, 02:09 PM
Retired Staff
I didn't upload but I just went there and logged in. no problem.
Elliott000 likes this.
BikerPepe` is offline
post #66 of 141 (permalink) Old 07-19-2017, 02:50 PM
Erik
I've been trying to post all day. Supermotors was down for me all morning but fine now. So...
Bumpers..
Started by buying a warn bumper with 9000i from a fsb member for a good price.
It was in pretty good condition but the bumper wasn't very stout imo.
So we cut the center winch mounting portion out and I used the rest of the thinner metal to make stuff like floor patches and inner fender panels.
And my buddy got a few very thick pieces of 2x10 steel for free and got to work..
The front..
Technically these are both sealed other than the license plate holes I drilled so I could use them as air tanks at some point.
We cut the front frame rails off to match and welded it directly on.
Cleaned up the rear.. We cut the frame rails here as well to weld it on.
It's like a roll pan but beefy.
BikerPepe`, stm and Quader1 like this.
post #67 of 141 (permalink) Old 07-19-2017, 03:24 PM
Elliott000's Avatar
ok I got er all sorted out.
Going through facebook has reminded me the order of things, hell youd think I was old considering my memory haha
So my motor actually went after i got my iroks and my 14bolt in, so Ill touch on that first. I had gotten an older 4 rib 14bolt off a buddy for a hundered bucks and a case of beer. Over the time while I was running my 9? i had welded it up and grenaded it twice so I knew a beefier rear was in my plans.
Here's the 9" after some welded rock wheeling.... busted
Here's the weld job before she detonated
Here's What I had in my shelf and should have run but I was afraid of a gear setup, but soon enough I woould be doing one in the 14b
So after a busted ass end and the cost of building a tuff 9" it was time to build the 14. AND buy some wheels/tires
For our terrain I had been suggested IROKS and since i wanted to street drive aswell i went radial.
I have loved the tires but the radial sidewalls have let me down a couple times.
Anyway, back to the 14 bolt. It was a relatively simple swap, I got some ruff stuff perches so I could set the axle back an inch or so. Also moved the shock tabs up so they werent below the tube. After I set the gears up and installed a grizzly locker she was ready to roll. Here's all the pics I have from the 14b install.
Inside the 14b drums after mudding with crap seals
I dont know how i managed but at some point i squashed the spring pad. probably after my first wheeling trip on the new tires which lasted about 15 minutes haha
Welded the 14bolts tubes up because I heard of em spinning
So I briefly ran this setup and according to my facebook record keeping briefly is 10 days! then my motor let go. so onto that mess, I ran out of oil on the front main and after i tore the bottom end apart i seen the damage. The bearing was welded to the crank and the block, I blew out the bottom cap and split my crank in half.... Buggered
[img]http://www.supermotors.net/getfile/1111784/fullsize/motors-****ed2.jpg[/img]
[img]http://www.supermotors.net/getfile/1111783/fullsize/motors-****ed1.jpg[/img]
[img]http://www.supermotors.net/getfile/1111782/fullsize/motors-****ed.jpg[/img]
I dont have any pics saved from the damage. I generally just delete stuff!
After the damage was discovered to be catastrophic I was on the hunt for a motor. After a bunch of research I decided to go with a reman and some upgrades out of a place in spokane called S&J engines. overall they were good and the motor did what it was supposed to.
Quick overview off the build
351w .030 over
35-414-3 magnum cam
prw rollertip rockers
bottom end was mostly stock pistons i believe were stock and the motor was at about 9.5:1 compression
I went edelbrock performer intake and a holey 670TA carb
Chevy valves
Overall Ive been happy. acceleration on my c6 was not what I wanted but its no race car, 37's and 4.10s i guess will do that. Going back in time I would have unloaded the cash and done a 408 stroker but hey. here i am haha.
Custom home brew exhaust parts!
Recurving the distributor
Trying to pass our stupid aircare. luckily its gone forever!
So thats all for the motor part of it, as it sits now that power plant is still in there and running well. I gotta bolt and take the kids to a movie with some, Ill leave off with a picture or two of my 15 minute wheeling excursion on the 37's and new motor..... some parts didn't like it haha
And now, FINALLY i can use the ol girl after I built a new 1350 driveshaft! Ill be back later with lots of pics from the broncos adventures following that up with another busted part. trannys i tell ya!
thanks for reading
post #68 of 141 (permalink) Old 07-19-2017, 03:42 PM
Retired Staff
Just FYI for you guys competing... I'm pretty sure SM and many/most other free, pic hosting sites are getting flooded recently with new members and tons of pic transfers, so be patient and plan accordingly. the effects of PhotoSuckIt's money move to screw everyone is making shock-waves across internet communities far and wide.
Another quick note/explanation...
Apparently the bad-word filter is working on image files and rendering them useless. Just a heads up.
(Disclaimer: BikerPepe` is no longer a staff member and anything or everything he says should be ignored and proper staff members should be addressed for real answers and explanations. This msg may self destruct in accordance with proper staff members judgement and FOTM rules on hijacking threads. Thank you and have a nice day.)
post #69 of 141 (permalink) Old 07-20-2017, 02:00 PM
Erik
So the next part of my bronco saga involves me neglecting it. I never finished the sas to a point of moving, electrical stuff was unfinished, among other things. Started modifying my dodge and got burnt out on the bronco. Eventually traded the 5 beadlocks, tires, and some cash for an LS1 powered car. That was fun while it lasted... But I have a bronco addiction.
Heres where it sat in the woods for many, many years. Like 5 or 6 years I think.
So in that time I also moved from Maryland to Florida with my other 2 vehicles while the bronco sat there. Got a bug to rebuild the bronco eventually and sold my LS1 Volvo very quickly. Cash went into parts for the bronco and transporting it more than 800 miles. Heres when I dragged it out of the woods for the first time..
It was bad from sitting back there.. At least 3 separate mice nests, spiders everywhere, more rust, and an insane amount of dirt. The mice nests in the door panels were so nasty I just threw out the panels.
And when the guy picked it up in Maryland. Funny how it was a trailer with just an old bronco and blazer on it. Guy was really cool and into me fixing it up.
The next part was much better. After my disabled neighbor helped me get the bronco into my driveway the real work began. The pace of work I did during these periods in Florida was unreal. More to come..
post #70 of 141 (permalink) Old 07-20-2017, 06:49 PM
Wild Cayuse
Tough month fellas! It's all looking great. Got about a week before I'll cast my vote so keep the pics flowing!
@stm you had me laughing hard at "everyday I'm shovelin"! Is that the Moscow remix? The 'cow' pics were pretty cool, and damn that is a crazy cactus plant. Do they give you flat tires at all?
stm and Elliott000 like this.
July, and September!
FOTM forum section
BigBlue 94 is offline
post #71 of 141 (permalink) Old 07-20-2017, 06:55 PM
johnnyk8's Avatar
Thinking I kinda blew my wad all in two posts!!!
I should've spread it out!
Sent from my Moto G (5) Plus using Tapatalk
johnnyk8 is offline
post #72 of 141 (permalink) Old 07-20-2017, 07:08 PM
MS88Bronc's Avatar
Haha I almost said that after your photo dump!
All the rigs look awesome! Good month.
johnnyk8 likes this.
MS88Bronc
post #73 of 141 (permalink) Old 07-20-2017, 07:09 PM
johnnyk8's Avatar
NICE!!!!!!!
MS88Bronc likes this.
johnnyk8 is offline
post #74 of 141 (permalink) Old 07-20-2017, 08:14 PM
greasemonger's Avatar
Go outside and take pictures of everything, every detail, even the stuff you want to change. I need motivation to fix up my black 86. I also need a push to thrash my 88. So far so good guys but keep it up!
Elliott000 and johnnyk8 like this.
greasemonger is offline
post #75 of 141 (permalink) Old 07-20-2017, 09:51 PM
johnnyk8's Avatar
After work tomorrow!
johnnyk8 is offline
post #76 of 141 (permalink) Old 07-21-2017, 08:21 PM
Elliott000's Avatar
Ahh yeaaaa its like ealry Christmas! 5.13s, install kits and hydro assist! Ill see if i have time to get started on this during the comp but i doubt it. Back later with some mud and flat tires!
Sent from my SM-G935W8 using Tapatalk
post #77 of 141 (permalink) Old 07-22-2017, 09:40 AM
johnnyk8's Avatar
Alright buddies I'm going to Milwaukee to pick up a drone. We will have footage in glorious 4K and 120 fps HD slowmo.
Hobbies are expensive!
johnnyk8 is offline
post #78 of 141 (permalink) Old 07-22-2017, 11:17 AM
Elliott000's Avatar
Ok so back at it!
After finally getting the thing what i thought was ready to rock and hitting a trail 15 minutes from home It busted the shaft as I mentioned before. Luckily it was only the rear so I pulled the shaft turned er around and drove home on the front wheels. burn outs at every corner haha. I took the wife and her sprained ankle out for a shake down run again near my place. Im very lucky to live where we have some fun technical spots only 15 minutes from home, here's a few shots bit of a log mess to weave through at the start then its mostly gravel power line road to the look out nothing to tech on this run
POSER
Later that evening i took a load of garbage to work with my son. I had just finished putting in a magnaflow basically straight exhaust and was stretching its legs on the way up a big hill. Copper heard me before he saw me and I got a ticket, yup the ol girl still has it and can speed hahaha, Not sure why OJ didn't drop the hammer! Kinda funny, my boy started crying when the cop walked up because he thought dad was going to jail.
After that a couple weeks later we packed up and went for a real drive up about an hour and a half from home to check out a mountain pass. Here's some shots of the ol bronk in action up there.
Here's me and my buddy Karls trooper on 40's pretty sweet rig
End of the line for our crew, there was a washout that the dirt bikes plowed through but the trucks held off, Karl and I wanted to go but just before we got to this I was a winner and had myself some issues!
Couple shots on the way to my 600 dollar problem of the day
Here's the irok and the day I learned I hate the radials sidewall
I thought I had just blown the bead so we grabbed the air compressor and went at getting the tire back on. Once we put the air to it though is when I noticed i ripped a nice big hole in it. Tire was done for good, on with the spare
This is me explaining to my boy how to stay calm when shit goes wrong and the wife is bickering in your ear haha
The Slop after i winched out
Here's a video clip from the tire pop, at a point when i first come out of the hole you can hear it let go.
https://youtu.be/DumNOhgila4
That's it for that adventure. Next up was a trip to stave lake, local mud flats and trail area. Can u spot the camo bronco hiding in the trees
I gotta do some stuff here at work! Ill be back with some more action from a couple days at stave and a local farm.
BikerPepe`, JGR, stm and 1 others like this.
post #79 of 141 (permalink) Old 07-22-2017, 01:25 PM
MS88Bronc's Avatar
@Elliott000 , that exhaust sounds wicked when you get on it.
MS88Bronc
post #80 of 141 (permalink) Old 07-22-2017, 05:21 PM
johnnyk8's Avatar
Outstanding!!!
johnnyk8 is offline
Closed Thread
