Chat with F.O.T.M. contestants - Page 2 - Ford Bronco Forum
 182Likes
post #21 of 136 (permalink) Old 05-21-2018, 10:06 PM
RicksBroncoBeast's Avatar
Bronco Info: 96 Eddie Bauer
been running alcans out back on my rig since I did my solid axle swap. think they changed ownership, at some point but I know they make a great product.
Cool, good to know. Did you run the Orbit Eye bushings?
1996 Eddie Bauer Bronco Beast: Powered by a 4BT Cummins Diesel, 37" BFG BAJA TA's, Atlas 4 Transfer Case, HUMVEE 24 Bolt Wheels with Trail Fab Beadlocks, RCV Front TTB Axles, 5.5" SuperFlex Suspension, Lockers Front and Rear, Custom Front and Rear Bumpers, Monstaliner Bedliner Paint Job...
Vote RicksBroncoBeast May 2018 F.O.T.M.
RicksBroncoBeast is offline
post #22 of 136 (permalink) Old 05-22-2018, 07:51 AM
Charlie don't surf!!
To be honest I think the springs have actually gotten better with age..if that's possible..running the regular eye bushings, but I remember seeing the orbit eyes..they're pretty slick..wonder if you could retro into a regular eye??
jermil01 is offline
post #23 of 136 (permalink) Old 05-22-2018, 04:35 PM
...wonder if you could retro into a regular eye??
I think some springs can get better when they are broken in. More limber so to speak. Not sure if the O.E. bushings can be retro fitted, I would call and find out though. Reading about the O.E. bushings it says you do need their shackles though. I am a little bit away from being able to do it so when that time gets closer, I will be finding out...
post #24 of 136 (permalink) Old 05-23-2018, 01:01 PM
White Dragon's Avatar
Bronco Info: '96 XL
@stan the man
@Warhoss
@RicksBroncoBeast
@jermil01
@TravisITGuy
Dragon is really liking the "Aeronose Show" this month.
Mud, Snow, Mountains & Rocks, What More could a Bronco Lover want? (Maybe some Sand)?
I also enjoy Reading & Watching the progression on each of your Rigs from their humble beginnings to where they are now, Good Stuff Guys.
Thanks go to you All for sharing.
Later,
Dragon
BigBlue 94 and Warhoss like this.
White Dragon is offline
post #25 of 136 (permalink) Old 05-23-2018, 01:12 PM
aka: kemicalburns
TravisITGuy's Avatar
I thru some Sand pictures from the Christmas Valley dunes in Oregon. they are nothing like the Oregon coast dunes though.
White Dragon likes this.
TravisITGuy is offline
post #26 of 136 (permalink) Old 05-23-2018, 01:50 PM
Bronco Info: '96 XL
Why Yes, Yes you did. LoL
It's the Bronco Addiction talking.
You know,,, the More we see, the More we want.
Still 8 days left in this little Aero-Fest.
Thanks Again,
Dragon
post #27 of 136 (permalink) Old 05-23-2018, 01:56 PM
8 days is a lot of time...
jermil01 is offline
post #28 of 136 (permalink) Old 05-24-2018, 10:52 AM
Bronco Info: '96 XL
Indeed it is.
@Warhoss with that 3D Emblem surround, what a Great Idea.
Later,
Dragon
Warhoss likes this.
post #29 of 136 (permalink) Old 05-26-2018, 09:41 AM Thread Starter
F.O.T.Y. 2017
Quader1's Avatar
Bronco Info: 78 W/400
@RicksBroncoBeast How is the line locks working, any problems ? also any problems installing them ?
Quader1 is offline
post #30 of 136 (permalink) Old 05-26-2018, 09:45 AM Thread Starter
F.O.T.Y. 2017
Quader1's Avatar
@stan the man Nothing like a bunch of BKO Buddies coming to the rescue to help out !!!! .... Oh and the Blazer get's a pass as well lol very cool !!!
Quader1 is offline
post #31 of 136 (permalink) Old 05-26-2018, 10:31 AM Thread Starter
F.O.T.Y. 2017
Quader1's Avatar
@jermil01 how are you liking the synthetic rope on your Winch ? The only reason I went steal is the Arizona sun rots everything and didn't want it to fail when I needed it.
Quader1 is offline
post #32 of 136 (permalink) Old 05-26-2018, 10:35 AM Thread Starter
F.O.T.Y. 2017
Quader1's Avatar
@Warhoss could you explain how your dual exhaust was ran ? I had gone to 2 different exhaust shops and they couldn't get it done
due to the front driveline and crossmember and was curious
all I can say is WOW !!!!!!
White Dragon and Warhoss like this.
Quader1 is offline
post #33 of 136 (permalink) Old 05-26-2018, 10:48 AM
The Line lock was was very easy to install. All you have to do is find a good mounting point, then make a new brake line (making sure to double flare the ends). In my case I was able to cut the original brake line and bend it into a different shape and install new ends. And in my case I ran it into the MICO hydraulic parking brake solenoid and made them work independently. Installing the shifter momentary switch was a little different. Since the ford shifter is splined and not threaded I had to purchase a universal adaptor that has set screws holding it on but the knob screwed onto the adaptor. When I looked at the thread size I knew that I could make threads over the splines and it would be a lot more secure. I found a die that would be the right thread and walla, it was perfect. A drop of lock tight and it was secure.
One more thing on the line lock design. A lot of line locks are dual line and other configurations. Fo me I needed a rear inlet and front outlet so I could run it in series with the MICO. I used Biondo (Moroso Style) Rebuildable Line lock which also did not have the warning of a maximum of 60 seconds of holding the solenoid engaged.
White Dragon and Quader1 like this.
post #34 of 136 (permalink) Old 05-27-2018, 09:41 AM
I've only used the the synthetic line twice, but it's great. Much easier to handle than the steel cable. You do have to be more careful about scraping it across rocks, but that's easy enough..Also, you want to make sure to clean of any mud/debris after using it, but I chalk that up to normal maintenance. Mine is hidden behind the bumper so I don't have any concern about the sun wrecking it..
jermil01 is offline
post #35 of 136 (permalink) Old 05-29-2018, 03:00 PM
Bronco Info: '96 XL
@Warhoss
Your rear interior cargo light looks good, is that an aftermarket piece?
I Like the way your rig turned out.
it's good to see a rig that has a clean and somewhat stock kind of flavor.
(Not everyone around here thinks that heavily modified and chewed up is the "End All" for Broncos)...
Later,
White Dragon
Warhoss likes this.
post #36 of 136 (permalink) Old 05-29-2018, 11:36 PM
Warhoss's Avatar
Bronco Info: 1995 Bronco
Thanks @whitedragon ! This Bronco was in the hands of a fire department in Alabama for most of it's life so it was never rode hard and I didn't have the heart to change it up much other than doing some updates. I want it to be a survivor in the end and if at some point I or someone else wants to go back bone stock, it can be done easily. The rear interior light is actually the one that was on it when I got it, so I believe it was the factory light
Warhoss is offline
post #37 of 136 (permalink) Old 05-29-2018, 11:45 PM
Warhoss's Avatar
Thanks @Quader1 ! I'm not sure how to explain it and I just checked to see if I had better pictures of the exhaust toward the front end. I've got a buddy who has a shop where he has put on a many a mufflers and run those exhaust. He brought them down the passenger side. If you remind me. I can get some better pics to let you see for yourself?
Warhoss is offline
post #38 of 136 (permalink) Old 05-29-2018, 11:53 PM
Warhoss's Avatar
@BigBlue94 Oh ok I was just discouraged from the attempts of others that couldn't get that tail gate panel to clean up and I saw the prices on new ones to replace it so I just wanted to give the film a chance and I thought the dark skin would go better against all that white paint!
BigBlue 94 likes this.
Warhoss is offline
post #39 of 136 (permalink) Old 05-30-2018, 08:50 AM
Wild Cayuse
@Quader1 here's a really poor drawing of how my true duals were ran. Longtubes, 2.5" pipe, and flowmasters under the back floor.
July, and September!
FOTM forum section
BigBlue 94 is offline
post #40 of 136 (permalink) Old 05-30-2018, 12:57 PM
Bronco Info: '96 XL
So, @RicksBroncoBeast
I've been meaning to ask about your rims and i have questions.
1. Are you utilizing the "Run Flat" rings in those rims?
2. What Air Pressure do you typically run?
3. What is the "Lowest" air pressure you have tried?
4. If you use the "Run Flats" and air down below 10 psi, do the Rings interfere with your "Foot Print"?
So,
If giving Affirmative responses to the above questions,
5. Do You Like the "Run Flat" rings for off road use or would you not recommend them?
Thanks in Advance for your Answers.
Dragon
itwasFREE!!!! likes this.
