I'm gonna go with the F350 pump. I have no idea what year the donor boost came off of, I'm just using it for the inner bits and the core charge. I'll post the progress soon....
I've heard different things about using a bigger MC, but the truth is I didnt want to go through the hassle of bench bleeding and then system bleeding the whole thing! Also, when I start posting pics of what's going on in there, you'll see those brake lines coming of my original MC don't look like they can stand up to too much torque....
It was pretty easy! I just used a dremmel grinder to grind the holes on the MC out a little, and had to bend that hose going into the steering gear a little to get it in there. I'm not going to run a cooler quite yet, I'll do that soon enough. As usual, there was one part of this that was a pain, and that was getting the pulley on and off the old / new power steering pump. Whenever I do something, I can usually pull it off pretty quickly, but there's always one thing that holds me up. Dammit.
The brakes are really like riding in a whole different truck right now. The difference is really amazing. The only thing that annoys me is how loud that F350 pump is. I'm probably gonna go saginaw sooner than later, but it's annoying to spend the money on that pump and then have to waste it. My only question about the saginaw is hoses.... am I gonna have to fabricate my own? I know the pressure line from the pump is a different size, but it's the same at the steering gears. What about with a hydroboost? Better yet, what vehicle had the saginaw and the hydroboost so I could just order that part? Hmmmm....
Nice clean Eddie Bauer! Any thoughts on trying to source the rear trim that covers the topper bolts? Probably pretty hard to come by in decent shape and in tan.
Alright haven't posted in a while on this but I'm gettin stuff done. Starting to pull everything apart for the painting and rebuild:
So it's going well. Finding some stuff under there that I didn't know about. First off there's a remote lock control that's hooked up:
and seeing the bottom of the doors is annoying. Looks like I'm gonna have to find some new ones somewhere.
and this was my favorite. I took of the front of the instrument panel and saw a light was missing. Held the panel up to the light and started laughing. Big no prize for the first person to tell me what light the PO pulled....
Its amazing how lousy PO's are at wiring. My 91' some how ended up with brake lights spliced into an AIR LINE for the adjustable shocks.
Related Threads
3.9M posts
99.2K members
Since 2003
