Ford Bronco Forum - View Single Post - D44, coil sas for me.
post #6 of (permalink) Old 03-17-2013, 04:04 PM Thread Starter
zippome
zippome's Avatar
Originally Posted by PVTbronco View Post
Wow, great build! I like how it isn't totally jacked up like most others. I'm guessing you're running 35"x12.5" right? Also, why did you have to cut the crossmember? Just so you know I will probably be pestering you more and more when i get close to doing mine hahaha.
That's fine, pester away. Yes I am running 35"x12.5". And I cut the cross member because otherwise the track bar would of hit it. If you move the axle forward more than I did you can get away with not cutting it. But that is a lot harder than just cutting the cross member.
zippome is offline
