BOSS's SAS Build - Page 10 - Ford Bronco Forum
post #181 of 498 (permalink) Old 08-30-2006, 10:41 AM
Former owner of Shadofax
Originally Posted by bossind
Ok I guess I wasn't following your post, sound like you said these ones in the pics would be fine, which is why I questioned you on it.
But now I understand.
you're listening to all the little bumps in the night at your shop, and not to ME???
I had said the 90* fitting crazed used and that caliper should be fine.
post #182 of 498 (permalink) Old 08-30-2006, 11:33 AM Thread Starter
Retired Staff
bossind's Avatar
Its true, its a bit disturbing and distracting. I'll be a better Grasshopper!
bossind is offline
post #183 of 498 (permalink) Old 08-31-2006, 01:20 AM
dont u hate all the bumps and noises in a shop at night . but not all of them are made up in your head. i thought i heard somthing under a car in my brothers shop i get down to take a look and theres somones mean ass dog. i also had a guy just walk in asking for all my 60 watt lightbulbs. he was crazy in the head. ps lookin good
92f150300six is offline
post #184 of 498 (permalink) Old 08-31-2006, 09:15 AM Thread Starter
Retired Staff
bossind's Avatar
What gets me everytime is when I'm grinding or welding late at night all alone, lost in my own thoughts. I stop and turn around and someone is standing there watching me! I'l never get used to that.
bossind is offline
post #185 of 498 (permalink) Old 08-31-2006, 11:12 AM
How can you be alone, if someone is standing there watching you?
Great job, keep it coming.
desertrat_666 is offline
post #186 of 498 (permalink) Old 08-31-2006, 11:14 AM Thread Starter
Retired Staff
bossind's Avatar
I was alone so that would mean someone came in!
Thanks!!!!
bossind is offline
post #187 of 498 (permalink) Old 08-31-2006, 12:17 PM
bronco boy's Avatar
Bronco Info: No More Bronco
Stiop your bitchin' guys! How do you think I feel; I hear voices all the time!!
Chris B
bronco boy is offline
post #188 of 498 (permalink) Old 08-31-2006, 01:14 PM Thread Starter
Retired Staff
bossind's Avatar
I thought you stop reading back on page 2!!
bossind is offline
post #189 of 498 (permalink) Old 08-31-2006, 02:42 PM
bronco boy's Avatar
I never said that. Must have beem them voices.
Chris B
post #190 of 498 (permalink) Old 08-31-2006, 04:31 PM
Sheesh, crazy Canadians. Not sure what all you're doin' out in dem dar woods, me thinks you're both flipped.
post #191 of 498 (permalink) Old 08-31-2006, 04:43 PM Thread Starter
Retired Staff
bossind's Avatar
Come for a visit and find out on what your missing.
Anyway just a few pics, found a place that had the russell fittings for the calipers and the lines are on order.
Got the axles in.
bossind is offline
post #192 of 498 (permalink) Old 08-31-2006, 06:30 PM
very nice, what's the plan with the lower coil pad? It's not painted all purdy, so I'd guess you're still fiddling with fitment? Looks like you've been rotating it? put a wedge under it yet?
post #193 of 498 (permalink) Old 08-31-2006, 09:04 PM Thread Starter
Retired Staff
bossind's Avatar
Your good! they don't fit flat so I'm going to make a shim to level them out, and the left side the holes don't line up so I have to take the die grinder and lenghten one of the holes. Oh and one of them was bent - I bought them off of "ESC" after he totaled his 79 bronco, must of got bent when he rolled it. I heated it up and pounded it flat again.
bossind is offline
post #194 of 498 (permalink) Old 08-31-2006, 09:09 PM Thread Starter
Retired Staff
bossind's Avatar
Ok I installed fluid in the front diff tonight! Figure I might as well test the seals and just one less thing to remember before driving it.
I finnally finished off the cage shock mounts, I made a 1/2 spacer to go in between the frame and the cage mount. I'll weld them up this weekend and will slide the diff into place.
bossind is offline
post #195 of 498 (permalink) Old 09-01-2006, 12:55 AM
Bronco Info: 90 Bronco
The lower spring pads are prone to bending,you should weld a plate on the bottom of the pads to reinforce them.
bronco1 is offline
post #196 of 498 (permalink) Old 09-01-2006, 01:20 AM
He mentioned making a shim, so that should cover it. you are likely right though, I've seen some used lower coil cups....not good. I went and spent money on new not trusting them.
bossind, one more item, you're going to use the superflex coils right? Take a long look at your clearance with the stock upper coil tower and the bolts, especially that driver side bolt front lower. On the JBG's (which have less clearance) I had to use round heads. I have an SAS thread on these clearance bolts if you search.
post #197 of 498 (permalink) Old 09-01-2006, 10:08 AM
"Clever User Title Here"
Ralphenstein's Avatar
Bronco Info: 96 Eddie, 351W, 32x11.50 Mud Terrains, Flowmaster Crap Back; 93 Eddie, 302, Misc Parts Laying Around
Hey Bossind...hate to be a doosh, but could you give me some dimensions on that nifty trans crossmember of yours?
I want to make a solid model and whip up a 3-view drawing of some ideas I got running round in my head. I will likely have some time at work in the next few weeks...might get started on building me something with some scrap pipe/tubing etc. that we have laying around here.
Thanks!
Sig Courtest of KOJ
Ralphenstein is offline
post #198 of 498 (permalink) Old 09-01-2006, 11:24 AM
bronco boy's Avatar
Well, between the and the , we got er covered!
Chris B
post #199 of 498 (permalink) Old 09-01-2006, 11:35 AM Thread Starter
Retired Staff
bossind's Avatar
I seen that post (thread) with the bolt, and will be doing the same just haven't gotten back into town to get them. Thanks for the reminder.
bossind is offline
post #200 of 498 (permalink) Old 09-01-2006, 11:37 AM Thread Starter
Retired Staff
bossind's Avatar
Thanks!
Sure no problem, I'll measure it up this weekend.
bossind is offline
Tags
sas
