Ford Bronco Forum - View Single Post - What Did YOUR Bronco Get For Christmas?
post #50 of (permalink) Old 12-28-2011, 10:12 AM
Bronco Boy 88
Bronco Boy 88's Avatar
Bronco Info: 88 Bronco 302 5.0L efi
Originally Posted by ToddACimer View Post
I had to cut 1" off the bottom all the way across. Then I had to cut the honeycomb frame 1" shorter. The top bolts right in and the bottom is zip tied. The headlights would fit but you need to extensively modify the header panel or get one from a 04-07 truck.
thanks for the info man
When in doubt, throttle it out
4x4, for when big balls just aren't enough.
Bronco Boy 88 is offline
