96 F250 4x4/SAS - Ford Bronco Forum
 6Likes
  • 3 Post By raleigh
  • 1 Post By raleigh
  • 2 Post By raleigh
post #1 of 17 (permalink) Old 02-19-2019, 09:18 PM Thread Starter
OMF
raleigh's Avatar
Bronco Info: 1979/1972 "Hybrid Hilda"
96 F250 4x4/SAS
Thought I would share my progress, not a Bronco but it is my 96 OBS F250 7.3. Its my tow rig and I carry a 10ft camper so I want to keep it low.
I love this truck, I picked it up for a song because it had a dead cylinder, turned out it had thrown 2 push rods, replaced them and it has run like a top for over a year now.
Anyhow the only thing I didnt like was that it was 2wd, that gonna change very soon.
Picked up a set of 04 SD axles and springs last week and got to work.
The idea is to use as much of the SD bracketry as possible, looks like the only thing I'll have to fab is the track bar and frame bracket. Everything I have been able to modify, or will modify.
I was able to get all the leaf spring mounts burned in today after work and did a little ride height test, LOVE IT! The offset is awesome too
File Type: jpg IMG_20190217_132430_226_1550628891176.jpg (148.9 KB, 12 views)
Dave
Vote for me FOTM!
Built 400, NP435/Strongbox Doubler/NP205
2007 Superduty Axles, Chomo'd, Superjoints, and Locked
110" WB, Body narrowed 6" and armored up!
raleigh is offline
post #2 of 17 (permalink) Old 02-20-2019, 08:41 PM
Bronco Info: 94 XLT, 5.8L, 8 lug HP D44, FF D60, work in progess
Thanks for posting this. I have a D60 out of a 01 F350 that I'm considering using in either my Bronco or other OBS Ford. Any and all additional pictures would be helpful, especially of the rear shackles. You're using stock/OE leaf springs correct? Will you be running a crossmember between the two front spring hangers?
Looking forward to updates.
zainyD is offline
post #3 of 17 (permalink) Old 02-20-2019, 10:02 PM Thread Starter
OMF
raleigh's Avatar
Yeah, I'm using all of the SD brackets and springs.
I'll take some pics once it's done so you can see what I did.
Yes, I'll be a bar between the front leaf hangers under my intercooler.
Dave
Vote for me FOTM!
raleigh is offline
post #4 of 17 (permalink) Old 02-21-2019, 11:46 AM
Looking forward to seeeing the pictures of how the brackets are attached to the frame. I have been pondering this for awh9ile. NICE find on the truck with the "dead" cylinder. Thats something we all dream about, lol
1989 F-150 4.9/C6/2.73 reg-cab LWB 2wd DD
79 f-150 4wd Craigslist 400/C6 swb spooled rear
2017 F-350 CCLB 4x4
kubotaorange76 is offline
post #5 of 17 (permalink) Old 02-21-2019, 11:47 AM
Thats a pretty cool way to do a leaf SAS
reptillikus is offline
post #6 of 17 (permalink) Old 02-22-2019, 12:20 PM
Wild Cayuse
Nice work. Btw, you are aware of the value of your old wheels and especially center caps, right?
P.s, that's why I bought a f350... SA from the get go
July, and September!
FOTM forum section
BigBlue 94 is offline
post #7 of 17 (permalink) Old 02-22-2019, 01:39 PM Thread Starter
OMF
raleigh's Avatar
Yes, I love these wheels, I was hoping to find a BJ 60 I could use so I could keep them but no luck.
BigBlue 94 likes this.
Dave
Vote for me FOTM!
raleigh is offline
post #8 of 17 (permalink) Old 02-25-2019, 08:58 PM Thread Starter
OMF
raleigh's Avatar
Nearing completion!
Got a done of work done this weekend, only things left are front shocks, front sway bar, box the frame where I had to notch it and the track bar.
I'll take care of the shocks and sway bar tomorrow and a friend of mine will be building the track bar since I don't have a bender anymore. Anyway here are some pics, I'll get better pics tomorrow when it's light out
In order to use the SD rear shackle mounts I had to notch the frame, so I have a pair of plates to box the frame in that area, cleans it up nicely, pics to follow
reptillikus and '89Bronco302 like this.
Dave
Vote for me FOTM!
raleigh is offline
post #9 of 17 (permalink) Old 02-26-2019, 11:49 AM
It looks good like that, like it was built that way from the factory. Which leafs did you use in the front?
[hijack]
While they look mostly identical, i thought only the Alcoas and not the Ford-manufactured wheels are worth $$$. Or are the Ford ones sought after now too? (i have a set of the ford ones.) I havent been following.
[/hijack]
post #10 of 17 (permalink) Old 02-26-2019, 03:25 PM
Wild Cayuse
[hijack]
[/hijack]
A good centercap with functional spring will fetch 75 bucks here, each. NOS pieces over 100. The wheels are more common, but still valuable. The stockers on my 96 f350 were the Alcoa's. Didnt know there were two identical wheels made by two companies for the "OBS" 8 lug trucks.
FOTM forum section
post #11 of 17 (permalink) Old 02-26-2019, 08:26 PM Thread Starter
OMF
raleigh's Avatar
These are the SD springs, they ride much better than the OBS inverted springs from what I have heard.
I've been driving it some today and it rides pretty nice, not much difference from the coil springs.
A small amount of bump steer which I expected since I don't have the track bar yet.
Dave
Vote for me FOTM!
raleigh is offline
post #12 of 17 (permalink) Old 02-27-2019, 10:12 AM
I have a set with 305s on them; the set i ran on the green bronco when i first got it on the road. Ford stamps instead of Alcoa. Im pretty sure its the same way with the 5 lug wheels; two manufacturers.
Sorry, i meant which SD springs. I have the X codes in front of mine. Even with how stiff the X Codes are, they still ride better than the OBS springs.
post #13 of 17 (permalink) Old 03-08-2019, 08:12 AM
Raleigh, any additional close-up pictures of the brackets (front/rear) from different angles/sides that you could post pictures of? Any additional information would be greatly appreciated. Thanks again for posting this.
zainyD is offline
post #14 of 17 (permalink) Old 04-04-2019, 08:08 PM
Bump for additional pics and updates.
I picked up a set of Super Duty front leaf springs and brackets yesterday at the pick-n-pull. Just about have the parts I need to SAS my 95 F250.
zainyD is offline
post #15 of 17 (permalink) Old 04-04-2019, 09:08 PM Thread Starter
OMF
raleigh's Avatar
Sorry, I'll get some pics this weekend
Dave
Vote for me FOTM!
raleigh is offline
post #16 of 17 (permalink) Old 04-18-2019, 07:15 AM
Any luck with those additional pics?
zainyD is offline
post #17 of 17 (permalink) Old 04-18-2019, 12:46 PM
Dave is full of surprises LOL.
Similar Threads
Got rid of the F250.. Got a different F250 (semi-long story) Pictures Added Bronkzilla General Discussion/ Bronco and Wheeling related. 53 07-13-2004 09:24 AM
how hard to install an 85 F250 5 speed in my '90 Bronco? xxxxxxxxxxTCRIMSONK 1980-'96 Bronco Tech 15 03-30-2004 11:59 PM
Friend's dad has a cheap '86 F250... What to do? xxxxxxxxxxTCRIMSONK 1980-'96 Bronco Tech 20 03-24-2004 05:19 PM
f250 sas -> bronco knarf121 Solid Axle Swaps 8 01-03-2004 02:47 AM
79 f250 zeus0909 Noobie Bronco Tech Questions. Flame free zone! 3 11-24-2003 04:20 PM
