Chat with F.O.T.M. contestants - Page 7 - Ford Bronco Forum
 175Likes
post #121 of 127 (permalink) Old 03-20-2019, 04:38 PM
NickOille's Avatar
Bronco Info: 1984 Bronco, 351w, C6, custom np208 based doubler, np208, TTB D44, 9", 5.13's
Originally Posted by itwasFREE!!!! View Post
@NickOille
Tire Diameter: 37:1 Transmission Ratio: 2.40:1 Diff Ratio: 5.13:1 Transfer Case Ratio: 5.22:1(if u just multiply x 2 "doubler")
Equals a Crawl Ratio: 64.27:1 ????
Not picking on your math, but it should be 2.61 squared, not x2 for the doubler. So 2.46x2.61x2.61x5.13
itwasFREE!!!! likes this.
NickOille is online now
post #122 of 127 (permalink) Old 03-20-2019, 05:12 PM
F.O.T.Y. 2016
itwasFREE!!!!'s Avatar
Its all good! I wasn't sure how it was calculated, in fact i was using a formula that was online, but i still was putting the wrong info. so thank you for that; now i know.
Welcome to our Addiction, where counseling consist of admitting the problem is you and your Bronco is the Cure!
itwasFREE!!!! is offline
post #123 of 127 (permalink) Old 03-20-2019, 06:37 PM
NickOille's Avatar
http://www.grimmjeeper.com/gears.html
My favorite calculator for figuring that kind of stuff
post #124 of 127 (permalink) Old 03-24-2019, 02:01 PM
F.O.T.Y. 2016
@NickOille looking at your post for your broken ram this is what I did to mine. works great. Since I do drive mine on the road and the ram doesn't return to center 100% I wanted a quick disconnect. So I wouldn't be sawing the steering wheel back n forth all the time. you can see in one picture where the ram is disconnected it is attached to the Track Bar, I the other picture the hoses connect to one another and are secured to the cross member via a sway bar bracket. It works great.
JGR likes this.
post #125 of 127 (permalink) Old 03-24-2019, 08:38 PM
NickOille's Avatar
That’s a nice set up.
So I dunno if it’s cause my ram is only 1”, but I have zero street-ability issues. Perfect return to center, and I never have out-run the stock pump. It has enough power and relives enough stress that I haven’t cracked my frame at the box again either
post #126 of 127 (permalink) Old 03-28-2019, 01:24 PM
Retired Staff
that's awesome. maybe now some moderator will move those pic posts into the actual contest thread, where they belong.
allcruisen and anaconda like this.
BikerPepe` is offline
post #127 of 127 (permalink) Old 03-30-2019, 04:04 PM
F.O.T.Y. 2016
Missed them , what can I say I am a government employee I only work for Wine Bribes @antonio We/I want to see the legendary Malbec Vineyards.
BikerPepe` likes this.
