Ford Bronco Forum - View Single Post - Mongomann75's 85 Build
post #229 of (permalink) Old 10-01-2015, 08:04 AM Thread Starter
MONGOMANN75
MONGOMANN75's Avatar
Bronco Info: 1985 351W C6 Going thru severe Chemo and Radiation Therapy
So the source of my frustration has been remedied! I was having difficulty figuring the correct spacing for the brackets that came with the rear disc brake conversion kit from Jeff's Bronco Graveyard. No matter how many times I tried I could not get the caliper centered on the rotor, Until I lost all hope and put the death wheel on my grinder!
I cut 1 mounting bolt hole off the base plate to allow it to slip over the axle tube so I could mount it to the back side of the mounting plate welded tot he axle tube. Having done this I also had to clearance these mounting bolts on the actual caliper bracket.
Needless to say the direction said nothing of this, but I guess if you can't figure it out you really shouldn't be installing a disc brake kit in the first place.
https://youtu.be/V9Jpk7W0QRY
A short video of the drivers side going on once I figured out the correct spacing on the brackets! Brakes are done! Well OK maybe not entirely I need to complete the rear brake lines and bleed everything out then the brakes will be done!
3 Generations together on one Project, Our build thread, meet Patches.....
http://www.fullsizebronco.com/forum/...d.php?t=335545
MONGOMANN75 is online now
