Built 351w with an AOD - Ford Bronco Forum
  • 1 Post By race4food
post #1 of 6 (permalink) Old 06-09-2019, 04:52 PM Thread Starter
Bronco Info: 1987 Bronco, 351w, AOD, manual transfer case, manual locking hubs, around 3 inch lift.
I would like to know what a stock 87 AOD can take from a built 351w with I am guessing around 425hp. Transmission has around 90,000 miles on it. Have not moved it in close to 2 years and the old 302 then was running like crap so no tell how it ran. We replaced the valve body with a constant pressure one replaced torque converter, high capacity oil pan and earls oil cooler. I eventually want to get it rebuilt and beefed up but for when it is ready to drive I want to know what I can’t do.
Thanks- Griffin
GriffinB is offline
post #2 of 6 (permalink) Old 06-11-2019, 12:14 PM
aka: kemicalburns
TravisITGuy's Avatar
make sure the TV cable is adjusted correctly and it should be fine i would think. with that said there are no guarantees with Auto's. to many variables involved.
TravisITGuy is offline
post #3 of 6 (permalink) Old 06-11-2019, 12:27 PM
Ford Hoarder
He has constant pressure valve body, so TV cable non-issue. With those the TV cable is just for the shift point, it could break and the trans will be fine, though may shift extremely high rpm, I am not 100% sure what the constant pressure bodies do when this happens...
With that said, I would still be a little worried about the input shaft, and I would not do the 1-2-1 shuffle or let it go into overdrive when beating on it.
I think you will likely be at least "OK" with that setup though, maybe just try not do to any foot brake assisted launches. I think should be more then fine to break the new engine in.
CrazyBRONCOguy is online now
post #4 of 6 (permalink) Old 06-11-2019, 04:24 PM Thread Starter
Thank you for the reply, I am working on installing a Lokar TV cable currently.
GriffinB is offline
post #5 of 6 (permalink) Old 06-12-2019, 09:50 AM
LVSteve's Avatar
Bronco Info: 95 XLT Sport 96 427w/e4od obd II Long tube's Solo stage 4 with Kings 35's & 4.88 Turetracs. RWHP/TQ
Good luck with the Lokar stuff !
LVSteve is online now
post #6 of 6 (permalink) Old 06-14-2019, 04:58 PM
That should last quite a while. Heat and band slipping is what kills it. If you are not towing super heavy and just driving around and just having fun on the street
it should last quite a while.
Synthetic fluid would be a very helpful addition.
LVSteve likes this.
race4food is offline
