Chat with F.O.T.M. contestants - Page 3 - Ford Bronco Forum
 175Likes
post #41 of 127 (permalink) Old 05-30-2018, 06:14 PM
Wild Cayuse
Well fellas, my vote has been cast. Ill say it was the toughest vote I've made on here. I would have loved to have voted for you all, and hope that the runner-ups will consider running again. You all have fantastic Broncos, and use them well, and could no doubt win a future competition. Thanks for the adventures and good luck to all!
@stan the man @Warhoss @RicksBroncoBeast @jermil01 @TravisITGuy
July, and September!
FOTM forum section
BigBlue 94 is offline
post #42 of 127 (permalink) Old 05-30-2018, 06:33 PM
RicksBroncoBeast's Avatar
Bronco Info: 96 Eddie Bauer
Originally Posted by White Dragon View Post
So, @RicksBroncoBeast
I've been meaning to ask about your rims and i have questions.
1. Are you utilizing the "Run Flat" rings in those rims?
2. What Air Pressure do you typically run?
3. What is the "Lowest" air pressure you have tried?
4. If you use the "Run Flats" and air down below 10 psi, do the Rings interfere with your "Foot Print"?
So,
If giving Affirmative responses to the above questions,
5. Do You Like the "Run Flat" rings for off road use or would you not recommend them?
Thanks in Advance for your Answers.
Dragon
I use inserts that are made from drainage pipe from Trail Fab Worthy. They are now true beadlocks. The military run flats are not good for off-roading and are primarily made for bullet holes...lol. I can run my tires down to 5psi and not worry about anything. I typically run 18psi while wheeling and 35psi on the road. Here is a link to the website that shows a perfect picture of how they work.
Hummer Wheel PVC Insert
1996 Eddie Bauer Bronco Beast: Powered by a 4BT Cummins Diesel, 37" BFG BAJA TA's, Atlas 4 Transfer Case, HUMVEE 24 Bolt Wheels with Trail Fab Beadlocks, RCV Front TTB Axles, 5.5" SuperFlex Suspension, Lockers Front and Rear, Custom Front and Rear Bumpers, Monstaliner Bedliner Paint Job...
Vote RicksBroncoBeast May 2018 F.O.T.M.
RicksBroncoBeast is offline
post #43 of 127 (permalink) Old 07-02-2018, 11:09 PM
White Dragon's Avatar
Bronco Info: '96 XL
@PoppaGator
Your getting Pics.... Yeayyyy
(Now, where is that Bronco?)
Good Luck.
Dragon
Do You want to Participate in the 2019 Moab "Full Size Bronco Invasion" ??? Looky Here, https://www.fullsizebronco.com/forum...on-2019-a.html
Here is the "Planning & Info Only Link", https://www.fullsizebronco.com/forum...info-only.html
White Dragon is offline
post #44 of 127 (permalink) Old 07-04-2018, 10:31 AM Thread Starter
F.O.T.Y. 2017
Quader1's Avatar
Bronco Info: 78 W/400
Originally Posted by CainsBigRed View Post
Happy Fourth of July everyone
Badass pic right there !!!!!! Just sayin
Quader1 is offline
post #45 of 127 (permalink) Old 07-04-2018, 10:57 AM
Wild Cayuse
@PoppaGator when using the img tagged url from supermotors, you can directly paste it into the text box. No need to use the img button here. That's just double img tagging each one, and why each one says img before and after the pic.
Otherwise, carry on gents!
White Dragon and CainsBigRed like this.
FOTM forum section
post #46 of 127 (permalink) Old 07-11-2018, 12:05 PM
Beach bumming it ........
Saltlife's Avatar
@CainsBigRed Link to the grab handle install? Elvira needs those in her life.
Saltlife is offline
post #47 of 127 (permalink) Old 07-11-2018, 07:50 PM
CainsBigRed's Avatar
Bronco Info: Rosita my 95 XLT Sport, 5.8, 33x12.5x15, 6 inch lift, factory limited slip, manual hubs
Smittybilt 769311 Grab Handle for 2007-2018 Jeep Wrangler JK, Pair
https://www.amazon.com/dp/B004K25IGK...bEAXHN3W<br />
Fyi I did try using the more inexpensive ones but they don't last long, the eyelit metal end are too weak. These pricer ones the eyelit are more heavy duty n have not broke off as I pull my self in
Saltlife likes this.
CainsBigRed is offline
post #48 of 127 (permalink) Old 07-13-2018, 02:11 AM
@Saltlife
Sorry I didn't realize I didn't post how I install them.
Pretty much once you have your handle spacing figure out I mark the plastic trim and drill a hole straight through and into the door sheet metal, I then pull all plastic trims and install in place these things called nutzerts they are essentially a rivet n get install by a similar tool but you are creating instead a solid threaded place for the handle to screw on too.
I did modify the holder that came with the handles for a larger bolt. by the way I found YouTube videos on how to install nutzert without the tool and that's how I did mine here a few more pics. Took a few hours but definitely worth it in the end.
Vote here for your Hot Next Door Bronco
https://www.fullsizebronco.com/forum...vote-here.html
post #49 of 127 (permalink) Old 07-15-2018, 12:58 PM
Bronco Info: '96 XL
@Ghosteh
I can't speak for the others,
But those "Little Details" that you do not want to "Bore" us with??
Bring it Brudda',
that is part of the "Meat" on Bronco Ownership,
many of us have gone through the same "Detail Oriented" process.
Great Job so far.
Later,
Dragon
post #50 of 127 (permalink) Old 07-15-2018, 01:22 PM
Ghosteh's Avatar
Bronco Info: '96 XLT 5.0L manual hubs, 4" Rancho lift, rock sliders, relocated shock mounts, original USBP vehicl
@Ghosteh
Bring it Brudda',
Great Job so far.
Later,
Dragon
Haha! Thanks brother! It's been a huge project finding all those little odds & ends to make an old hunting truck look nice inside. LMC, eBay, and Carparts.com have been the best resources, but they swallow hundred dollar bills like water!
Don't worry; tailgate rebuild is next and it was a &#$^!!!
Ghosteh is offline
post #51 of 127 (permalink) Old 07-15-2018, 02:14 PM
F.O.T.Y. 2016
itwasFREE!!!!'s Avatar
@Ghosteh
Bring it Brudda',
Great Job so far.
Later,
Dragon
@Ghosteh I to agree with @White Dragon the little odds n ends are some of the things that we all deal with on a daily basis but yet some of the most tedious, sometimes the simplest as well as the hardest things to figure out how to fix. If you have pictures of it Id highly recommend posting them, it will go along ways. Keep telling those great stories.
monch, sackman9975 and Ghosteh like this.
Welcome to our Addiction, where counseling consist of admitting the problem is you and your Bronco is the Cure!
itwasFREE!!!! is offline
post #52 of 127 (permalink) Old 07-17-2018, 10:40 AM
Wild Cayuse
@Ghosteh as I'm reading your interior post, I couldn't help but remember that I saw a pair of brand spanking new blue bronco bucket seats on Craigslist a couple weeks ago. If they weren't 5 hours from me in southern Missouri, I'd have scooped them up. They only wanted 200 for the pair!
FOTM forum section
post #53 of 127 (permalink) Old 07-17-2018, 12:50 PM
Ghosteh's Avatar
I know! Isn't that always the way things go? I looked for YEARS to find a decent seat, and when I finally find one, buy it, and get it installed, then a great set of them pop up.
I saw that post too, and if I hadn't already bought mine (which I'm happy with), I'd have been over there in a heartbeat! $200 for 2 nice seats is a great buy. Hope someone else can use them.
BigBlue 94 likes this.
Ghosteh is offline
post #54 of 127 (permalink) Old 07-23-2018, 07:30 PM
@Ghosteh ,
Any details on how you reverse the seat, I really like that lol do you have more pictures or brackets you made to reverse it.
post #55 of 127 (permalink) Old 07-23-2018, 07:42 PM
Ghosteh's Avatar
@Ghosteh ,
No, it was really easy. Just unbolt & turn it around, using the same holes. If you don't like it, just spin it around again!
Ghosteh is offline
post #56 of 127 (permalink) Old 07-23-2018, 07:52 PM
Okay so your are not using the actual latch to secure it and lock it in to position then? Only using the bolts to just hold it.
Ghosteh likes this.
post #57 of 127 (permalink) Old 07-23-2018, 07:59 PM
Ghosteh's Avatar
Right. It's probably not the ideal situation, but we never had one fold up on us in the field & we drove those things HARD!
CainsBigRed likes this.
Ghosteh is offline
post #58 of 127 (permalink) Old 07-29-2018, 12:36 PM
Wild Cayuse
@CainsBigRed most often, a fire will melt the cartridge before the primer will go off. Once there's a hole in the cartridge, the chance of explosion is minimal. The powder will flash, not explode because it is no longer a compressed charge.
I had hundreds of rounds of ammo, 10,000+ primers, and 50lbs of powder go up in a shop fire. None of the ammo or powder exploded, but the primers all went off like a pack of black cats. All the brass and plastic shells had melted, along with every bit of lead, even that encapsulated in copper jackets.
Still terrifying either way!
FOTM forum section
post #59 of 127 (permalink) Old 07-29-2018, 01:16 PM
My first experience with fire and ammo but now I know
Sent from my Moto Z (2) using Tapatalk
post #60 of 127 (permalink) Old 07-29-2018, 01:48 PM
monch's Avatar
Bronco Info: 1996 XL 5.0
@1clean5.8 i love that factory bumper with a hidden winch behind it! Do you have build thread for it? And what size of winch do you run?
monch is offline
