Trevor12's Dana 60 SAS - Ford Bronco Forum
post #1 of 5 (permalink) Old 10-27-2014, 10:46 AM Thread Starter
Trevor12's Avatar
Bronco Info: 94 XLT frame off restoration completed. Solid axle swapped Dana 60 and Sterling 10.25 rear on 37s
Did my sas a couple months ago, but I figured I would share it here.
Dana 60 out of an 89 F350. Also had the matching sterling 10.25 rear
Changed the gearing over to 4.56 gears to run the 37" tires
TTB out
D60 cleaned up
Mocking up the placement
Welding up some drop brackets for the lift. We wanted to achieve about 8 inches of lift. This part was hard to figure out how tall to make the brackets and where to place them. We finally figured it out by jacking up the truck until the middle of the fenders were at the same height, and then having the axle sit at normal height. The placement was taken by measuring the wheelbase and moving it accordingly.
The holes were to be plug welded
Cross member fabbed up
Covered the front with diamond plate
Wouldn't fit out of the garage with tires on
Sitting on its own weight again
Works well too
94 Bronco build thread
My thread: http://www.fullsizebronco.com/forum/...=199480&page=1
Trevor12 is offline
post #2 of 5 (permalink) Old 10-27-2014, 12:30 PM
birdman27's Avatar
Bronco Info: 92 bronco
Truck looks good man. nice job.
birdman27 is offline
post #3 of 5 (permalink) Old 10-27-2014, 03:41 PM
AUBronco's Avatar
Hows the ride now??
Patrick
My supermotors page
AUBronco is offline
post #4 of 5 (permalink) Old 10-29-2014, 11:01 AM Thread Starter
Trevor12's Avatar
Originally Posted by AUBronco View Post
Hows the ride now??
It drives better than before. The solid axle with the F350 front leafs handle the bumps so much better than before. No more bump steer either. Easily the best upgrade I've ever done to the truck
Trevor12 is offline
post #5 of 5 (permalink) Old 10-29-2014, 01:14 PM
Resurection Ranch
379sinvb's Avatar
Looks good man, I look foward to doing my own swap to leafs.
Rick
"Left for Dead"
Filly
379sinvb is offline
