September 2017 F.O.T.M. Vote here !!!!! - Page 13 - Ford Bronco Forum
View Poll Results: Who will be your September 2017 F.O.T.M. ???
stm 2 3.51%
MS88Bronc 6 10.53%
SRWillis 15 26.32%
Cobrajoe 24 42.11%
dash_cam 10 17.54%
Voters: 57. You may not vote on this poll
 1258Likes
Closed Thread
post #241 of 256 (permalink) Old 09-29-2017, 03:51 PM
Ford-a-Holic
cobrajoe's Avatar
I also added some stainless side steps; but didn't like the way they mounted:
So, I went back to the shop early the next morning. I started out by scrapping the tin tubing spacers they give you for the front body mount and made some out of 3/4" black iron pipe. I chucked a piece up in the lathe and turned it down to 3", about an 1-1/2" longer than the supplied ones.
You can see that it is a much heavier wall thickness compared to theirs:
Now I was able to mount the front and brace it up to get a measurement for the rear suppoprt. This came out to be about 2 1/2" longer than the supplied brace.
I took some 1/4" plate and cut two new brackets with a cut off wheel, sorry, no pics. Holding a grinder with a cut off wheel and using a camera is a recipe for disaster and I didn't feel like taking a ride to the "new finger store"
I drilled a 9/16" hole in the end and then heated it up and bent it in the vise. It's a little beefier than the the stock one:
Once I had the step level, I marked the mounting hole and drilled it out. The step is much straighter now and a little lower which should help me and my short little legs.
MY BUILD THREAD
cobrajoe is offline
post #242 of 256 (permalink) Old 09-29-2017, 04:02 PM
dash_cam's Avatar
upgrayedd?!
roll cage
sliders
external trans filter
sag pump & 4-bolt
front tow hooks
wheels & tires
oh shit handle
gauges
sound deadening
center console, bolted to floor
cb radio
dash_cam is offline
post #243 of 256 (permalink) Old 09-29-2017, 05:10 PM
dash_cam's Avatar
fix or repair daily
front brake job
torn tailgate skin
reseal the engine
ball joints
drip rail sealing
motor mounts
fuel float
shocks
trans filter
u-joints
rear end rebuild
tracklok clutches
toasted axle
new axles
new bearings & seals
new studs
dash_cam is offline
post #244 of 256 (permalink) Old 09-29-2017, 05:33 PM
dash_cam's Avatar
beauty is on the outside...
first funky carpet replaced by anti-fatigue mat
then it was shredded
and now all-weather carpet
tire cover
black out
then painted
de-chromed
wipers
dash_cam is offline
post #245 of 256 (permalink) Old 09-29-2017, 07:55 PM
MS88Bronc's Avatar
Artistic (my attempt anyway) versions of some pics...
And survived the edge of Hurricane Irma.
And yanked a huge log out of the driveway just to prove a point. The wife wasnít rolling her eyes after that!
Because, America. Love my Bronco!
MS88Bronc
Don't be fooled by the name,
4.56 gears with lockers
-->My Build Thread<--
MS88Bronc is online now
post #246 of 256 (permalink) Old 09-29-2017, 09:32 PM
SRWillis's Avatar
Got a couple spare 3Gs. I was wanting to store one in the ammo can I mounted under the hood, but it's just a little too big.
Here's the AC and serpentine systems for installation soon!
SRWillis is offline
post #247 of 256 (permalink) Old 09-29-2017, 09:42 PM
MS88Bronc's Avatar
I gots to get me one of those too!
MS88Bronc
post #248 of 256 (permalink) Old 09-29-2017, 10:50 PM
Ford-a-Holic
cobrajoe's Avatar
Well, I didn't get the ABS fixed, but my buddy at the boneyard hooked me up, just need to go by his house this weekend and pick it up; hopefully tomorrow.
Tonight we got a solid six hours on the bumper, but it's still not done, close, but not done; I owe this guy my life.
We took some measurements, made some cardboard templates, pulled it off and headed back to his shop.
Then we transferred the template onto the material and started bending:
Then fitted and tacked the pieces together:
Getting closer and getting late:
Back to my shop for a test fit:
(It looks wide, but the fender flares will cover a good portion )
Then trim for the wheel opening:
Looks like it will work, now back off and to his shop to cap the ends, finish welding and blend the welds, but, not tonight.
Thanks guys, it's been a lot of fun, hopefully everyone had as a good a time as I did. Best of luck to all; can't wait to see how this turns out!
MY BUILD THREAD
cobrajoe is offline
post #249 of 256 (permalink) Old 09-30-2017, 12:43 AM
MS88Bronc's Avatar
Good luck to everyone. Iím out of pictures and stories and may the best Bronco win!
TeGluGLgQU8
MS88Bronc
post #250 of 256 (permalink) Old 09-30-2017, 09:21 AM
SRWillis's Avatar
It's been fun sharing Ol' Faithful with y'all and seeing all the ideas, improvements and hard work you guys have put into your rigs, each one worthy candidates for F.O.T.M. Looks like the monster plow beast of @cobrajoe will come out on top, and it will be a fine representation of our close-knit community.
I put an oval on. Not a Ford oval though. I guess a lot of people use these to brag about how far they have run, but I'm too old to run, so I went with this one.:red x Also put a NRA sticker in the window. Me with one of my favorite rifles, a Springfield Armory M1A Scout in a VLTOR stock.
SRWillis is offline
post #251 of 256 (permalink) Old 09-30-2017, 11:35 AM
Wild Cayuse
Aye, every good bronco needs an NRA sticker and a gun toting man behind the wheel. This is America afterall!
July, and September!
FOTM forum section
BigBlue 94 is offline
post #252 of 256 (permalink) Old 09-30-2017, 03:09 PM
MS88Bronc's Avatar
Oh, I almost forgot...this is my wallpaper on my phone. Haha.
BikerPepe`, stm, cobrajoe and 1 others like this.
MS88Bronc
post #253 of 256 (permalink) Old 09-30-2017, 07:48 PM
Ford-a-Holic
cobrajoe's Avatar
Thank you for the kind words @SRWillis , but there is still plenty of time left. No matter how it turns out, it was a lot of fun completing with you guys and all though I have never followed this thread before, it seems like it was really competitive and will definitely follow them in the future.
Well I went and picked up the McGard lugs for the Weld wheel this morning so I took the liberty to polish up each one of the wheels when I took them off.
Unfortunately, that took most of the day, but they came out really nice as you can see from last nights bumper pics:
The rest of the day was spent tidying up loose end, securing lines, etc... and cleaning up the '93.
Good luck all.
BikerPepe`, stm, SRWillis and 1 others like this.
MY BUILD THREAD
cobrajoe is offline
post #254 of 256 (permalink) Old 09-30-2017, 08:06 PM Thread Starter
F.O.T.Y. 2017
Quader1's Avatar
Bronco Info: 78 W/400
Last day to vote folks , if we could get half the members on this site to vote it could be anybodyís game.
Seriously guys you did a great job !!!
Quader1 is offline
post #255 of 256 (permalink) Old 09-30-2017, 11:32 PM
F.O.T.Y. 2016
itwasFREE!!!!'s Avatar
This is what its all about not giving up until the bells Tolls!!! The sportsmanship the ability to pimp your ride even when behind is admirable it shows the true LOVE for your BKO regardless of the uncermountable odds, it shows the passion one holds for their Bko! I LOVE IT it speaks volumes for the individual & his self worth to keep up the quest until then end, never give up never surrender fight until there's
Is no fight.
Welcome to our Addiction, where counseling consist of admitting the problem is you and your Bronco is the Cure!
itwasFREE!!!! is offline
post #256 of 256 (permalink) Old 10-01-2017, 11:46 AM Thread Starter
F.O.T.Y. 2017
Quader1's Avatar
To the Contestants that ran this month you did a great job and consistantly kept us members entertained the entire month so thank you for your hard work and willingness to participate but there can only be one !!!!!!!!!
Congradulations @cobrajoe
Take a moment and help me congradulate him on his Epic Run ...... Your September F.O.T.M. Winner Cobrajoe
http://www.fullsizebronco.com/forum/...er-2017-a.html
Quader1 is offline
Closed Thread
