May Full Size of the Month 2019 Vote Here!!! - Page 4 - Ford Bronco Forum
View Poll Results: Vote for your May 2019 Full Size of the Month !!!!!!!
allcruisen 4 21.05%
ANGELO 3 15.79%
CrazyBRONCOguy 2 10.53%
AbandonedBronco 8 42.11%
nedceifus 2 10.53%
Voters: 19. You may not vote on this poll
 696Likes
post #61 of 87 (permalink) Old 05-14-2019, 06:45 PM
FSB Pimpster & Recruiter
allcruisen's Avatar
Bronco Info: '95 302 XLT
After Market LED Turn signal mirrors:
Allcruisen
VOTE For FOTM !!!
"DEATH BEFORE DISHONOR"
allcruisen is online now
post #62 of 87 (permalink) Old 05-15-2019, 12:48 PM
Big Six
AbandonedBronco's Avatar
Back to it.
The '84+ firewall was kind enough to supply tiny divots to mark where the hydraulic master cylinder mounted.
Time to cut through!
Unfortunately, the M5OD/ZF5 master cylinder uses a different bolt pattern than the earlier era. So, I wasn't able to use the kindly provided markers. Time to make my own.
Studs in place, and solidly mounted!
Pulled it back out to finish mounting the brace. Time to drill the holes for the brace.
Once the holes were drilled, I had to remove the cowl to get to the upper holes.
Engine bay mounting bolts:
Manual bracket and pedals put into place.
I wanted to keep the tilt steering in the '85, so I didn't reuse the manual transmission steering column from my '81. So, I just pulled the shift lever out.
With the reinforcement plate installed, pedal bracket in place, and the master cylinder mounted, I could put the dash together. It'd been 8 straight days of pulling more and more things apart, so being able to put something back together felt really good!!
Next, the ZF5 was fully rebuilt and home. So now to get it in.
March 2016 FOTM
Supermotors Pics
AbandonedBronco is online now
post #63 of 87 (permalink) Old 05-15-2019, 09:42 PM
September 15 FOTM
ANGELO's Avatar
Bronco Info: 1978 bronco 351 c6
some before and after.
20170921_154727 by Angelo Mehtala, on Flickr
20170921_154502 by Angelo Mehtala, on Flickr
20171216_135723 by Angelo Mehtala, on Flickr
20171216_135740 by Angelo Mehtala, on Flickr
20171216_134556 by Angelo Mehtala, on Flickr
20171216_134335 by Angelo Mehtala, on Flickr
those tires are really old, i was worried they were going to pop flexing on the forks. the front driver almost did
1992 f250 turbo intercooled idi ~ D.D./work truck
1978 bronco "grits"~ trail truck
1984 f350 with sleeper "The Rig"
ANGELO is online now
post #64 of 87 (permalink) Old 05-16-2019, 08:37 AM
Ford Hoarder
Inspired by some home ads and other car ads, thought sure why not.
I present the VR tour of my 78, shot from in first person, feel like your actually here checking out my truck. If you have 2 minutes to spare. No real sound track just me almost falling out, and some Indiana Native Birds.
Soon will have some more stuff to post
CrazyBRONCOguy is online now
post #65 of 87 (permalink) Old 05-16-2019, 11:19 AM
Big Six
Before I could put the ZF5 in, I had to get the 300 in. I've found it to be much easier to install a transmission and mount it with an engine that's in place, than it is to install an engine and connect to a transmission.
Getting rid of the 302 radiator and transmission cooler.
*pluck*
A nice, running EFI 302 should sell nicely.
An open canvas.
These were a PAIN. I had to swap out the engine perches from the V8 to the I6 varietal.
The I6 perches just bolt right in. However, the V8 ones had some very odd design decisions. The passenger side bolts in, but the driver's side used half bolts and have rivets. Thanks random Ford engineer.
The rivets are tucked up underneath, so it took a good amount of work to try to squeeze a cutter up to get them. Once I got them ground down low enough, I used a crowbar to bust and the snap the rest off.
Ground them flat and covered them with some local grease, so they'd blend in.
300 perches in place.
I acquired a new intake for the fuel injection system, and it needed to be painted to match the engine.
Lining up all the ports so they match exactly.
Those are some pretty ports.
Resting in its new home!!
The ZF5 is one big, tall transmission. I originally had it up on the transmission jack, but even with my floor lift jack lifting the Bronco as high as it would go, there was no way it was going under. The frame even sits about 4 - 5" lower than the sill below the door, so the Bronco would have nearly hit the ceiling of the garage, before the ZF5 would slide under while still on the jack.
Once I took the transmission back off of the jack, I was able to slide it under.
Next step was getting it back up on the jack. Fun job with a 200 lb transmission while under the Bronco.
Honestly, sometimes I feel the only reason I go to the gym anymore is so I can properly work on the Bronco
And they're mated for life.
Did I mention how tall the ZF5 is?
At this point, I was at day 17 of non-stop nights and weekends on this swap. This was a really, really good point to be at.
March 2016 FOTM
Supermotors Pics
post #66 of 87 (permalink) Old 05-16-2019, 04:03 PM
September 15 FOTM
ANGELO's Avatar
wow. the small blocks have so much more room. i just did the zf in my 250 a month ago for the clutch and it took a couple hours to get it to fit back in its place. it pretty much sits on the firewall, and less then half a inch away from the downpipe and up pipe ended up having to pry the exhaust over and forcing the trans in place. that much space would have been awesome
post #67 of 87 (permalink) Old 05-16-2019, 04:19 PM
Big Six
In this case, it looks like a lot of room because the engine isn't bolted down and is free to tip. With absolutely nothing connected to it, it can tip a LOT. Made for a good amount of room.
I had 3 jacks I was using to raise and lower different parts of the engine and transmission to get different pitches on them until they finally lined up. I can see how it would have been pretty tight otherwise.
March 2016 FOTM
Supermotors Pics
post #68 of 87 (permalink) Old 05-17-2019, 12:24 PM
September 15 FOTM
ANGELO's Avatar
right after the lift was finished, my t case started to leak so twin sticked it and resealed
20180211_172358 by Angelo Mehtala, on Flickr
20180217_181501 by Angelo Mehtala, on Flickr
that is one heavy transfercase! I usually pick the 1565s up on my back so i dont need a jack. not doing it with this one!
20180223_111318 by Angelo Mehtala, on Flickr
finished it just in time to bring it to hardrock offroad. it used to be a limestone mine so theres no traction when wet and it has extremely steep hills.
20180224_150338 by Angelo Mehtala, on Flickr
20180224_131746 by Angelo Mehtala, on Flickr
of corse hill are hard to show the angle off but you can just barely see the ruts to the right of my truck, thats one of the hill climbs
20180224_112836 by Angelo Mehtala, on Flickr
20180224_111643 by Angelo Mehtala, on Flickr
20180224_115644 by Angelo Mehtala, on Flickr
and some videos
20180224_133154 by Angelo Mehtala, on Flickr
i probably could have made it all the way up, but i was having carb problems, the quardajet wasn't adjusted right. going backwards down the hills without power steering and brakes was really sketchy, and i wasnt in a good position to do that on this hill, so i just got winched the rest of the way up. the lower passenger side of the body was also stuck on a root. this was before sliders
i have more videos i just have to find them.
post #69 of 87 (permalink) Old 05-17-2019, 01:06 PM
Big Six
The crossmember for the ZF5 was fortunately really straight forward. It curves backward to accommodate the extra length of the transmission, the drop brackets are curved back, so that it can still utilize the upper bolt holes, and only needs to have the bottom hole moved an inch back. The later year trucks have both bolt holes just for this.
ZF5 on top, original underneath.
I had to put the exhaust back in that I had cut out of my other Bronco, since it has to go above the crossmember. I originally had to cut it in half since there is no way to get it unwrapped from around the axle. I welded the tailpipe back on later.
New hole drilled:
Mounted and solid!
Now the transfer case can go in.
Since again, this is by myself, I just benched it up and got it hooked on the output shaft, and then could spin it into place. Not a bad way to do it.
One of the biggest obstacles I ran into with the ZF5 was the transfer case shifter. The later year Broncos/trucks came with transfer case shifters that enter the cab from the side of the transmission tunnel hump, instead of through the tunnel cover.
This isn't the best picture, but this is how the later years are set up. You can see how the transfer case shifter is down low on the left and comes out of the side of the tunnel, instead of the top.
http://images.gtcarlot.com/pictures/70363838.jpg
I didn't want to replicate this, since I didn't want to cut into my floor and risk issues with it stressing and cracking. I imagine Ford bolstered this area up when they decided to go this route in later years. So, I needed to figure out a way to utilize my original shift linkage.
You can see the original linkage on the ZF here:
Both the ZF5 shifter bracket and NP-435 bracket used the same kind of setup, and utilized a big shoulder bolt to rotate on. However, the ZF5 bolt was metric and the NP-435 standard, and the diameters' of them were just a hair different, so they couldn't be used interchangeably. So, I had to cut the nut off of the ZF5 bracket and get a new bolt to attach the NP-435 arm I had.
The nut was welded on, so I rested a cutting wheel against the surface and slid it across. Made for a beautiful cut.
Now I could use a locking nut to put the NP-435 shifter arm on.
Before:
After!
Now that it was in place, it hit the side of the opening.
A little cutting never hurt.
Now it can move!
Since the ZF cover doesn't have a hole for the transfer case, I had to make one.
Next, I had to make my own custom length shift lever. The original had a peg that an arm would clip on, so I had to drill it out.
I used some heim joints and threaded rod, which did the trick nicely.
Carpet finally going back!
*peek*
Looking like a Bronco again. Now with a manual shifter!
A little floor cleaning. It was pretty nasty.
Seats and center console back in!!
Last but not least, some custom length driveshafts.
The drivetrain is DONE.
Now that it's ready to rock, it was time to get it to roll. So, I needed to get the engine running with the new fuel injection system.
But that's another story for another day.
March 2016 FOTM
Supermotors Pics
post #70 of 87 (permalink) Old 05-19-2019, 08:40 AM
Wild Cayuse
White Dragon likes this.
July, and September!
FOTM forum section
BigBlue 94 is online now
post #71 of 87 (permalink) Old 05-19-2019, 11:58 AM
Ford Hoarder
Im kind of out of it...
I do not have the desire to post my whole build thread here. Not saying anything wrong with those that do. Just not for me.
post #72 of 87 (permalink) Old 05-20-2019, 08:48 AM Thread Starter
F.O.T.Y. 2017
Quader1's Avatar
Bronco Info: 78 W/400
I have but not all the voters have seen your build thread and all you put into your BKO Id be showing that bad boy off!!!
Quader1 is online now
post #73 of 87 (permalink) Old 05-20-2019, 10:27 AM
Wild Cayuse
Yeah, it's not only the build pics we wanna see, it's what you do with the bronco while it's actually running that we wanna see.
allcruisen and White Dragon like this.
FOTM forum section
post #74 of 87 (permalink) Old 05-20-2019, 10:55 AM
Big Six
Happy Monday fellow Bronco lovers. Hope you had a great weekend!
Taking a break from the regularly scheduled program to share some more Moab pictures. Finally got the pics off of my wife's phone.
A rare picture of yours truly.
Being able to drive my Bronco out here was one of the best birthday presents I've had in a long time.
March 2016 FOTM
Supermotors Pics
post #75 of 87 (permalink) Old 05-20-2019, 11:41 AM
Big Six
On a side note, one of the laughs I got while in Moab is how whenever I asked about trails, I was asked how big my lift was.
I know everyone is always thinking "Jeeps", so this is what their question is in reference to.
My brother had to install a lift on his Jeep Cherokee so that he could put 31" tires on it. I have 32" tires without a lift. It isn't a 1:1 comparison.
March 2016 FOTM
Supermotors Pics
post #76 of 87 (permalink) Old 05-20-2019, 12:49 PM
Big Six
Now that the engine and transmission were in, I needed to get my Sniper EFI installed and set up.
I had an easier job than most since the '85 302 was fuel injected, so I had a high pressure fuel system already in place with the needed 60psi fuel pressure, and a return line. All I needed to do was tie into it.
I decided to go with the 2300 two barrel style for my engine. It felt weird going from a 4bbl carburetor to a 2bbl style fuel injection system, but ultimately it made sense. It was either two 100 lb injectors or four 100 lb injectors. If they had made a 4bbl Sniper with smaller injectors, I would have gone with that. But the 4bbl styles were just too big for my engine. The 2bbl setup was rated to 350hp as it was, and flowed 580cfm, so it really was plenty (and honestly would be plenty for the 302 or 351).
Plus, the going with a smaller setup allowed for finer fuel control and precision. Win/win.
First thing I needed to do was fit the 2bbl style throttle body to the 4bbl intake. Mr. Gasket made a nice adapter, so I bought one and painted it up.
A little test fitting with my newly painted intake.
All bolted up to the engine.
The system needs a coolant temperature sensor mounted. Fortunately, I had a spare port for the heater core return line that had a threaded hole for a vacuum switch. It had the same thread pattern as the sensor, so I was able to put it there. I also found that this s where Ford mounted the EFI era coolant temp sensor in the '87+ trucks, so it worked great.
The upper port (the one with the large hex set screw in it) can't be used since it's temperature fluctuates with the thermostat, and is not the engine's operating temperature.
Next was figuring out the throttle cable. I wanted to use the original sheath, since I'd had terrible luck using aftermarket throttle cables before. The throttle cable exits the cab at about a 30 angle from the gas pedal, which is a nightmare for smooth operation, and keeping the cable from dragging. The stock cable was curved to accommodate this.
The Sniper system utilizes AN-6 fittings, so unless I wanted to run new fuel line all the way to the tank, I needed to figure out how to tie in with the original fuel lines. I ended up using a series of adapters that, while they look clunky, worked really well (and have been leak free for thousands of miles now).
I wanted to keep with the motif, so I went with black fuel lines.
Ran a 12v hot to the fuel pump to pressurize the system and check all the fittings. All good!
Next came the fun of all the wiring. In the end, fortunately, it was quite simple. Many of the wires weren't needed and were either for different ignition setups, or for auxiliary fans, etc.
Power! On to the initial setup.
Everything's hooked up and working. Now for some cleanup. I bundled all the wires together and then sleeved them in looms.
Last on the list, I wanted a mount for the digital display inside the cab, so I fabricated a bracket. I wanted it hook around the dash, and be tucked up and out of the way.
Bent up a piece of steel in the vice.
Tada:
First turn of the key and it fired to life! I couldn't have been more happy.
At this point, it had been 37 days of non-stop work. Every day after work until bed time, and full weekends. I was exhausted.
But, I finished it 3 days before we had to turn in our leased car, so I made it!
The Bronco finally buttoned back up. Engine swapped, converted to a manual ZF5, converted to fuel injection, exhaust installed, hoses install, wiring installed, hood back on, and running.
It was time for my first test drive. My wife and I hopped in and I put it into granny low and pulled out of the garage. I wasn't used to the tension on the gas pedal spring, so it spun the tires on the garage floor, and launched out of the garage. (I was proud).
For a first test drive, it couldn't have driven better. SO much work, and suddenly all worth it.
My '85 Bronco was now how I wanted it.
Out of the garage and back in the driveway!
March 2016 FOTM
Supermotors Pics
post #77 of 87 (permalink) Old 05-20-2019, 08:35 PM
September 15 FOTM
ANGELO's Avatar
20180317_184327 by Angelo Mehtala, on Flickr
i turned my factory ac condenser into a trans cooler and added a powewrsteering cooler
20180317_184306 by Angelo Mehtala, on Flickr
jbg sag swap. didnt fit. i had to modify the bracket to fit the pump.. then had to get the pump warrantied
moved to a new house. the bronco fits perfect in the stable
20180530_153206 by Angelo Mehtala, on Flickr
I got those skinny interco 37s, i needed street able tires and those were a good deal. not what i wanted but they were cheap
building my snorkel
20180706_143041 by Angelo Mehtala, on Flickr
20180707_150956 by Angelo Mehtala, on Flickr
20180707_150946 by Angelo Mehtala, on Flickr
just relied i dont have any under hood pictures of the snorkel. this kinda showes it. im using a spectre inline filter
20190108_172440 by Angelo Mehtala, on Flickr
20180721_103353 by Angelo Mehtala, on Flickr
it exhaust pipe so when i go to deeper water i can just slip a pipe over it to extend it. I decided on a short one because i couldnt figure out how to do a full length one that would still look good
post #78 of 87 (permalink) Old 05-21-2019, 02:49 PM
Big Six
A couple little, but much needed side projects for a nice daily driver.
The stock cup holders are more of a "suggestion" than an actual cup holder. I'd never consider setting anything here while the Bronco was moving.
Fortunately, some boat sleeve cup holders work great!
Time to get out my power tools.
The cutting gets pretty hot, so there was a lot of plastic slag.
They look nice and original, and the black offsets nicely with the black dash I installed.
Sometimes it really is the little things that make the difference.
Another side project was swapping out the early era fuel hose. The 86 and prior had an air vent tube to vent the gas tank. This could easily get kinked if you moved anything around, which would make it extremely difficult to fill. It also caused the engine to stall after long periods of driving, since the vacuum in the tank would overcome the pull of the fuel pump.
The later era used the outer portion of the tube as the air vent (plenty), and an inner hose for the fuel flow. A simple redesign, but significantly better.
It also allows for newer style gas caps, such as this locking specimen.
I also failed to mention that, along with my 300, I swapped in my Saginaw pump. This is a highly recommended upgrade!
Last but not least, one thing I thought was fun about the Holley Sniper on my 300 is that I got to leave this on the tailgate.
March 2016 FOTM
Supermotors Pics
post #79 of 87 (permalink) Old Yesterday, 11:45 AM
allcruisen's Avatar
Hello Boys and Girls, SORRY For being MIA. I had to fly down to Florida for Drs. appointment, Yes my Drs. are for the most part down in Florida.
My dumb fone won't let me upload any thing. Just view the forum.
These are some of the lights that have caused the Bronco to be named "THE UFO"
Why the heck those SM uploads my pix sideways ?
Allcruisen
BigBlue 94, Quader1 and SRWillis like this.
VOTE For FOTM !!!
post #80 of 87 (permalink) Old Yesterday, 12:16 PM
allcruisen's Avatar
Didn't know the wifey took these pics of our repairs at Gilmer. Here I had to replace the Center Link I bent at Gilmer earlier that Day:
Allcruisen
VOTE For FOTM !!!
Similar Threads
Full Size FSB Invasion 2019 deathmobile2 Mountain States Chapter 1098 Yesterday 05:51 PM
March Full Size of the Month 2019 Vote Here!!! allcruisen F.O.T.M Voting 131 04-01-2019 03:00 PM
January Full Size of the Month 2019 Vote Here!!!! Quader1 F.O.T.M Voting 132 02-01-2019 11:35 AM
FULL SIZE OF THE YEAR 2018 VOTE HERE!!!!! Quader1 F.O.T.M Voting 117 12-17-2018 01:04 PM
